rusheR
Project 95
Looks awesome Taras!!  The new tailgate and brake lights are a nice update
Well played Sir. Project is coming out great , and that interior job is top notch :biggrin:
Thanks man! Should look even better all done.
Found a guy making short centercaps replicas for Epsilons. Ordered those. Also I might be trading my 5.5" barrels for 7" ones
85B55707-3673-4C7F-B44E-43507F0523E7_zps
Not much happened since October, the car was running great but rear driver side caliper seized, for the second time,  in February which I decided to replace together with hard line that I successfully stripped the fitting on
FCA24B84-3F1F-4FAA-9B61-DB656DF78D73_zps
And now the exciting part - finally started '93 front end swap last week. I've been collecting all the parts for a while now and dropped 'em off at paintshop last Monday. So,naturally, 93 front bumper and skinny headlight moldings, also my original hood, v70 sideskirts, clean rear bumper and spoiler.
In the meantime I did install the bigass 93 headlights and new corner lights from Korea.
I got headlight housings from Junkyard and used new glass from eBay seller in Lithuania. While I had lights apart I reinstalled inner wiring from newer light and epoxied a plug on the back of the housing. On the 93 lights wiring goes straight to the bulb through the twist on cover.
6671015C-983A-471B-9BE0-70DCBDEEE116_zps
Then drilled a hole and epoxied a little wedge bulb in the side of the reflector to use as a city lights. Always liked that look on VWs
Smoked_E-codes_install_on_MK3_Jetta_VR6_
I did wire my low beam to that and highs as low beam
C0683BBC-FD42-484C-9494-F683041C69D0_zps
D068C36C-047F-44B3-BCFA-74CB890116B4_zps
Did some weight reduction- junked headlight wiper motors then relocated the horns( so much room for activities on NA cars), trimmed the brackets and painted whole rad support. Decided to move DTC box under the fender to clean up underhood a bit, did that and wired repeaters while there. I will be ditching all AC system and tucking and just cleaning engine bay next. Much easier on non turbo cars
Just waiting now for body panels to put it all back together
66FDFFDB-7C24-45A9-B473-A33D64CECDF2_zps
And my two on the cold morning
FE1E9706-C7B5-4CCA-9764-C10E3FEEEB1A_zps
  • Upvote 4
Looking good!
I've seen a 93 850 wagon driving around once, had to do a double take.
The big lights look cool on 850s.
thought the first 855 was 94?
a few 93 850 wagons were made and brought over here
3 hours ago, quiksilver said:
Looking good!
Thanks. I would kill for 93 rear wagon bumper
Received some NOS Bosch Pilot fogs. Really wanted to find Volvo OEM Bosch lights, but those few I've seen on eBay went for over $300 :blink:
55C0B96F-3D53-4F58-8450-E33C0D6F2A41_zps
These have Bosch logo on covers. I just might put Volvo decals on those later myself
Still not sure where I want to mount those, thoughts?
221EE241-6C0D-48CC-B8B6-AB71E030D7C1_zps
44 minutes ago, Kevin. said:
top right pic
do you have the 93 fogs in there yet?
No fogs yet
As previously said there are some 1993 850 estates. They are "rare" as they were prouced only for a limited amout of time before the 94- model year began. According to Volvo production started in february 1993 which gives a timefrime of around 4 months. They have all the old design features: 700/900 series inspired switch gear, different dashboard, different A/C, ventilated and filtered ECU box and ofcourse 4 bolt lug pattern.
Front fog lamps for -93 850 with lower front spoiler:
#9134838 (RH) requires anchorage #9134199 and #9134592
#9134837 (LH) requires anchorage #9134198 and #9134591
Reproduction -93 foglamps are available. Unless it has to be an OEM one from Bosch you could buy one for around 75$ + shipping.
Pictures to show the visual differences:
That's news to me.  Just like Greg, I thought we didn't get any prefacelift 850 wagons in the states
Stopped by the bodyshop and everything is right where I left it. I'm going to California for a week and they promised it to be ready by the time I'm back
6733EB9D-6C68-4AEF-BA42-572DA61E329D_zps
  • Upvote 3
