Help! New 02 Sensor Installed But The Cars Dies
6 replies to this topic
#1 ajusaf
ajusaf
  • 218 posts
Posted 17 February 2005 - 07:50 PM
I installed a new Bosh plug for rear 02 but after it starts the rpm drop under 1k like normal but then starts to stall and the car shuts off. what can be the cause of this? maybe i pluged the connector upside down (connected the wrong way)?
1994 850 T-5 automatic
2004 XC90 2.5T
1965 Mustang Fastback
#2 DEWFPO
DEWFPO
  • 539 posts
Posted 17 February 2005 - 07:57 PM
Check for codes at the DTC. You might also want to unplug that connector, make sure it is clean and plug it back in again tight.
If you find any codes, let us know.
DEWFPO
#3 ajusaf
ajusaf
  • 218 posts
Posted 17 February 2005 - 08:32 PM
QUOTE(DEWFPO @ Feb 17 2005, 07:57 PM)
DEWFPO
find code under A2? is there a right or wrong way of plugging the plug or is it universal either way? I'll run the code but the car had no problems 2 days ago when i started this
Edited by ajusaf, 17 February 2005 - 08:35 PM.
2004 XC90 2.5T
#4 ajusaf
ajusaf
  • 218 posts
Posted 17 February 2005 - 08:46 PM
i got codes 522, 153, 121, 535. going to look at th econnector might not be in right
2004 XC90 2.5T
#5 Bay13
Bay13
  • 6,378 posts
Posted 18 February 2005 - 12:18 AM
http://www.volvospeed.com/Repair/FuelSystemSocketA2.htm
#6 Patrick.
Patrick.
  • 5,707 posts
Posted 18 February 2005 - 12:21 AM
did you figure this one out? seems as though it isn't hooked up correctly to me.
#7 ajusaf
ajusaf
  • 218 posts
Posted 18 February 2005 - 05:46 AM
yes runs fine and no check engine light. I reconnected like 2-3 times to make sure thanks only took me 30 seconds to remove the old 02 sensor after letting it sit for day with 6 applications of PB blaster
2004 XC90 2.5T
