apeacock
Peacocks Wagon Build
On 12/25/2016 at 10:29 PM, lookforjoe said:
Whose is the 500? Is it an Abarth  :blush: ?
It's my Fiances, boringiish 500 with the NA 1.4? Does better then you'd think in the snow with proper snow tires. We did just get both rear wheel bearings replaced under warranty though. Cupped the crap out of the rear wheels. Only had 4-5k on those winter tires and only 33,000 on the car itself.
Re-sealed the Angle gear on my '00 XC.
#2 is 9143885
#3 is 30735126
Left had seals 2 & 3 live very far down in the sleeve and the angle gear respectively. The transmission side was totally dry and so we decided to leave them be.
The big seal on the exposed passenger side was the most likely culprit.
Cleaned up
Filling it through a long funnel from above the engine.
Took about 98% of the 1L bottle.
Driven 100+ miles on it with no leaks and no foul burning smell.
  • Upvote 3
FIY  -you can fill those out of the car - no fluid will leak out unless you tip it over where the vent nipple is located :)
I use a pair of long sheet rock screws to extract the inner/outer   D/S seal - but if it was dry no reason to fuck with it I agree.
I use a pair of long sheet rock screws to extract the inner/outer   D/S seal - but if it was dry no reason to monkey with it I agree.
Ahh nice i did notice the hole at the top.
We had the thing all sorts of flipped around when refitting it into the car. Should have filmed how it came out.
A screw was needed for the large seal on the pass side. Nothing seems to work better.
Trying to sure up the wiring on my refurb AFR gauge. Yes the innovate died randomly after less then 5000 miles. It was the gauge that was no good.
Looking for the correct pin to fit into the accessory connector under the dash. I had some ok ones from Carquest, however since being bought out, they carry nothing of the sort any more. Can anyone pinpoint which one is correct?
After some research and dealer questioning the correct pins are seemingly unavailable. Out of stock here in the U.S. and not show as available in Sweden.
#27 seemed to be the correct one.
Improvising, I did some junkyard digging into the wires under the dash and took apart some of the male side connectors for those big yellow / purple connectors under the dash.
They produced some decent sized leads. Took a pair of side cutters and pinched them slightly so they fit and where held into the yellow connector.
Happy to say as well the Innovate gauge warranty process went alright. Seems to be working correctly again.
Edited by apeacock
Nice job getting it all fixed quickly.
That being said, I'm a huge fan of my AEM gauges - not the flashiest/most feature laden, but dead reliable and respond quickly. If it continues to be a problem, you could switch the Innovate gauge for an AEM one, they use the same LSU 4.9 Wideband O2 sensor so it would be pretty close to plug and play.
The pins you are looking for are referred to as:
Power Timer, Standard Power Timer, Junior Power Timer or JPT
Obviously there is a size difference between "Standard" and "Junior". Available in male or female configuration. Requires a suitable crimping tool to enable simultanious crimping of both the contact and strain relief tabs. Or just fudge it with pliers and never pull on the cable.
I was thinking of just getting the gauge only (if possible) The screen on this is pretty nice, and I guess it responds quicker? idk. Doing it again I would go for the problem free one.
Did a better job wiring it all together this time too. It's not pretty but its all heat shrink / adhesive quick connects.
I was seeing Flat terminal and terminal pin when locating similar things. I think we are talking about the same pieces. Using this in the end might have proven easier, being pre-crimped and all.
On all the ends I did 3:1 adhesive lined heat shrink to sure it up a bit.  The terminals are just in the connector under the pressure of the 'lid' they are lightly tuggable.
Innovate's MTX-L gauge is shit. It was poorly engineered in many ways, one of them being that they pulse the heater circuit too slowly, causing large temperature swings of the sensing element, leading to premature failure.
The new AEM X-series are worlds better, not in terms of response time and accuracy, but also sensor life.
14 hours ago, Tightmopedman9 said:
Innovate's MTX-L gauge is stuff. It was poorly engineered in many ways, one of them being that they pulse the heater circuit too slowly, causing large temperature swings of the sensing element, leading to premature failure.
I have a feeling that's part of what changed in the Firmware update & Warranty repair. It's on "htr" much longer then it used to be, which I'm really fine with so long as it all works from now on. The 02 sensor came back really clean and with new sleaving on the cable, they may have replaced it as well.
