My Hidz Are In
9 replies to this topic
#1 volvo4lif3
volvo4lif3
  • 1,323 posts
Posted 19 February 2005 - 08:33 PM
My 5400k's are finally in, i love them, i can see so much clearer now! smile.gif many props to adrian for putting up with my constant nagging. Anyways, since the HIDs pull in less voltage, an error comes up on my infocenter saying low wattage, dipped bulbs. Anyone know how to stop this?
05 s60 2.5T
#2 volvo4lif3
volvo4lif3
  • 1,323 posts
Posted 19 February 2005 - 08:37 PM
well i searched myself this time and found this - http://www.xenonvalot.com/xenonfixvolvo.html
If i do this, just the warning wont come on correct? I dont want my info center to be disabled as well (ie.gas mileage,distance2empty,averagespeed) thx guys
05 s60 2.5T
#3 styx0r
styx0r
  • 401 posts
Posted 21 February 2005 - 01:29 AM
Yes, I would say that if you do the mod you won't recieve a warning message, but your info center will still operate properly. It's just changing the sensing of the headlight circut.
1994 850 Turbo Chassis. 151,000 miles. 1995 HPT motor 15,000 miles, M56H transmission/R clutch. 19T, BSR 3in downpipe, 3in electronic exhaust cutout, IPD 2.5in cat-back. EST Intercooler, Samco intercooler hoses, custom intercooler pipe (metal replacement for stock plastic piece), Greddy Type-S BOV, Aquamist 1S 0.7mm @ 12PSI, Upsolute ECU @ 1.4bar (~21psi), Lotek tripple pod, Greddy Boost, Oil Pressure, EGT gauges, Greddy Catch Can, Greddy Turbo timer, Bilstein shocks/struts w/IPD lowering springs, IPD swaybars, OMP strut tower bar, 17in Alba wheels, 320mm front brakes, X-drilled and slotted, EBC greenstuff pads all around, Bridgestone S-03s 225/45/17s. Gemini Carbon Fiber Hood, Jewel headlights/clear corners.
#4 theunderlord
theunderlord
  • PipPipPipPipPipPip
  • 14,738 posts
Posted 21 February 2005 - 01:39 AM
QUOTE(volvo4lif3 @ Feb 19 2005, 12:33 PM)
post pictures of how you wired them, My old HID's did the itiot light, whereas my new ones don't.
#5 SubCrash
SubCrash
  • 202 posts
Posted 21 February 2005 - 03:15 AM
QUOTE('98S70R @ Feb 20 2005, 09:39 PM)
I would like some pictures to. The lights i recived from adrian do not cause a idiot light.
1998 Blk/Blk S70 T5
#6 V Tuning 850
V Tuning 850
    BIG TIME TOOL
  • PipPipPipPip
  • 3,624 posts
Posted 21 February 2005 - 03:17 AM
Pics
#7 Veneficus
Veneficus
    biggie
  • 6,066 posts
Posted 21 February 2005 - 04:15 AM
Thats an intresting way to aproach putting out the idiot light. I think there is a more effective way than that to fix the problem out there. Maybe you could rout a little more power over in that direction or something that will not be perminant.
- Captain John Paul Jones
#8 Serge
Serge
    Level 6 Senior Member
  • 10,667 posts
Posted 21 February 2005 - 05:11 PM
QUOTE(Veneficus @ Feb 20 2005, 10:15 PM)
You can add a dummy load to compensate for the lower current drain. I would use a DMM in series to measure how many amps are drawn with a regular halogen and then with the HIDs. Subtract the two and you will know the amount extra current you need to drain.
Using the formula R = V/I; where R = resistance we want, V = voltage of the circuit (12V), I = current drain.
So given a halogen bulb drew 4.5 amps (55W @ 12V, 55/12 = 4.5834) and we'll say a HID ballast draws 2.9 amps (35W @ 12V, 35/12 = 9.167), the difference is 1.6 amps.
R = 12/1.6 = 7.5ohms. You'll need a large 7.5 ohm resistor, atleast 18 watts.
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...sspagename=WDVW <-- this might suffice.
Serge - 95 850 T5
#9 Jamaica2G
Jamaica2G
  • 508 posts
Posted 21 February 2005 - 05:28 PM
QUOTE(SubCrash @ Feb 20 2005, 09:15 PM)
Don't forget he's got an S80, so it probably has a different electronics setup.
Adrian
1993 940 Turbo Wagon Red - "Red Rover" Sold 143k mi.
1998 S70 T5 Auto Red - "Lety" - SOLD 86.5k mi.
2005 G35 Coupe Red 6MT - "Mei-Ling" - 58k and counting
#10 Veneficus
Veneficus
    biggie
  • 6,066 posts
Posted 21 February 2005 - 05:42 PM
QUOTE(LiquidKernel @ Feb 21 2005, 12:11 PM)
Somehow I knew you'd want to answer that question.
