Bonus Lane Man
Art's 242 Build thread
Figured since this turned from a simple +T to something bigger, I'll start a thread about it.
Some backstory first.
It's a 1984 242 DL with roughly 200K miles.
Picked it up last year sometime in August from a Turbobricker in Indiana. Pretty much rust free, Arizona car with faded paint job. It wasn't running at that time. Turns out it needed a new fuel pump.
$1100 later it was mine!
It needed some TLC also.
So I bought a polisher and went to town
Then I parked it in the garage for winter and started driving it when all the snow was gone in the Midwest. And that's when the problems started
It left me stranded on my way to work, so I decided it was time to slap a turbo on it.
So the teardown started
RMS was leaking, replaced with new seal and gasket
Cleaned up the trans
Started cleaning the engine, it was dirty as FUCK
Welded oil return to the oil pan
Tapped the oil feed
Painted some bit and pieces
And somewhat assembled
Replaced all the seals, gaskets, etc.
Drilled and tapped for CPS sensor
Power steering bracket with AC deleted
Stage 4 clutch
Old steering rack was leaking, that's why everything was covered in Power Steering fluid
New rack installed
K24 Rebuild kit
Back in!
K24 teaser
Wiring done with new LH2.4 harness
That sums it up for now. Need the turbo balanced, and piece the rest of the parts that should be arriving this week.
Love the progress Art! Look forward to seeing it soon!
Twins. ..kind of. MWC is going RWD.
Damn Art, did all that since the Saturday you couldn't come meet up when I was in WI?
Yes. It's still work in progress and a lot of stuff needs to be done. But it's getting there.
Cool project Art, I can't wait to see this next year at Carlisle!
awesome!
Good shit there. Sti got you bored?
Bored and STI in one sentence?! Blasphemy!
Needed a bigger project something that would challange me a little bit.
  • Similar Content
    • By zman172
      Box #1
      Steering wheel
      Trunk hatch carpeted trim
      Center console
      Box #2
      A/C compressor
      Windshield wiper motor
      Accelerator pedal
      Fuel door lock solenoid
      Navigation Antenna
      Ignition immobilizer
      Ignition switch starter
      Turn signal stalk
      Sensor alarm
      Seat belt restraints (x2)
      Door sill plates (x2)
      Metal radio pocket
      Volvo plastic radio pocket
      Radio
      A/C control unit
      Side view mirror left
      Servotronic fuse relay
      Trunk latch
      Windshield wiper stalk
      Overhead light driver front
      Rear bumper trim (x2)
      Dashboard trim
      Instrument border
      Rear speaker covers
      Driver motor seat controls
      Passenger motor seat controls
      Gear shifter
      Steering wheel column cover
      Center console trim (x2)
      Front cupholders
      Master cylinder
      Box #3
      Side view mirror right
      Fuel pump regulator
      Overhead dome light rear
      Windshield rain sensor
      Tan headrest with long spikes
      Rear armrest with cupholders
      Power steering pump tank
      Right upper brake light
      Right lower brake light
      Armrest for front seats
      Driver window switch box
      Front passenger window switch
      Airbag sensor
      Rear speakers (x2)
      Box #4
      Side airbags (x2)
      Spare tire
      Rear fuse relay box
      Rear third brake light
      Emergency brake with leather
      Rear trunk speaker trim (x2)
      Right rear trunk carpet trim
      Box #5
      All 4 door panels
      Rear bottom single seat
      Single seat leather upper
      Double seat leather upper
      Right front carpet
      Left front carpet
      Drivers front seat
      Passenger front seat
      Rear trunk hatch trim
      Box 6
      Braking systems (x2)
      Glove box
      Emergency brake trim (x2)
      Center console back plate
      Passenger lower dash cover
      Floor door trim (x2)
      Front door handles
      License plate frame
      Seat railing covers
      Box 7
      Instrument cluster 163000
      Radio trim
      Shifter trim
      Rain sensor cover
      Dash radio storage box
      Fuse panel cover
      Gas tank cover
      Front air bag crash sensor
      Rear air bag crash sensors
      Air bag impact sensor
      Headlight switch
      Hazard light switch
      Dashboard airbag
      Ecu
      Box 8:
      Miscellaneous
      On pallet not in box:
      Door pillar vents (x2)
      Torque rod
      Trunk pillar covers (x2)
      Left side skirt cover
      Right side skirt cover
      Trunk trim no cut out
      Dashboard
    • By mynewvolvoexp
    • By lowbudgetracing
    • By JPittVolvo
      So i have been dealing with the oil cooler lines on my 1998 V70 Awd Turbo for a while. Vehicle has 169,000 miles or so on it now and since i have gotten the car i have put two sets of oil cooler lines on it. I have used the OEM lines each time with new seals etc. Well the second set is now leaking again from the connection at the rubber hose to metal clamping as the usually seem to start leaking at. I dont want to have to do a third set of lines or have these ones rebuilt. I was able to get a hold of the NA motor oil cooler block off plate that it uses instead of having oil coolers. Does anyone know if that would cause a big problem if i decided to put that on instead of new lines? The car is daily driven to work and back about 2 miles on local roads. Never take it on the highway etc, we use the wifes newer mini van for that. I am just worried that iuf i do the block off that the oil might be too high a temperature and burn out the turbo etc. Any thoughts would be greatly appreciated?
    • By mynewvolvoexp
      Hello everyone,
