I notice that when I turn on defrosters or anything that puts a heavy load on the alternator the idle dips slightly. I am assuming this is because the current drain takes power away from the ignition coil, thus reducing the power output of the engine.
Or is it that the alternator gets more difficult to turn as there is a larger load on it? I can't see how this is possible though, from an electric motor point of view.
Anyone?
Alternator Drainage And Engine Speed.
Started by Serge, Feb 16 2005 08:00 AM
Posted 16 February 2005 - 08:00 AM
Serge - 95 850 T5
Posted 16 February 2005 - 02:47 PM
The alternator (and builtin voltage regulator) is designed to keep the voltage stable regardless of the load.
The defrosters put a heavy load on the alternator.
If the idle speed goes down, you may want to check the automatic idle speed valve to make sure it is doing its job and keeping the idle constant so the alternator can do its job.
Also, while at idle, check the voltage at the battery and then turn the defroster ON.
Do the same reading at the alternator output and see if there is a difference that may indicate poor connections.
Step childs92 Chevy Suburban and '03 Mini Cooper S
Step childs
Posted 16 February 2005 - 03:27 PM
Basic electromagnetics - the more current a generator has to supply, the harder that generator is to turn (basically the current flowing in the generator's coils opposes the direction of rotation - more current = more opposition)
2006 SEAT Ibiza Cupra TDI
