Posted 18 February 2005 - 12:10 PM
Well, I'll know better this weekend regarding complete improvement.
I have an R, so it had Nivomats on the rear. I purchased new OEM wagon springs and shock mounts for the rear and discovered that you need another part when doing this conversion: The spring hold-down plate is a different size. The parts just came in yesterday and I will install them later this afternoon to get a good picture of the improvement. I wish it was better documented that this part was required!
However, before I tackled the rear, I did all the front work and then took it for a drive. Wow, what a difference! One of the main reasons I tackled this job was all the nice clacks and clunks coming from the front end. Of course, the car is dead quiet now, which was worth the cost in my opinion. Not to mention how much better the car feels as a whole. It is firmer, but more controlled and very smooth.
I also found that my rear sway bar was actually sheared! On the driver's side mount, the section with the bolts that fits inside the swing arm was totally sheared off, rendering the rear sway bar about 5% effective.
So...I expect a remarkable difference when I get it up and running this evening. I was wondering why my wifes 97 850 GLT felt like it handled better than my R.
Also, I should note that the struts up front were VERY shot. If you took the shaft and compressed or extended it, it was grabby and inconsistent and very easy to tell that they were worn past their adequate point.
The control arms looked OK, but I decided while I was in there to change them. One of the tie rod ends' boot had exploded, so it was on it's way out definitely. One of the sway bar end links looked to have been replaced and probably could have been reused, but the other was totally worn out.
I won't get the car aligned until Saturday or Monday, so I won't know exactly how well everything works together until then.
Hope this answers your question.
'96 855 R (100k). Bilsteins, 215/45 R-17 P-Zero Neros, ipd sway bars, slotted rotors (front + rear), stainless lines, Ate SuperBlue, new front suspension components, decent head unit
