96R
S90 960 PCV install write up
Just installed new PCV into a S90, thought I share some step by step.  I have done this on the 850 but on the S90 it seems more complicated getting the intake manifold out because of the engine orientation.  You should take photos of everything you take apart if this is your first time so you remember how to put it back together.
Also, the PCV parts, I noticed some volvo dealers are selling 1993 960 for less than $40 online. Looking at the diagram it appears to be the same for the S90 at a much lower price. I wished I knew before buying the parts.
1) remove the power steering reservoir will give you more space to reach the left two bolts to take the manifold off.
    the power steering reservoir 3x 12mm bolts are behind the round pulley, there are access holes on the pulley but you also need to take the serpentine belt off.
2) you may need to remove the thermostat housing too. (2 T-40)
3) open the blue cap at the end of the fuel rail, press the valve to lower fuel pressure. Gas will spill out so put a towel there.
4) remove the throttle cable assembly (two pieces) 5x 10mm bolts.
5) now you have room to take the fuel rail aluminum cover off, and gently pull on the fuel injectors to remove the fuel rain completely.  disconnect any cables and vacuum
    hoses that get in the way. take photos so you remember how to put it back together.
6) remove the air filter box cover, remove the air intake snorkel, and the big plastic elbow connecting the throttle body.  Lots of wires and vacuum hoses to disconnect.  take photos before you pull that apart.
7) now begin to remove a bunch of 10mm bolts holding the intake manifold to the block. they're on top, bottom, and one 13mm NUT  at the very bottom that's very difficult to get to by touch only.  Some of those 10mm bolts are hidden, so take a flash light and look! when they are all removed the manifold will move and you can pull it out.
8) Once the intake manifold is out you can see your intake valves, look for any gunk built up on top of the valves and clean gently as necessary.
9) unbolt 10mm from the PCV breather box. along with connecting vacuum hoses.  Check the vacuum tree, it has 6 ports, only one is unused with a cap. My vacuum cap was cracked with holes probably causing a vacuum leak.  Check and replace the vacuum cap and any replace any old vacuum hoses. They're cheap and local autopart store carry them.
10) Most difficult was getting some of those 10mm bolts off the manifold, and that 13mm nut way at the bottom. There are also some space issues moving everything out of the way to get to the PCV.  Give yourself a good 5 hours because those 10mm and the 13mm can ruin your day.
  • Similar Content
    • By zman172
      Box #1
      Steering wheel
      Trunk hatch carpeted trim
      Center console
      Box #2
      A/C compressor
      Windshield wiper motor
      Accelerator pedal
      Fuel door lock solenoid
      Navigation Antenna
      Ignition immobilizer
      Ignition switch starter
      Turn signal stalk
      Sensor alarm
      Seat belt restraints (x2)
      Door sill plates (x2)
      Metal radio pocket
      Volvo plastic radio pocket
      Radio
      A/C control unit
      Side view mirror left
      Servotronic fuse relay
      Trunk latch
      Windshield wiper stalk
      Overhead light driver front
      Rear bumper trim (x2)
      Dashboard trim
      Instrument border
      Rear speaker covers
      Driver motor seat controls
      Passenger motor seat controls
      Gear shifter
      Steering wheel column cover
      Center console trim (x2)
      Front cupholders
      Master cylinder
      Box #3
      Side view mirror right
      Fuel pump regulator
      Overhead dome light rear
      Windshield rain sensor
      Tan headrest with long spikes
      Rear armrest with cupholders
      Power steering pump tank
      Right upper brake light
      Right lower brake light
      Armrest for front seats
      Driver window switch box
      Front passenger window switch
      Airbag sensor
      Rear speakers (x2)
      Box #4
      Side airbags (x2)
      Spare tire
      Rear fuse relay box
      Rear third brake light
      Emergency brake with leather
      Rear trunk speaker trim (x2)
      Right rear trunk carpet trim
      Box #5
      All 4 door panels
      Rear bottom single seat
      Single seat leather upper
      Double seat leather upper
      Right front carpet
      Left front carpet
      Drivers front seat
      Passenger front seat
      Rear trunk hatch trim
      Box 6
      Braking systems (x2)
      Glove box
      Emergency brake trim (x2)
      Center console back plate
      Passenger lower dash cover
      Floor door trim (x2)
      Front door handles
      License plate frame
      Seat railing covers
      Box 7
      Instrument cluster 163000
      Radio trim
      Shifter trim
      Rain sensor cover
      Dash radio storage box
      Fuse panel cover
      Gas tank cover
      Front air bag crash sensor
      Rear air bag crash sensors
      Air bag impact sensor
      Headlight switch
      Hazard light switch
      Dashboard airbag
      Ecu
      Box 8:
      Miscellaneous
      On pallet not in box:
      Door pillar vents (x2)
      Torque rod
      Trunk pillar covers (x2)
      Left side skirt cover
      Right side skirt cover
      Trunk trim no cut out
      Dashboard
    • By mynewvolvoexp
    • By lowbudgetracing
    • By mynewvolvoexp
      Hello everyone,
    • By cryptophilosopher
