Was just looking at a 2005 XC70 AWD and was wondering how do you replace the bulbs inside the rear break tail light assembly that runs up the rear of the car?
Rear Light Replacement
Started by
Guest_stevecahill_*
, Feb 19 2005 02:30 AM
#1 Guest_stevecahill_*
Posted 19 February 2005 - 02:30 AM
Posted 19 February 2005 - 04:10 AM
I think it's covered in the owners manual. Bulbs are covered for the duration of the warranty.
#3 Guest_stevecahill_*
Posted 19 February 2005 - 01:09 PM
Found it in the index of the owners manaul on-line @
http://apps.volvocars.us/ownersdocs/2005/2...0/05xc70_00.htm
Replacement of rear turn signal and brake light bulbs
1. Switch off all lights and turn the ignition switch to position 0.
2. Using a screwdriver, carefully pry off the speaker grille.
3. Pull out the red tab in the speaker.
4. Then press on the black pin above the extracted red tab and twist out the speaker.
5. Twist the bulb holder counterclockwise, and withdraw it.
6. Fit a new bulb.
7. Fit the bulb holder in place and twist it clockwise.
8. Refit the speaker and press in the red tab.
9. Press the speaker grille back into position.
Thank you.
Steve
6. Fit a new bulb.
Thank you.
Steve
