apeacock
Peacocks Wagon Build
On 12/12/2018 at 11:06 AM, Commander Riker said:
Wheels are on point!  Car looks great.
Thanks! Salt on the road means it's away for now. Going to pull bits apart and heat wrap / clean old gunk.
On 12/12/2018 at 4:04 PM, Andzey said:
Lucky you having PS4S in 17"..
Smallest size they make for the PS4S!! Also the max I can fit width wise so that's lucky.
Edited by apeacock
I'm running 225/40R18 PSS on mine without issue and have heard of others running 235s.
the 7.5" wheel and equivalent of a 28mm offset make the rears a hair off hitting the plastic fender liners though. Other wise yes I could fit a wider tire.
Exhibit A:
7 hours ago, B_Dub said:
Those wheels are so god damn hot. Wish I had a set. :biggrin:
SO rare where would you find one! :biggrin:
Edited by apeacock
On 2018.12.16. at 12:14 AM, apeacock said:
This stretch is exactly the same as my 205/50R17 Conti SC2 on 7.5j Enkei GT7
When I got my '00 R with 17" Satellites it had 215/45R17 Hankook Ventus and they were by a thickness of paper same width as aforementioned 205 Sportcontacts. I hate how tire manufacturers sell us imaginary tire width that has nothing common to real tire footprint width
Would be nice to at least standardize the point at which they are measured right?Or maybe provide a template with the width etc. Couldn't be that hard.
Getting more stuff back together post 'heat shielding' everything down behind the engine.
Removed the rear water pipe to give a bit of a bend to the turbo return line and as a result I  made a new leak =[
Seems like it was difficult to refit and that lead to something with the o-ring inside there getting messed up, so I'm going to use a stop gap solution for now until the whole assembly comes back out again for  a major planned refresh.
Gold looks nice though ❤️
  • Upvote 3
I should have put this up before but here is what the front prop shaft bearing holder guy looks like when it rubs it self to death.
On 3/13/2019 at 10:01 PM, B_Dub said:
What’s the major planned refresh? Do tell
Happening in two weeks is:
Cylinder head from a V70R
"Stage 2" port services with enlarged valves and "race porting"
Manley custom stainless over sized inlet and outlet valves.
While it's down and out doing the front A arms, tie rods, reseal the oil pump / pan (i think that's where this leak is coming from), and change to the new style oil pickup.
Might delve into the axle seals for the rear diff as well since it's been gooey and cruddy since the day I bought the thing almost 7 years ago.
Gonna be sweet!
Weather was great yesterday, almost 60 degrees outside. Had the time to swap in the new stiffer springs. Going from 450lb to 600lb rated. No drives yet but the "knee test" we are all familiar with felt pretty good. I'm also happy to have some ride height back again.
I also realized I've had the rubber isolators / seats in the bottom for years now. Pulled those out in the process.
Note how much height the springs lost over the last few years. These came from @lookforjoe on his former wagon and have been on mine for a while now. At least 1/4" gone off of them.
  • Upvote 2
wow - interested to see/hear more on the motor work
600lb, damn. I went from 350lb to 450lb Eibachs based on my calculations for the rear suspension (optimal was ~475lb IIRC) and think it rides great. Interested in hearing your thoughts.
So I'm guessing the threads on coilovers can take a crazy amount of abuse? I've always wondered how that works. It looks like all of the force from any bump you hit is pushing up against the threads.
Yeah, all the spring force is against the collar. The collar engages several of the threads at once so it helps to spreads the force out.
  • Similar Content
    • By 05V70RGT
    • By Mustapha
      Hello,
      first time posting here not sure what to expect. So I have an 07 xc70 I recently purchased and have a few questions about some performance mods I would like to do. So this car has about 175k miles and I want to boost my horse power up to the high 200’s if not low 300’s it’s my daily and I want a bit more juice for fun but I don’t want to destroy it too bad I love the i5 sound and the entire car in general. What are some things I can do to increase the horsepower but keep it from killing itself. Also what are some good exhaust mufflers or kits I can buy that increase the sound at higher rpms but not as much at low rpms it just sounds so amazing at high revs and I want to emphasize that as I’m driving. Any feedback or suggestions would be great. Thanks!
    • By zman172
      Box #1
      Steering wheel
      Trunk hatch carpeted trim
      Center console
      Box #2
      A/C compressor
      Windshield wiper motor
      Accelerator pedal
      Fuel door lock solenoid
      Navigation Antenna
      Ignition immobilizer
      Ignition switch starter
      Turn signal stalk
      Sensor alarm
      Seat belt restraints (x2)
      Door sill plates (x2)
      Metal radio pocket
      Volvo plastic radio pocket
      Radio
      A/C control unit
      Side view mirror left
      Servotronic fuse relay
      Trunk latch
      Windshield wiper stalk
      Overhead light driver front
      Rear bumper trim (x2)
      Dashboard trim
      Instrument border
      Rear speaker covers
      Driver motor seat controls
      Passenger motor seat controls
      Gear shifter
      Steering wheel column cover
      Center console trim (x2)
      Front cupholders
      Master cylinder
      Box #3
      Side view mirror right
      Fuel pump regulator
      Overhead dome light rear
      Windshield rain sensor
      Tan headrest with long spikes
      Rear armrest with cupholders
      Power steering pump tank
      Right upper brake light
      Right lower brake light
      Armrest for front seats
      Driver window switch box
      Front passenger window switch
      Airbag sensor
      Rear speakers (x2)
      Box #4
      Side airbags (x2)
      Spare tire
      Rear fuse relay box
      Rear third brake light
      Emergency brake with leather
      Rear trunk speaker trim (x2)
      Right rear trunk carpet trim
      Box #5
      All 4 door panels
      Rear bottom single seat
      Single seat leather upper
      Double seat leather upper
      Right front carpet
      Left front carpet
      Drivers front seat
      Passenger front seat
      Rear trunk hatch trim
      Box 6
      Braking systems (x2)
      Glove box
      Emergency brake trim (x2)
      Center console back plate
      Passenger lower dash cover
      Floor door trim (x2)
      Front door handles
      License plate frame
      Seat railing covers
      Box 7
      Instrument cluster 163000
      Radio trim
      Shifter trim
      Rain sensor cover
      Dash radio storage box
      Fuse panel cover
      Gas tank cover
      Front air bag crash sensor
      Rear air bag crash sensors
      Air bag impact sensor
      Headlight switch
      Hazard light switch
      Dashboard airbag
      Ecu
      Box 8:
      Miscellaneous
      On pallet not in box:
      Door pillar vents (x2)
      Torque rod
      Trunk pillar covers (x2)
      Left side skirt cover
      Right side skirt cover
      Trunk trim no cut out
      Dashboard
    • By lowbudgetracing
    • By andyb5
