apeacock
Peacocks Wagon Build
Made progress today on replacing the ebrake with stuff from Husseins XCR. Really bummed it took my so long to figure out how to mount the ebrake shoes. Going to make a video of how I did it. Really amazed how easy it is with the proper technique.
Finally got my Mirzams bored out by the only guy I town who would do the job. Only come to find out they don't fit over at least the rear brakes
Maybe a small spacer will do the job? Not sure what width requires longer bolts.
Made a VERY unpleasant noise when bolting it up for the test fit. left a little mark on the caliper.
Edited by apeacock
Sorry to hear of the trials with the eBrake.
Try a 5mm spacer, that is thin enough not to mess with the required lug thread depth.
Hardest part was realizing they need to be slipped into place on the assembly versus having the spring pulled over the whole thing. Can't count how long I've spent trying to make it work.
You should be fine with a 5mm spacer! No longer lugs as well, Like H said
Almost last batch of parts arrive today.
Something seems to be missing from the collar service kit =[
Going to mail it back and get a new set with the additional seal and lubricant.
Took a minute today to install the new detent and the reverse light switch/detent.
Thought I was having trouble shifting at first and then I switch the cables on the shifter itself. Seems to work great, really slots into each gear and as AndyB5 has said to me it's hard to hit reverse when going to 6th.
Can't wait to start the swap :biggrin:
Fill the trans from the top detent plug in the gate assy once the trans is installed, axles in. Should be 2 quarts. The side fill plug is not accessible with the trans in the car & the side mount installed, in case we didn't already discuss this...
Never, ever went anywhere near reverse going 5th-6th on hard shifts (that's over 130+) with no rev limit, shifts around 7500 :)
We did not but I always appreciate the advice sir! I was considering making a flip switch on the dash with a sunroof momentary switch hooked up to a 10 second relay that would open up the reverse gate. However once I hooked it all up with the detents in place as shown above, it's WAAAY farther over then I thought.
Great tip on filling through that detent, would not have thought of that. I was just thinking yesterday how i was going to fill it from that top drain plug. I bought the 4L  Volvo jug as it was $46 only, $10 more then two 1L jugs of the stuff. This should allow for a change out down the line and or any small leaks I don't catch in time.
Things still to do are count up all the parts one last time and Shave the webbing on the side.
Question as well: Do I need any seals on the passenger side apart from what comes in the Collar sleeve service kit? They all seem to come with 3 and O-ring, a drive shaft seal and an outer seal for the collar sleeve.
The Diagram would lead me to think no.
Edited by apeacock
With the engine/trans/subframe out of the car, filling the trans is easy :wink:
New factoid. Both the first and second service kit I got (31256246) Seem to no longer some with the little bottle of lube. The second kit was fully sealed and it would make me think that the kit no longer comes with it. Reflecting further even the diagram above doesn't show the tube near the service kit where as some older ones do.
wNX7w0Ml.jpg?1
wNX7w0Ml.jpg?1
1161748 I think is the spline lube
Should be just the two seals on the PS - the small one goes inside the diff, the large one goes around the collar, and the o-ring goes in before the collar also. Do the seals before the collar, of course.
The 3rd seal must be the DS axle seal - that's what the 6843481 is for
10 hours ago, lookforjoe said:
1161746 I think is the spline lube
Such is my luck right now I think I sent that seal back and ordered a new one, but didn't get a refund for it. I have another on the way because I thought I hadn't ordered it yet and the 3481 seal i started with came in the axle kit bag. Time for another call to get that credit back.
  • Similar Content
    • By zman172
      Box #1
      Steering wheel
      Trunk hatch carpeted trim
      Center console
      Box #2
      A/C compressor
      Windshield wiper motor
      Accelerator pedal
      Fuel door lock solenoid
      Navigation Antenna
      Ignition immobilizer
      Ignition switch starter
      Turn signal stalk
      Sensor alarm
      Seat belt restraints (x2)
      Door sill plates (x2)
      Metal radio pocket
      Volvo plastic radio pocket
      Radio
      A/C control unit
      Side view mirror left
      Servotronic fuse relay
      Trunk latch
      Windshield wiper stalk
      Overhead light driver front
      Rear bumper trim (x2)
      Dashboard trim
      Instrument border
      Rear speaker covers
      Driver motor seat controls
      Passenger motor seat controls
      Gear shifter
      Steering wheel column cover
      Center console trim (x2)
      Front cupholders
      Master cylinder
      Box #3
      Side view mirror right
      Fuel pump regulator
      Overhead dome light rear
      Windshield rain sensor
      Tan headrest with long spikes
      Rear armrest with cupholders
      Power steering pump tank
      Right upper brake light
      Right lower brake light
      Armrest for front seats
      Driver window switch box
      Front passenger window switch
      Airbag sensor
      Rear speakers (x2)
      Box #4
      Side airbags (x2)
      Spare tire
      Rear fuse relay box
      Rear third brake light
      Emergency brake with leather
      Rear trunk speaker trim (x2)
      Right rear trunk carpet trim
      Box #5
      All 4 door panels
      Rear bottom single seat
      Single seat leather upper
      Double seat leather upper
      Right front carpet
      Left front carpet
      Drivers front seat
      Passenger front seat
      Rear trunk hatch trim
      Box 6
      Braking systems (x2)
      Glove box
      Emergency brake trim (x2)
      Center console back plate
      Passenger lower dash cover
      Floor door trim (x2)
      Front door handles
      License plate frame
      Seat railing covers
      Box 7
      Instrument cluster 163000
      Radio trim
      Shifter trim
      Rain sensor cover
      Dash radio storage box
      Fuse panel cover
      Gas tank cover
      Front air bag crash sensor
      Rear air bag crash sensors
      Air bag impact sensor
      Headlight switch
      Hazard light switch
      Dashboard airbag
      Ecu
      Box 8:
      Miscellaneous
      On pallet not in box:
      Door pillar vents (x2)
      Torque rod
      Trunk pillar covers (x2)
      Left side skirt cover
      Right side skirt cover
      Trunk trim no cut out
      Dashboard
    • By lowbudgetracing
    • By andyb5
    • By cryptophilosopher
    • By cruzvolvo
      T-5R Wagon (1995), black, automatic transmission, mostly original with a few moderate suspension upgrades. Approximately 175k, with careful and regular service. This was a California car for most of its life, and is (from best estimates) one of fewer than 100 still on the road in the U.S. It comes with: IPD 3" cat-back exhaust; 4 steelies with snow tires mounted; trailer hitch; original parts no longer installed; and your choice of body panels and parts from a 1995 black 850 NA wagon (parts car). I am a motivated seller and will take $3,000, for the next two weeks. Contact me and I'll answer all questions, to the best of my knowledge, and send any additional pictures that you may want. The car can be seen in Delaware, near I-95.
