Is there anything special about changing brake lines the starting point right rear left rear and so on. Should I repalce all fluids just flushed out about 6 months ago
Brake Lines
Started by sp5368, Feb 19 2005 06:33 PM
8 replies to this topic
Posted 19 February 2005 - 06:33 PM
Posted 19 February 2005 - 08:51 PM
6 mo's is plenty fresh for fluid...no special way of installing, have some line caps arround so fluid doesn't drip all over the place. However you most of course re-bleed the lines which has a procedure of LF RF LR RR
(i'm pretty sure thats it, some one please correct me if i'm wrong)
Posted 19 February 2005 - 09:07 PM
I am not sure what type of fluid was used it was done at a shop so is it okay to mix a different fluid as long as it is rated dot 3/4 or better
Posted 19 February 2005 - 09:17 PM
was this a dealer? or indy? Dealer would have of course used the right fluid (check your manual DOT 3 + i belive)
Posted 19 February 2005 - 10:22 PM
indy
Posted 19 February 2005 - 11:01 PM
I think you need DOT 4 or better. (Meaning DOT 4 plus as the better) Absolutely NOT DOT 5.
1995 850 GLT
Stage -1
General Competence -2
Stage -1
Posted 20 February 2005 - 06:51 PM
QUOTE(Mesoam @ Feb 19 2005, 03:17 PM)
I believe for 850 is DOT 4(+).
DOT 3 is sillicon base totally different animal. Mix it and you will regret it.
[font=Arial Black] 1996 855NA, EIBACH Pro Line, Bilstein HD, 225/45/16, Just top 120K.
Posted 20 February 2005 - 09:37 PM
checked the manual and it is indeed DOT 4+
Posted 21 February 2005 - 12:27 PM
QUOTE(850 Stylzz @ Feb 19 2005, 05:01 PM)
Nope, definitely not plain old DOT 5. It'll melt your brake system
Edited by White850T5, 21 February 2005 - 12:28 PM.
- Sean
