lookforjoe
2012 C30 T5M/Warning!-Fiat content!!
Was wondering if this was coming together before Carlisle.
Did you leave the subframe in place when you removed the transmission?
I did. Pain in the neck coming out, but going back in, I removed the heater hose of the back of the motor & rotated the transaxle so the diff pointed straight up, then rotated it around to align. Definite PITA on a jack with wood chocks strategically placed while jacking to prevent it falling off..
Dropped the turbo today.
7652D579-D64F-488A-8FAD-D665FC1A9D92_zps
CB6B4623-073B-440B-9F8D-E1F04187AEA5_zps
Turbosmart dual port CBV base orings suck, emailed Don about this
D6616FAD-0CAF-4AC2-B9A1-6BA6035A4BF4_zps
K16 going in. Added a blanket to the housing, and also a SS bung to feed my dual boost gauge
878E7472-F589-43F8-9B65-CB648A99F1AE_zps
6ABB3E13-A01E-4980-A243-23E38321B028_zps
RS oil cooler in
F9FC8102-1122-4F8D-9564-3D0282084914_zps
Trans back in
191C64CB-096D-4C97-A74E-7EFC88B43534_zps
Hopefully wrap it up tomorrow afternoon.
In Fiat related news, the heater valve went this morning. Replaced it with one of the metal/plastic style 700 valves.
3E1FE72E-C189-4E3C-B23B-B42728ED0D22_zps
Axles are re-booted & re greased & installed. This is the correct EMPI 86-2411D  - replacement inner boot  - about 1/2 the price of the Volvo boxed CKN boot (31256019, inner; 31256018 inner & outer kit).
684CF950-FB5D-40AC-AF97-2E2AA12024F3_zps
Couldn't get the clutch hard line to seal in the air vent tube with out the shock load limiter in place, so I drill out the hub to match the normal flow ID. With the load limiter & original line seal, the line seals properly in the vent tube.
ECA97FE9-5E54-4219-A6A5-8CD89302ECDE_zps
Refilled the trans & started putting back all the odds & ends.  Modified the heat shield to allow install of the EBP line - 2nd shot's the charm ;)
BB01FE01-3728-469F-9EBD-6569810817A6_zps
Hopefully wrap it up tomorrow: install injectors, water trap for EBP line, coolant hoses, IC hoses, battery tray, etc.
Bunch of fiddly bits today - had to redo the IC/TB hose - with the deeper Porsche TB the hose is pushed into the AC pressure switch
7ABAA46D-26C6-4185-8993-F8364BADFF65_zps
Larger 550cc  injectors for the K16 going in
B8EA0CA0-D17F-4835-A51D-E64FD0E18AD8_zps
fitting the PITA upper IC piping & hose
9129188B-AF78-4082-8A54-B895CD497398_zps
Turns out the later air vent pipe only needs the shuttle & rubber block to seal. With the extra ones from the old air vent pipe, the line blew out when I pumped the clutch.
6C043535-1032-4EC5-8051-0AFE9F4A1A25_zps
Blue piece is the shuttle that I drilled out (after taking this pic) to match normal flow orifice
443AD46E-496C-4DBC-831F-758320FB9D2D_zps
Removed the two extra seals, and it's all good. Got the Mrs. to help bleed it, and then put everything else back together - new rad hoses, overflow hoses, battery, air box, etc. I swapped out all the regular hose clamps on the DO88 kit for Oetiker clamps.
All back together & running. Now I have to get used to the heavier clutch again :) Exhaust blanket is making quite a stink also. Hopefully that will settle down soon.
Hello Neu- not sure I'll be bringing the C30. The plan was to have the body painted on the Fiat - and bring that :) not sure that will happen before Carlisle, so it may be the C30!
Nice work (as always) Hussein! You made short work of the K16/SMF swap.
Can you explain more about what you ended up doing for the IC/TB hose?  Matt put the Porsche 70mm TB on his car and the do88 IC/TB hose hits the AC switch. It's a 1 piece silicone hose. He spent a long time fighting with that hose to get it aligned and secured in place but due to the rubbing it's not a permanent solution.
