grasshopperR
What's the Compression like on Your Turbo 5 Volvo?
Compression
26 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Every time I look up a Volvo compression test, it's always the people with horrible compression (90-125). I was wondering what VS has on their cars. Hopefully better!
Edit: including mileage in a post would be nice
If I remember right 185 is considered new, and 150 is the lower end where it starts to go become concerning. I remember doing it on a 100k engine that went another 100k and I believe at the time I was mostly getting in the mid 150's. Not all gauges read the same - precision varies.
Rule of thumb is that uniformity is more important. That's because unless the car has crazy high mileage, you're not expecting all 5 cylinders to fail simultaneously. and uniformly. So if you see 140-140-140-90-140, you've got a problem, but it isn't the 140's. If you're getting uniform but low numbers, I'd probably get another gauge to confirm.
I did 2 tests so far, one test showed I was in the 155-165 area and one faulty gauge wouldn't show anything above 60 psi. So, I don't know for sure completely.
I was pleasantly surprised by 180-190 across all my cylinders at 115k. Though I think lpts would be on the higher side.
After replacing my cylinder head last summer (worn valve stem seals were leaking oil into the exhaust, no effect on combustion/compression) I tested mine with a rented gauge from Autozone, so I can't speak to the absolute accuracy of the gauge, but all 5 cylinders were between 165 and 170.
I was pretty happy with those numbers - for a motor with ~185k on it at the time to exhibit less than 5% variation across all 5 cylinders seemed pretty good to me.
131k fresh rebuild just over 1k ago 190 across the bar wet
What's the dry test number? Wet test is usually used to diagnosis a problem.
No clue, I only do it wet.
EPIC
  • Similar Content
    • By mynewvolvoexp
      Hello everyone,
    • By cryptophilosopher
    • By greenellie
      Hey all! I'm planning on swapping in 'white' 350cc injectors, a 16T, and a '98 T5 ECU in my 1998 V70 GLT.
      Only issue is, I'm having serious trouble finding a T5 ECU! I need an automatic one...
      I've scoured Ebay and various other sites and they all seem to be non-turbo ECUs. I've found R and T5 upgrades online and they're all relatively expensive (150-200 bucks).
      Any help or advice would be greatly appreciated.
      Thanks,
      -Ellie