The X series is so thin too, kind of nice if you want to mount it somewhere nontraditional.
Considering Scaling back the A pillar clutter with a single gauge to do both AFR & Boost.
Sitting a little more neatly now. took the time to hot glue down the leather cover and trim the thicker sections on the seams
Quintessential R badge affixed to the front of the grill. Got another junkyard one and gave it a clean with 3-4 plasti dip coats.
Badge is done with 3m red. Clips remain intact.
  • Upvote 3
Love that boot, dude.
Instead of getting the battery turned sideways I decided to make a little helper bracket to hold the intake system off the B+ cable.
This piece of bar stock was going to be a holder for my rear Ohlins reservoirs. I found an old thread on Swedespeed that shows a longer piece going  between the two seat belt mounts for a 3rd row.
Pictures from Gdog16 on SS:
  • Similar Content
    • By Shane E
    • By KMF
      i have a V70r 1999
    • By 05V70RGT
    • By Mustapha
      Hello,
      first time posting here not sure what to expect. So I have an 07 xc70 I recently purchased and have a few questions about some performance mods I would like to do. So this car has about 175k miles and I want to boost my horse power up to the high 200’s if not low 300’s it’s my daily and I want a bit more juice for fun but I don’t want to destroy it too bad I love the i5 sound and the entire car in general. What are some things I can do to increase the horsepower but keep it from killing itself. Also what are some good exhaust mufflers or kits I can buy that increase the sound at higher rpms but not as much at low rpms it just sounds so amazing at high revs and I want to emphasize that as I’m driving. Any feedback or suggestions would be great. Thanks!
    • By zman172
      Box #1
      Steering wheel
      Trunk hatch carpeted trim
      Center console
      Box #2
      A/C compressor
      Windshield wiper motor
      Accelerator pedal
      Fuel door lock solenoid
      Navigation Antenna
      Ignition immobilizer
      Ignition switch starter
      Turn signal stalk
      Sensor alarm
      Seat belt restraints (x2)
      Door sill plates (x2)
      Metal radio pocket
      Volvo plastic radio pocket
      Radio
      A/C control unit
      Side view mirror left
      Servotronic fuse relay
      Trunk latch
      Windshield wiper stalk
      Overhead light driver front
      Rear bumper trim (x2)
      Dashboard trim
      Instrument border
      Rear speaker covers
      Driver motor seat controls
      Passenger motor seat controls
      Gear shifter
      Steering wheel column cover
      Center console trim (x2)
      Front cupholders
      Master cylinder
      Box #3
      Side view mirror right
      Fuel pump regulator
      Overhead dome light rear
      Windshield rain sensor
      Tan headrest with long spikes
      Rear armrest with cupholders
      Power steering pump tank
      Right upper brake light
      Right lower brake light
      Armrest for front seats
      Driver window switch box
      Front passenger window switch
      Airbag sensor
      Rear speakers (x2)
      Box #4
      Side airbags (x2)
      Spare tire
      Rear fuse relay box
      Rear third brake light
      Emergency brake with leather
      Rear trunk speaker trim (x2)
      Right rear trunk carpet trim
      Box #5
      All 4 door panels
      Rear bottom single seat
      Single seat leather upper
      Double seat leather upper
      Right front carpet
      Left front carpet
      Drivers front seat
      Passenger front seat
      Rear trunk hatch trim
      Box 6
      Braking systems (x2)
      Glove box
      Emergency brake trim (x2)
      Center console back plate
      Passenger lower dash cover
      Floor door trim (x2)
      Front door handles
      License plate frame
      Seat railing covers
      Box 7
      Instrument cluster 163000
      Radio trim
      Shifter trim
      Rain sensor cover
      Dash radio storage box
      Fuse panel cover
      Gas tank cover
      Front air bag crash sensor
      Rear air bag crash sensors
      Air bag impact sensor
      Headlight switch
      Hazard light switch
      Dashboard airbag
      Ecu
      Box 8:
      Miscellaneous
      On pallet not in box:
      Door pillar vents (x2)
      Torque rod
      Trunk pillar covers (x2)
      Left side skirt cover
      Right side skirt cover
      Trunk trim no cut out
      Dashboard