I had to sleeve the Elevate hose with a section of another hose - you can see it near the top. I added that AFTER I found the rubbing through (visible at the elbow) - but I think it rides up from the motion of the engine. The reason mine is two-part is due to the larger Bell IC I/O - I bought a silicone step 90º to transition from the Elevate to the IC. I was going to leave it at that, until I found the damage to the hose above.
With the new hose, I added a section of addtional hose around the elbow secured with a industrial tie wrap, so the pressure switch rubs that instead of the hose. There is no way to avoid contact with the Porsche TB offset that I can figure out yet. Perhaps cutting back the top of the 45º so that the hose isn't pushed forward will work - I didn't have time to play with it further yesterday as I absolutely had to get the car back together & running.
Pretty sure I will be spending more time on it - I lost the section of 2.75" IC piping & intended to use as the bridge, and had to use a section of 3", which adds to the problem by swelling the two silicone couplers in already tight areas. The lower one is now almost touching the lower rad hose. Can't figure out what I did with all my 2.75" IC piping from the early XR IC setup - I have plenty of 3" & larger section :( I'll have to buy a piece. The more I look at it, the more I'm sure cutting back the top 45º where it attaches to the TB will do the job - that may not work with the DO88 / Elevate hoses, unless they have enough 'stretch' - Mine I can adjust overall length to compensate as needed.
Thanks for the explanation.   Hopefully Matt will chime in here but last we discussed it he was contemplating buying a new IC/TB setup from Sico Developments in the UK https://www.sico-developments.co.uk/collections/2009-2011-mk2-focus-rs/products/focus-rs-mk2-70mm-cold-side-boost-pipe?variant=27924274833.  It appears to be very similar to the piece you made.
The do88 hose is one piece of silicone from IC to TB, so it is kind of difficult to install.  However, the all silicone construction makes it easier to flex around things.  The multi-piece setup from Sico looks like it has a kink in the aluminum pipe that should clear the AC hose, and comes with a larger elbow for the bigger TB inlet.
Sounds like that maybe the way to go. Here's a detail shot of the sleeve around the new pipe
Looking down
4974BBF5-806D-44C2-9C2E-213C649B530A_zps
Looking forward from the motor side
9FE5D145-647A-4AEC-A123-DBC36507299E_zps
Water trap for EBP line to guage
9A78A560-77FC-4EE8-8983-B02CE6B4BC03_zps
Found out that the system was overboosting significantly with the new setup. Shown here is 6th gear, progressive throttle.
Reverted to stock Pierburg TCV, no change.
Revised the IC-TB hose to 2.75" (made a dogleg pipe from mandrel bend pipe, with 3">2.75" 90º coupler off the IC and 2.75" I/O coupler to the TB)
Reinstalled the stock TB instead of the Porsche unit (porsche unit was fine with K04 & Elevate tune)
in place
CDE6AF0C-9EBF-46EC-B136-61470848CCB5_zps
CE633162-3820-4D10-81E1-87541CDEFF64_zps
no more contact with rad shroud or AC pressure switch
A0BA05A0-5891-40CB-9C01-77577779C442_zps
Boost is now rock steady at 21psi IBP, and part throttle surge has all but gone. I can live with this until I get a Hilton tune underway
Forgot I reworked the inlet to snorkel pipe this week. Went through a couple versions before settling on using the stock snorkel cut back to remove the bottle neck
67F19AF3-4B7A-48BD-8A42-C46F9C558859_zps
Made a baffled expansion tank for the X1/9
7C10FF68-CAE3-43DF-B84F-3F3DDF425262_zps
931A0EE9-C546-4999-8B7C-90941872ECD5_zps
2B45CBB2-A1D9-46DD-898B-C20BD2F9CB15_zps
7B669914-E6FB-4F24-897D-262050DC7A22_zps
345E2630-B02F-4E48-B3F1-9832AB8E3937_zps
7D6D7863-8304-4DB1-8702-81BC07EC8DCF_zps
drilled & tapped T/stat hosuing fittings for 3/8NPT vent (10 AN fittings) & 1/2NPT feed (12 AN fittings)
D05BE1AE-2409-4484-BAC3-BFD6BDF3A363_zps
B8882E46-C145-4E44-8FAF-2FB6ABCC28F5_zps
almost done
314B3715-031B-4BC1-926E-FA92767A2612_zps
  • Upvote 2
AN fittings don't work here - hose runs are too short & so connection is too bulky and rigid - not enough give to allow for normal engine movement  - fitting came loose on the feed line after about 5 miles spirited driving. I stopped every couple miles to look it over, so no biggie, but they have to go. Back to my tried and true plumbing fittings (on the vent line) ;)
gonna look like this:
5/8" compression olive is sweated onto 1/2" pipe to replicate typical pipe fitting bulge/ridge.
