Air Con/heat Fan Not Working
4 replies to this topic
#1 Spetsnaz Op
Spetsnaz Op
  • 17 posts
Posted 20 February 2005 - 04:32 PM
Ok, on a 1999 V70 XC, the heat/air con stopped blowing. It can still make very hot air and very cold air, but the (fan?) will not push the air out. When I move the fan slider nothing changes, the hot/cold air continues to come out very slowly. When the car was first started, it made an extremely weird noise...kinda like buzzing. I don't know the name of the part or anything. Anyone know what could be wrong and perhaps how much a repair might run(if DIY is not possible)?
NEC FP912SB. MSI K7N2-L, 2x256 Kingston PC2700, Barton 2500+, ATi Radeon 9600 Pro 128, Monsoon Planar Media 9's. SuSE 9.1 Professional Novell DVD (12GB Reiser)/ Win2k Pro Dual Boot.(68GB NTFS)
Quote of 2004 - "FIA will not be happy until all the racers are pedaling f****** rickshaws around on spec cheng-shin tyres." - Desmobob @ europeanforums
2001 S40, 1999 V70 XC, 1995 960 (HOORAY FOR RWD!)
#2 Guest_Guest_MARK_*_*
Posted 20 February 2005 - 05:07 PM
Hi
Have you checked the fuse - I think there are two for the blower motor?
Mark
#3 Spetsnaz Op
Spetsnaz Op
  • 17 posts
Posted 20 February 2005 - 06:04 PM
QUOTE(Guest_MARK_* @ Feb 20 2005, 11:07 AM)
Hi
Mark
Hmmm, nope. I will though! Will it be obvious if it is bad?
#4 Spetsnaz Op
Spetsnaz Op
  • 17 posts
Posted 21 February 2005 - 05:55 PM
Ok I checked the fuseboxen, and nothing was melted or anything like that. What exactly am I looking for? sad.gif
#5 Serge
Serge
    Level 6 Senior Member
  • 10,667 posts
Posted 21 February 2005 - 06:40 PM
QUOTE(Spetsnaz Op @ Feb 21 2005, 11:55 AM)
A blown fuse. Under the fusebox lid there should be labels for the blower/AC/heater which relate to a number on the fusebox. With the car off, pull out the fuses that are under those numbers and look into the fuse.
If it looks like this:
That means it's blown, get a same amperage (or same color rather) replacement.
Serge - 95 850 T5
