Another Brake Question
6 replies to this topic
#1 Guest_Guest_DouginDenver_*_*
Posted 15 February 2005 - 08:09 PM
I noted in the article on Bay 13 that he called the substance smeared on the pads "pink grease" and perhaps even silicone grease. That lead me to believe it was really grease. Others in my post below said they buy it at Pep Boys etc. Buy what? I am very familiar with anti-squeal compound that comes with most brake pads - which is either blue or red, but I would never describe it as "grease." It turns into a hard rubber substance. Is the pink Volvo stuff the same, or is is really a form of grease?
#2 jross
jross
    Mad Scientist
  • 3,729 posts
Posted 15 February 2005 - 08:17 PM
Having used it on my rears, it really does look to be a think grease. I didn't go back and check.. if noone else beats me to it, I'll post up when I replace one of my calipers.
#3 kenhoeve
kenhoeve
  • 2,617 posts
Posted 15 February 2005 - 08:54 PM
pink volvo stuff is anti-squeal. grease would eventually rinse away. pink stuff stays.
2007 V70R
#4 Bay13
Bay13
  • 6,378 posts
Posted 15 February 2005 - 10:25 PM
Just so everyone knows the brake grease is now white instead of pink.
#5 Mesoam
  • 18,673 posts
Posted 15 February 2005 - 11:31 PM
i use this "brake quiet" stuff, comes in a spray can and works rather well... It sprays out in liquid form then give it a min and becomes sticky like grease but longer lasting...
96 854 R, CLICK ME
The Jeep
#6 MrWinkey
MrWinkey
    Am I drunk? You tell me!
  • 4,759 posts
Posted 16 February 2005 - 12:12 AM
I use a high temp copper anti seize ...if you have a squeal problem use the factory pads with a cut shim in the rear...in the front I use nada
"SMOKE TROUT NOT CRACK"
#7 KLS
KLS
  • 727 posts
Posted 16 February 2005 - 04:08 AM
I've tried the orange paste that turned to rubber, the red spray that got sticky, blue stuff in a little pouch, the silicone brake grease in a tube, very heavy sticky open gear lube, IPD teflon shims...the IPD shims kept the rears quiet the longest. Switching to Mintex pads, shims, & silicone brake grease is quiet now about 99% of the time.
Ken
