apeacock
Peacocks Wagon Build
On 8/7/2017 at 10:43 PM, gdog said:
Ah, aluminum brazing; very cool!!  I must confess, I'd never heard of that before.  Now I know how I'm going to install my WMI port bung onto the intake pipe!   Thanks!  :tup:
It was really not as difficult as I first thought. The videos make it look pretty easy and I think in the end it was. Just took good prep work.
Here are the rods I bought. They also had a little video of all the uses etc. http://www.ebay.com/itm/5-HTS-2000-18-Aluminum-Brazing-Rods-STARTER-KIT/270726153179?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
For small jobs it can work quite well - just be sure you 'tin' (heat & apply a surface coat of the braising material) the surfaces prior to joining, it will make for a more complete join. Just like solder & traditional braising, the join is more complete that way. I used it to do IC piping before I bought the TIG, and for large areas like that it was a royal PITA - I would not recommend it for that at all. Small OD work is not bad.
9 hours ago, lookforjoe said:
For small jobs it can work quite well - just be sure you 'tin' (heat & apply a surface coat of the braising material) the surfaces prior to joining, it will make for a more complete join. Just like solder & traditional braising, the join is more complete that way. I used it to do intercooler piping before I bought the TIG, and for large areas like that it was a royal PITA - I would not recommend it for that at all. Small OD work is not bad.
I was thinking of attaching the other beaded end to my current one but I'm glad I didn't It's some what imprecise when you get it going and especially on a curved surface it can quickly run away.
Tig would be essential doing larger areas.
day in the life of the R, Tuning things. Tuner pro logging through an awesome little box from Vanderbrock (block?)
Buffalo Cars and Coffee on Sunday, always a great crowd, lots of super cars, old porches, Bmw, lotus, MG, Americana, and Occasionally a Volvo or two.
Edited by apeacock
love that 2004 R and yours! you are 98 right? are you tuning yourself or sending logs somewhere?
99 my friend.
Sending stuff to the Great Stev0
Sometimes you have good days and sometimes you have bad days. Had a bad evening drive home that could have been worse. Lost all power and then smelled gas. Really panicked and got over the 3 lanes while coasting as fast as I could.
The line popped out of it's holder. I was even just driving normally. I had done a hard pull during this trip but maybe 10 minutes earlier.
Is there a way to ensure the end is still good? The AAA guy was nice and we jacked up the front of the car. I clicked it back in and I was good to go. Came home and opened it again to see what was up.
Side of the road
Clicked back in
Disconnected again at home.
Edited by apeacock
Is this back on the tank or somewhere else?
I'm working on re-doing all of the fuel lines on my '98 R and these stupid quick connections are the biggest issue I've been running into. The standard push-to-click ends that are available at the parts store are too short and won't clear the lock ring and the straight versions are too tall and hit the floor. I did find adapters online that will click onto the fuel pump and have A/N fitting adapters on them for A/N lines. I haven't tried them yet though to check the fitment. I wish the original ends were still available. That would make this easy with some nylon tubing.
Certainly would! When Ben did my pump he re used the elbows by the pump. Almost makes me want to keep a look out for them at the yard from now on.
This is where the long line meets the engine block.
Going to go with some of those 5/16 to AN fittings myself.
Still need to give it a few hard runs but I think the fuel line issue is resolved.
Used the following parts with success. Russell  624000 644110 & 660000
The screw type GM ->  AN connector is pretty sweet. Feels very secure and the o-rings make a really tight seal around the hardline piping. I likely didn't need a oetiker clamp on the -4 barbed fitting but It feels better to have one there.
-4 aeroquip tube fits neatly inside the oem tube tray under car device as well.
I ended up cutting out teh old fuel line a few inches into where it runs over the tank. I didn't have the resources to bring the tank and subframe down enough to see the whole top area. I figured this way I wouldn't break any of the tiny parts on top of the tank and with how robust this tube it being clamped into place (Tank hose Car body) it would be just fine that way.
Left a bit of extra incase I do ever take the rest of the rear end down and want to run it clean the whole way.
Used a 90* connector from a junk car at the end to ease the turn the new tube has to make. I ran it right by the filter feed line / the filler neck. Zip tied it to both along the way to keep everything in line.
