apeacock
Peacocks Wagon Build
On 8/28/2019 at 9:01 AM, tuner4life said:
Check that the prop shaft bolts are tight, and snug up the crimp-clamp on the boot. Mine did this last year on the front yoke and the bolts had actually worked themselves a little loose.
So they seem to be tight, Oetiker clamp is as tight is it could be from what I can tell. Maybe clean and see if it comes back.
On 6/5/2019 at 3:14 PM, apeacock said:
This is the worst location of the nitrogen reservoirs, you are constantly cooking them. I used my the same way until got recommendation by Thomas from TME Sweden, when ordered springs for ohlins road kit. That was the first thing he mentioned when discussed its adjustments and shoch damper settings
Not the first person to bring this up.
Talking with Ohlins USA "I don’t really know of a max temperature, you would prefer to keep them as cool as possible. I would say just from my track experience to have the best performance keep them around 150 to 200 would be optimum.  "
Drivers side could be easily moved, the passenger side is harder to re-position though. If you figure out a spot to place them I'd give it a shot.
I used the temp stickers and determined they reach about 180 in there after a long drive.
With some minor cutting, those cans could be hidden beneath windshield plastic, near cabin filter for passenger side, and side by side with fuse box for driver
Edited by Andzey
have to balance the cost to rebuild with the enjoyment factor of seeing them though 🙂
Was also thinking more on this and It's certainly interesting to debate. But my recent thoughts were, these are all probably made in a similar way right? N2 + some oil + magic?
How do these fair then on a big sexy beast like this?
Edited by apeacock
Small small dent but one that I always saw when getting in the car. Especially with the motion detected lighting in the garage always perfectly lighting it up.
PDR guy did a great job.
  • Upvote 3
  • Similar Content
    • By zman172
      Box #1
      Steering wheel
      Trunk hatch carpeted trim
      Center console
      Box #2
      A/C compressor
      Windshield wiper motor
      Accelerator pedal
      Fuel door lock solenoid
      Navigation Antenna
      Ignition immobilizer
      Ignition switch starter
      Turn signal stalk
      Sensor alarm
      Seat belt restraints (x2)
      Door sill plates (x2)
      Metal radio pocket
      Volvo plastic radio pocket
      Radio
      A/C control unit
      Side view mirror left
      Servotronic fuse relay
      Trunk latch
      Windshield wiper stalk
      Overhead light driver front
      Rear bumper trim (x2)
      Dashboard trim
      Instrument border
      Rear speaker covers
      Driver motor seat controls
      Passenger motor seat controls
      Gear shifter
      Steering wheel column cover
      Center console trim (x2)
      Front cupholders
      Master cylinder
      Box #3
      Side view mirror right
      Fuel pump regulator
      Overhead dome light rear
      Windshield rain sensor
      Tan headrest with long spikes
      Rear armrest with cupholders
      Power steering pump tank
      Right upper brake light
      Right lower brake light
      Armrest for front seats
      Driver window switch box
      Front passenger window switch
      Airbag sensor
      Rear speakers (x2)
      Box #4
      Side airbags (x2)
      Spare tire
      Rear fuse relay box
      Rear third brake light
      Emergency brake with leather
      Rear trunk speaker trim (x2)
      Right rear trunk carpet trim
      Box #5
      All 4 door panels
      Rear bottom single seat
      Single seat leather upper
      Double seat leather upper
      Right front carpet
      Left front carpet
      Drivers front seat
      Passenger front seat
      Rear trunk hatch trim
      Box 6
      Braking systems (x2)
      Glove box
      Emergency brake trim (x2)
      Center console back plate
      Passenger lower dash cover
      Floor door trim (x2)
      Front door handles
      License plate frame
      Seat railing covers
      Box 7
      Instrument cluster 163000
      Radio trim
      Shifter trim
      Rain sensor cover
      Dash radio storage box
      Fuse panel cover
      Gas tank cover
      Front air bag crash sensor
      Rear air bag crash sensors
      Air bag impact sensor
      Headlight switch
      Hazard light switch
      Dashboard airbag
      Ecu
      Box 8:
      Miscellaneous
      On pallet not in box:
      Door pillar vents (x2)
      Torque rod
      Trunk pillar covers (x2)
      Left side skirt cover
      Right side skirt cover
      Trunk trim no cut out
      Dashboard
    • By lowbudgetracing
    • By andyb5
    • By cryptophilosopher
    • By cruzvolvo
      T-5R Wagon (1995), black, automatic transmission, mostly original with a few moderate suspension upgrades. Approximately 175k, with careful and regular service. This was a California car for most of its life, and is (from best estimates) one of fewer than 100 still on the road in the U.S. It comes with: IPD 3" cat-back exhaust; 4 steelies with snow tires mounted; trailer hitch; original parts no longer installed; and your choice of body panels and parts from a 1995 black 850 NA wagon (parts car). I am a motivated seller and will take $3,000, for the next two weeks. Contact me and I'll answer all questions, to the best of my knowledge, and send any additional pictures that you may want. The car can be seen in Delaware, near I-95.