B0E88B4B-F07D-4888-9006-2A0C9E92CBF2_zps
Current news is that while the Elevate tune delivers in terms of nice power upgrade with the K16 hardware, drivability with the tune sucks ass. Cold start is a pita - car will stall / not start for a couple tries. Stumbles, hesitates, jerky throttle response until warm. Subsequent starts mostly OK, but some uneven behavior. On the road, holding a steady light throttle when crusing for example, gives a 'surge' that is really annoying. Progressive throttle results in boost which will suddenly drop out unless you continue to add more throttle. Boost transitions can be jerky.
Overall, it really makes driving the car annoying. I would NEVER recommend Elevate afer this. He basically said it must be mechanical as software doesn't change. Not going down that road, it's akin to ARD's claims to ppl that the issues developed after using his tunes must be their hardware, not his tuning (talking about setups where the hardware is all known good, new parts, maintained no vac leaks, worn parts, etc., exacerbated by higher power levels).
Paid for a Hilton tune on Friday, so that process is now underway. Very annoyed that I threw money away on the Elevate tune.
I'll be driving the X1/9 to Carlisle, it's all flat black for now, after Carlisle, I'll hopefully have time top strip it back, fix the final imperations/details & prime it properly in prep for top coat in Volvo Passion Red 612
E590C819-E925-4BDF-887C-A1D95BCEC5E5_zps
DFC2FFD5-FB89-40E5-8912-D0E3485FC829_zps
BC483324-21CC-4CC5-8A99-EF34E862C492_zps
C4576F58-02D6-4136-B869-8859B45DCA10_zps
  • Upvote 5
  • Similar Content
    • By hk20000
      My 1997 Volvo 850 wagon has some really tired suspension, and on top of that the car originally came with Nivomat self-leveling system.
      Now I don't really need a self leveling unit I don't carry a lot on a regular basis, and a Nivomat shock costs $270 a pop from rockauto. If I do that I might as well get a set of springs and some high performance shocks to refresh the suspension components and give it a nice drop while we are there. The Nivomat shocks themelves have a really strong rebound and it's part of what props the car up in wagons so equipped. It's supposed to sag less than 1" even when loaded with 300lb of load in the boot. That means if I just replace my dampers the springs alone will not be able to prop the car up, and the rear will sag a lot. In order to remove the Nivomat system from a wagon, a set of non-nivomat coil springs will also be installed. Since it's impossible to buy 1 pair of springs I'm stuck to buying a set of springs. And therefore might as well replace all 4 shock absorbers.
      What kind of options do I have for this wagon? I want to know if there are some Volvo-specific brands I should also look out for.
      From Tire Rack alone there are the following options:
      Eibach Pro springs
      H&R Sport springs
      Koni Sport dampers
      Koni FSD dampers
      Koni FSD dampers and springs set
      Koni STR street struts
      KYB gas-a-shock OEM replacement
      KYB GR-2 / Excel G shock
      Bilstein HD shocks
      Bilstein Touring Class
      If I want heavy duty daily use on rougher paved roads and retain OEM-like comfort but with enhanced cornering and highway stability, which combination would you recommend? Discuss.