Well-documented. It sucks that a lot of the fuel parts are NLA now but your solution looks pretty robust.
Forget NLA that OEM fuel line is $993 from tasca!!
Drove it today to give everything a shake down and the lower line seems perfect. Now the top decided to let go, the "striker plate" is bent out of shape and so there was some leakage occurring.
You mind posting up or PMing me a part number for that fuel line. $993 is absolutely insane. I imagine the 99 has some different lines than the 98 as the fuel line setup is different but still curious to see what's available here in Germany and at what prices.
Thanks in advance!
Thanks in advance!
Pming too but worth posting here for everyone
Fuel pipe for AWD part #9445512 This is for the AWD specific Fuel filter to engine connection.
Direct Link for a bigger view - https://imgur.com/rqagySA
Edited by apeacock
  • Similar Content
    • By Mustapha
      Hello,
      first time posting here not sure what to expect. So I have an 07 xc70 I recently purchased and have a few questions about some performance mods I would like to do. So this car has about 175k miles and I want to boost my horse power up to the high 200’s if not low 300’s it’s my daily and I want a bit more juice for fun but I don’t want to destroy it too bad I love the i5 sound and the entire car in general. What are some things I can do to increase the horsepower but keep it from killing itself. Also what are some good exhaust mufflers or kits I can buy that increase the sound at higher rpms but not as much at low rpms it just sounds so amazing at high revs and I want to emphasize that as I’m driving. Any feedback or suggestions would be great. Thanks!
    • By zman172
      Box #1
      Steering wheel
      Trunk hatch carpeted trim
      Center console
      Box #2
      A/C compressor
      Windshield wiper motor
      Accelerator pedal
      Fuel door lock solenoid
      Navigation Antenna
      Ignition immobilizer
      Ignition switch starter
      Turn signal stalk
      Sensor alarm
      Seat belt restraints (x2)
      Door sill plates (x2)
      Metal radio pocket
      Volvo plastic radio pocket
      Radio
      A/C control unit
      Side view mirror left
      Servotronic fuse relay
      Trunk latch
      Windshield wiper stalk
      Overhead light driver front
      Rear bumper trim (x2)
      Dashboard trim
      Instrument border
      Rear speaker covers
      Driver motor seat controls
      Passenger motor seat controls
      Gear shifter
      Steering wheel column cover
      Center console trim (x2)
      Front cupholders
      Master cylinder
      Box #3
      Side view mirror right
      Fuel pump regulator
      Overhead dome light rear
      Windshield rain sensor
      Tan headrest with long spikes
      Rear armrest with cupholders
      Power steering pump tank
      Right upper brake light
      Right lower brake light
      Armrest for front seats
      Driver window switch box
      Front passenger window switch
      Airbag sensor
      Rear speakers (x2)
      Box #4
      Side airbags (x2)
      Spare tire
      Rear fuse relay box
      Rear third brake light
      Emergency brake with leather
      Rear trunk speaker trim (x2)
      Right rear trunk carpet trim
      Box #5
      All 4 door panels
      Rear bottom single seat
      Single seat leather upper
      Double seat leather upper
      Right front carpet
      Left front carpet
      Drivers front seat
      Passenger front seat
      Rear trunk hatch trim
      Box 6
      Braking systems (x2)
      Glove box
      Emergency brake trim (x2)
      Center console back plate
      Passenger lower dash cover
      Floor door trim (x2)
      Front door handles
      License plate frame
      Seat railing covers
      Box 7
      Instrument cluster 163000
      Radio trim
      Shifter trim
      Rain sensor cover
      Dash radio storage box
      Fuse panel cover
      Gas tank cover
      Front air bag crash sensor
      Rear air bag crash sensors
      Air bag impact sensor
      Headlight switch
      Hazard light switch
      Dashboard airbag
      Ecu
      Box 8:
      Miscellaneous
      On pallet not in box:
      Door pillar vents (x2)
      Torque rod
      Trunk pillar covers (x2)
      Left side skirt cover
      Right side skirt cover
      Trunk trim no cut out
      Dashboard
    • By lowbudgetracing
    • By andyb5
    • By cryptophilosopher
