Fuel Pump Test
9 replies to this topic
#1 t5inAZ
t5inAZ
  • 19 posts
Posted 17 February 2005 - 04:46 AM
Okay, so I have yanked the fuel pump out and I was wondering if there is a way to test it to make sure that this is where the problem is?
Also, is there a way to test voltage to the wires that connects to the pump? I tried the pink and black wire (they turn to red and black on the fuel pump side) with the key at position II but I didn’t get anything. I would guess it should be 12 volts.
1997 850 t5
#2 FINN
FINN
    Pretty Boy Racing
  • 7,080 posts
Posted 17 February 2005 - 05:18 AM
You can take the fuel line off right before the filter and then have someone prime the pump by putting the key to pos. III but not starting the car. If the fuel doesnt squirt out then more than likely its the pump.
Were you able to hear the old pump prime before you took it out?
Sorry, didnt know you were the guy from the other post i answered earlier.
Edited by FINN, 17 February 2005 - 05:19 AM.
#3 Bay13
Bay13
  • 6,378 posts
Posted 17 February 2005 - 12:39 PM
best way to test is with the pump in the car and you hook up a fuel pressure gauge.
#4 t5inAZ
t5inAZ
  • 19 posts
Posted 17 February 2005 - 03:27 PM
QUOTE(FINN @ Feb 16 2005, 10:18 PM)
I tried this. There is actually a Schrader valve right before the fuel filter. So assuming that there should be fuel pressure at the fuel rail Schrader valve when key is number two position, I figured that the same should be true a the valve right before the fuel filter (please correct me if I am wrong).
In any case, I had no pressure or fuel at either. This is why I remover the fuel pump.
I was just wondering if I could hook-up 12 volts to the motor and get some kind of reaction from it. Like a hum or something.
I guess my concern is that it may be something between that is causing the problem. Just don’t want to buy a fuel pump if I don’t have too.
1997 850 t5
#5 t5inAZ
t5inAZ
  • 19 posts
Posted 17 February 2005 - 03:42 PM
QUOTE(Bay 13 Admin @ Feb 17 2005, 05:39 AM)
What is the normal fuel pressure psi?
thx
1997 850 t5
#6 DEWFPO
DEWFPO
  • 539 posts
Posted 17 February 2005 - 08:01 PM
Did you check the fuel pump relay?
DEWFPO
#7 t5inAZ
t5inAZ
  • 19 posts
Posted 17 February 2005 - 09:25 PM
QUOTE(DEWFPO @ Feb 17 2005, 01:01 PM)
DEWFPO
Yep. Allready replaced it.
However, I notice that in the parts catalog there are two.
Fuel Pump Relay; Main Fuel System Relay in Engine #3545803
Fuel Pump Relay; Fuel Pump and Fuel Injection Relay#9434225
Anyone know the difference? I replaced the later, aslo know as 103.
1997 850 t5
#8 MrWinkey
MrWinkey
    Am I drunk? You tell me!
  • 4,759 posts
Posted 17 February 2005 - 11:35 PM
I always replace both as I have had trouble with both ....the pump relay is for the pump(in the fuse block) The injection relay controls injector pulse and is under the rad shroud in the front
"SMOKE TROUT NOT CRACK"
#9 Bay13
Bay13
  • 6,378 posts
Posted 18 February 2005 - 12:13 AM
103 is the fuel pump relay.
The schrader valve by the fuel filter should have pressure, just like at the fuel rail. In the trunk the fuel pump has a pink and black connection, you can put 12 volts there and see if you get anything. If the pump is already out then just put 12 volt to it, but not for long, the gas cools the pump motor.
#10 t5inAZ
t5inAZ
  • 19 posts
Posted 18 February 2005 - 04:59 AM
Just wanted to say thanks to everyone who helped me diagnose my car. I bought a new fuel pump today, installed it and old Sherman is running again (the car is green and reminds me of a tank). So happy to have my car back.
Thanks again everyone!
1997 850 t5
