apeacock
Peacocks Wagon Build
20 hours ago, lookforjoe said:
Nice!
Did you let DO88 know about the shipping damage? They obviously need to revise their packing since this is a recurring  issue
It's tough to tell if it's shipping or fabricating that's doing it. My unit came in the group buy form re-volv last year and the box seemed alright to me. I'll send them a message about it today and see what they say.
Ended up needing to trim the plastic off the fan shroud by the top venting nipple to have it fit on all the way.
Do88 update, they said it can happen from the fabrication process and is normal. I can also be fixed with a hammer. Though I would be really cautious of doing this but it's something to consider.
____
m66 question.
The reverse light for the m66c comes by itself or in a nice little kit. Can any one identify the connector part number or does some one know where one might be found on a p80 Volvo? I have a bag of connectors but can't compare them to the plug on the reverse switch of my m66 as it was crushed and is being replaced.
It's the black part below.
far as I know it's only available with the kit
I want to say it's similar to an ABS connector on 850s but I really can't remember
I remember what it looks like on the abs module for my s70 and v70 but this looks differen't. Perhaps the time savings of the kit is worth while.
ALso
51 minutes ago, lookforjoe said:
Not the same as any P80 connector.
I'll see if I can find the PN for you.
8690674
Thank you!
Hopefully making that last parts order tomorrow.
Asking this question too. The collar for the angle gear is the same for both cars but the seals should be those for the s40 to match the m66? So a p1 rebuild kit is the proper way to do it.
I used two butt connectors on the reverse wires... as it is a two post connector.  Crimped the wire side... just pushed the other side one.  Done.
Can't visualize that.  I see it's a plug on the transmission side with two posts, probably similar on the p80.
Early rev switch had cylindrical pole connections (Molex) later ones do not.
1 hour ago, apeacock said:
Thank you!
31256008 collar
M66 seals are the all same (all FWD = same, all AWD = same), just a question of FWD or AWD versions
9143911 outer seal (around collar)
9143885 inner seal (for DS passing into diff)
6843481 left side seal
31256008 collar
Thank you I'll source those today. I also definitely have some spare molex male & female ends that can be used for this purpose.
They won't work if your reverse switch is the one you show above (!) The early version switches have the exposed male molex pins, like P80 washer pumps, level sensors, coolant temp sensor, etc.
I had a big bag of connector pig tails from a parts car but the molex style ones where all like the ones you mentioned. None of them were square like the ones shown.
Going to order the switch 3072912 & the receptacle 8690674 They total out too $23~ versus the kit which is $42~ I'm sure I can make these work for less then $20 with of parts and time.
This is whats left of the one that came on the transmission.
Here's the plug on my reverse light switch. Lucas is saying he simply hooked a butt connector to each of those pins. I did that for a little while but didn't like how loose the connectors fit on the pins.
A7C7F9B7-1061-4E4E-8E0C-9032039DD85A_zps
And the matching plug from the S40. The P1 cars use totally different connectors than the P80 cars do.  I forgot to take this from the S40 when I pulled the transmission and had to go back afterwards (when the harness wasn't in the car) to try and find the correct plug. That was tricky...!
9479D2C4-BC23-4805-B9A1-A72B00EC2A85_zps
I'm glad I ordered the connector then! Didn't go with the wires but i'll source those before we start this thing. Any word on shop availability?
If the weather would behave I could get stuff done during my down time.
Yesterday:
This morning:
  • Similar Content
    • By zman172
      Box #1
      Steering wheel
      Trunk hatch carpeted trim
      Center console
      Box #2
      A/C compressor
      Windshield wiper motor
      Accelerator pedal
      Fuel door lock solenoid
      Navigation Antenna
      Ignition immobilizer
      Ignition switch starter
      Turn signal stalk
      Sensor alarm
      Seat belt restraints (x2)
      Door sill plates (x2)
      Metal radio pocket
      Volvo plastic radio pocket
      Radio
      A/C control unit
      Side view mirror left
      Servotronic fuse relay
      Trunk latch
      Windshield wiper stalk
      Overhead light driver front
      Rear bumper trim (x2)
      Dashboard trim
      Instrument border
      Rear speaker covers
      Driver motor seat controls
      Passenger motor seat controls
      Gear shifter
      Steering wheel column cover
      Center console trim (x2)
      Front cupholders
      Master cylinder
      Box #3
      Side view mirror right
      Fuel pump regulator
      Overhead dome light rear
      Windshield rain sensor
      Tan headrest with long spikes
      Rear armrest with cupholders
      Power steering pump tank
      Right upper brake light
      Right lower brake light
      Armrest for front seats
      Driver window switch box
      Front passenger window switch
      Airbag sensor
      Rear speakers (x2)
      Box #4
      Side airbags (x2)
      Spare tire
      Rear fuse relay box
      Rear third brake light
      Emergency brake with leather
      Rear trunk speaker trim (x2)
      Right rear trunk carpet trim
      Box #5
      All 4 door panels
      Rear bottom single seat
      Single seat leather upper
      Double seat leather upper
      Right front carpet
      Left front carpet
      Drivers front seat
      Passenger front seat
      Rear trunk hatch trim
      Box 6
      Braking systems (x2)
      Glove box
      Emergency brake trim (x2)
      Center console back plate
      Passenger lower dash cover
      Floor door trim (x2)
      Front door handles
      License plate frame
      Seat railing covers
      Box 7
      Instrument cluster 163000
      Radio trim
      Shifter trim
      Rain sensor cover
      Dash radio storage box
      Fuse panel cover
      Gas tank cover
      Front air bag crash sensor
      Rear air bag crash sensors
      Air bag impact sensor
      Headlight switch
      Hazard light switch
      Dashboard airbag
      Ecu
      Box 8:
      Miscellaneous
      On pallet not in box:
      Door pillar vents (x2)
      Torque rod
      Trunk pillar covers (x2)
      Left side skirt cover
      Right side skirt cover
      Trunk trim no cut out
      Dashboard
    • By lowbudgetracing
    • By andyb5
    • By cryptophilosopher
    • By cruzvolvo
      T-5R Wagon (1995), black, automatic transmission, mostly original with a few moderate suspension upgrades. Approximately 175k, with careful and regular service. This was a California car for most of its life, and is (from best estimates) one of fewer than 100 still on the road in the U.S. It comes with: IPD 3" cat-back exhaust; 4 steelies with snow tires mounted; trailer hitch; original parts no longer installed; and your choice of body panels and parts from a 1995 black 850 NA wagon (parts car). I am a motivated seller and will take $3,000, for the next two weeks. Contact me and I'll answer all questions, to the best of my knowledge, and send any additional pictures that you may want. The car can be seen in Delaware, near I-95.
