johnwartjr
Some RN swap questions
I recently acquired a 2nd 97 850R to mess around with.
The car has a pretty significant knock. After talking with a few others, and having a few local friends take a listen, it seems like it's a rod knock. I'm not 110% sure it's a rod knock, but I'd say I'm reasonably sure.
So, I've been walking through the local pull a part yards, trying to find a B5234. So far, not a lot of luck. Granted, I take a bit of a risk when I grab an engine from a pull a part, but that's another story entirely..
I am seeing a fair number of 99 and up cars, and I know these have the 'RN' engine. I watched a video from ARD about the RN, and the work required to fit the RN engine in an 850 looks like its relatively minor stuff that doesn't add a lot of expense. I linked the video below.
The thing I don't understand yet - how do I decide which cars are good candidates to provide a donor engine? The end result needs to be equivalent or better performance to the original B5234 that came in the car. Ideally, I'd like to go a little better. The car has a 16G on it now, and orange injectors. I am not against a bigger turbo, injectors, tune, exhaust, etc - so I'd like to have some room to grow. I don't plan on going crazy, but I'd like to have some head room.
For example, today I looked at a 2001 V70 XC with a turbo engine - which I think is a 2.4? and I also looked at a 2004 V70 which I believe was a 2.5T.
I've been trying to read up on this swap, and haven't found a whole lot of solid information. I don't want to waste anyones time - I've made a significant effort to find this information on my own.
If there are links I need to read, and haven't found, I'd appreciate it if you shared them.
As far as which block to get, it depends on your goals. The 01-Up HPT motors are supposed to be the strongest and better suited for high HP applications, however I went with an 04-up LPT because they are pretty easy to find and tend to be cheaper, higher compression should give it a little more kick in the low end, and should still be good for around 350whp. As a bonus IIRC 04-up come with the upgraded R manifold.
Once you decide what block you want, you can also make a choice to upgrade to the newer accessories (ps pump/reservoir, alternator, ac compressor, a 'cleaner' look) or modify your accessories to work with the RN motor (cheaper, slightly noisier).
Theres tons of other threads on the subject. Here are some to check out:
http://volvospeed.com/vs_forum/topic/154256-rn-motor-install/?page=1
http://volvospeed.com/vs_forum/topic/141812-850-t5m-project-02-hpt-m56-tt-18t/
Some other builds
http://volvospeed.com/vs_forum/topic/151740-my-motor-build-thread/
http://volvospeed.com/vs_forum/topic/161434-1996-850r-more-functional-version/?page=15
http://volvospeed.com/vs_forum/topic/157483-another-rn-20g-my-build-thread/?page=1#entry2198170
http://volvospeed.com/vs_forum/topic/152263-njgbs-1998-v70-awd-project-good-grief/
PCV Stuff:
http://volvospeed.com/vs_forum/topic/157178-new-motor-build-need-some-direction/?page=4
Helpful tutorials
(Oil Sump reseal):
http://www.matthewsvolvosite.com/forums/viewtopic.php?t=31236
Front Cam Seals/timing (pics are down though):
http://volvospeed.com/vs_forum/topic/159754-how-to-replacing-1999-vvt-engine-cam-seals-and-setting-timing/
You also have to figure out what to do with fuel lines, I recommend changing to the 98 FPR setup pictured here:
http://www.matthewsvolvosite.com/forums/viewtopic.php?p=355576#p355576
Using an 05-up fuel rail/fuel Supply Line and running a vacuum line to the tree for the return but heres some more discussion:
http://volvospeed.com/vs_forum/topic/170371-rn-swap-fuel-line-mod-questions/
Youll probably want to upgrade your fuel pump as well, I recommend a DW200 but here's what you can expect:
http://volvospeed.com/vs_forum/topic/50783-walbro-255lph-hp-pump-install/?mode=linear
There are a bunch of threads but that should be a pretty good starting point
If it just has rod knock then I would do a compression and leak down test and if that checks out good, throw some h-beam connecting rods in and go...you'll never have to deal with a bent rod again, I wouldn't even play around with an RN unless it had h-beams. Seriously, if your going to be beating on it/tuning it, that's the number 1 failure in these motors especially with stock turbos. Also I wouldn't run that engine very long with the knock it will spin a bearing and throw a rod real soon. As long as the crank is good you'll be fine with new bearings and h-beams but that's just me...
The logic with the RN was simply that I'm more likely to find a newer engine with lower mileage and therefore find one in better shape.
The current engine has low compression. 125 in 1, 150 in 2-5. My 97 wagon with 130k has about 175 on each cylinder. I don't have the right equipment to do a leakdown test. Not saying I'm against getting it - just think in this case, another engine is a better choice considering my situation. I may be wrong - wouldn't be the first time.
The engine has 236k on it - assuming it's not had the odo gears broken at any point, or a lower/higher mileage cluster swapped in, etc - but the maintenance history I got with the car leads me to believe if it's not 236k, it's dang close. I bought it from a kid who had been doing his own maintenance and I'm not sure how confident I am in his mechanical ability. I'm not sure how much it's been driven with this knock.
I changed the oil, and strained the drain pan through a filter and didn't find any shavings or anything.
With my current situation, I can throw an engine stand in my garage and freshen up an engine, and then do my actual swap in one weekend. Having a disabled car sitting in my driveway long-term while parts go to the machine shop and I rebuild this engine is not a possibility. So, I need it to run so I can pull it in and out of the driveway as I work on things, etc. With my work schedule and life, I don't even know exactly when the swap would go down - it could take months to have a free weekend to really focus on taking an engine out and putting another one in.
Thanks for the links, I'll read them later!
I just did an RN swap but have a question on VVT my engine was out of an 04 and has the vvt on the exhaust- at picknpull I see s70 & S60 cars with the vvt only on the intake, where was the cutoff ? or was it a lpt-na-hpt thing >  I second the use the later accessory bracket - I swapped mine and it is much neater and smaller- I had the whole donor car so it cost me nothing plus get an alternator amp upgrade
Early NA RN cars had VVT in the intake, early turbo RN cars had VVT on the exhaust.
Skloon, this is correct.
