dougy
dougy's 300$ C70
i'll get another one ... but antenna ring tested fine.
so i was quoted 500-600$ by volvo dealer...immobilizer , antenna ring, new keys and software... plus labor...lmao...came home from work and got her running = 0$
Edited by dougy
  • Upvote 2
thanks ... unplug the battery for 1 to 3 minutes...reconnect the battery ... key in door-lock , lock - unlock x 5  ...repeat if it did not work.
  • Upvote 2
You're using used bearings from different engines? I'm guessing you looked at the block/crank bearing codes for each engine and worked backwards from there to find out each bearings 'colour' and then you swapped all the good/correct bearings into this motor? Am I right?
Glad it works this way. I assume that unplugging the battery would be similar to a reset for the learning functions.
You didn't accidentally flip the key 180 degree? :wink:
Congrats having the engine running! Appears to run smooth. You might check the converter at some point if it isn't damaged or clogged because of the oil in the exhaust.
pretty much...i measured them and used the be best out of all.
thanks Johann , let us all criss cross our fingers and toes and hope that is stays/runs that way...lol...unplugging just the the battery did not work , I tried that over and over... i did not flip the key I promise lol...for converter i pored a gallon 100% concentrated degreaser down the DP and let it sit then pored 2 gallons of hot water ,took a HD leaf blower to that DP hole and hit it full blast for 10 minutes twice...seeing 😨 the stuff that came/blew out I am certain it is clean now
Edited by dougy
  • Upvote 4
i got everything working perfectly  ... still have to make new turn stopper for LCA's out of aluminium and take the ABS module apart and re-solderer all points cause i get intermittent lights /codes for it.
  • Upvote 2
my front safety belt release buttons did not function properly, so i replaced them both...and made my own turn stopper ,they are same thickness as OEM but from aluminium so they'll never wear out and turning radius is the same...LCA are tapped and nuts on the other side...overkill, nooou - dougy style...:biggrin:
antena ring was not the problem but I got rid of the headlight wiper holes in the bumpier ...got the trim from s60 with same color code...cut and belt-sanded to shape to fit perfectly and I used blacks adhesive silicone...same as i did on my s60r.
http://forums.swedespeed.com/showthread.php?202438-Headlight-bumper-wiper-holes-plugs
  • Upvote 2
who would have thought a free s60r obx dp does not just bolt right on to C70 ???  ...lol... well now it does :biggrin:
it is time to call Hilton tuning and see what R 2.5 liter 16t  can do...:a-farmboy:
Edited by dougy
  • Upvote 2
i'll take some for you tomorrow...anything specific?
