Andy's 2000 V70 R
On 3/5/2019 at 4:49 PM, RBoy8 said:
You were sending it so hard you made it go boom cause #nofucksgiven. :cool:
😂 something like that. I’m unclear on the exact moment that I noticed the problem but I think that I continued to drive it for close to 3 weeks afterwards #oops
On 3/5/2019 at 5:15 PM, Commander Riker said:
Will be interested in a overall rebuild cost if you get one.  Good luck with the rebuild.  🙂
Thanks Lucas. It’s been up and running correctly for ~2 months now, and I’ve been really happy with it.  I can text you the details of the swap but it was in the $1500 range. It was $600 for the engine plus I spent about $800 in maintenance parts.
On 3/5/2019 at 6:05 PM, Zappo said:
Yeah, I know that sound.  Sounds like a rock in the valve train; worse as you rev it and quiet as it comes back down to idle.
Salvage what you can for the next build!
That’s exactly the sound!  There really isn’t too much worth saving from this motor, if I built a motor I’ll start with a later RN like the 04 2.3 that’s in the car now.
On 3/6/2019 at 12:52 AM, Andzey said:
I had a thread somewhere here on vs on my donor engine disassembly where conrod bearing was friction welded to the crank, I guess your engine would experience same after some time. The engine was extremely dirty, so I thought clogged crank oil passages caused oil starvation, but wooden oil pan o rings could be responsible as well
I looked up those photos you posted and wow! That is the worst neglect/damage I’ve ever seen to one of these motors, just crazy that someone ignored it for so long.
Got a little free time to get this thing all cleaned up and I gotta say that I still love how this wagon looks. Even ~2 years after buying it, I still find myself spending an embarrassing amount of time admiring the way the paint shifts color and has so many different highlights and tones based on how the light hits it.
  • Like 1
  • Upvote 5
mmmmm mmmmm!
Love it
What center caps ya got?
23 hours ago, B_Dub said:
Your car is stunning, I’d stare at it, too!
Thanks Brandon!
8 hours ago, gmsgltr said:
mmmmm mmmmm!
Love it
Thanks greg! Just plain black center caps for the winter but I have nice BBS ones like this picture for when I put my summers on
Uuuuuuuugh.  Stahp.  You're making me want to fix mine.  It sits with no drivetrain.  😞
Fix it Lucas!
On 4/9/2019 at 1:25 PM, BlackT5 said:
Fix it Lucas!
Fix it Lucas!!
I took advantage of some free time and the nice weather this past weekend to get my big front brake kit installed, and did a little bit of “while I’m in there” work too:
I started the project by stripping and cleaning the front spindles that were originally on this R when I bought it. Since this wagon never saw road salt until I bought it,  the spindles even have some of the factory paint left. None of the other cars I’ve worked on were in this kind of shape!
Spend a while taping off all the “critical” surfaces and they’re ready for paint:
After several coats of high temp primer and silver paint, they’re ready for new FAG hub assemblies to be installed:
Here are the details on the actual brake package. The setup I made uses Brembo 4 piston monoblock calipers from a 997 911 Carerra S. These are the same calipers that were used on the 996 Turbo and have 36/44mm pistons. I have custom adapter brackets that @Timbo Slice machined for me so the calipers can bolt onto the stock front spindle. I’m using Stoptech Sport “309” pads with 330mm x 32mm rotors from an 04-07 S60/V70 R, and custom braided stainless brake lines.  I previously ran Porterfield R4S pads, which were amazing when warm but weren’t as effective when cold. This car is a daily driver so I switched to the Stoptech pads in hopes of adding some low-temp bite without giving up high temp performance  - only time will tell how they compare to the R4S.
I chose Stoptech slotted rotors that will be a substantial upgrade over the factory 302mm x 26mm rotors. The increased swept area and rotor thickness create more area for heat dissipation, which ensures consistent performance when used aggressively.  The larger 330mm rotor weigh about 5 lbs more than the stock 302mm rotor, but the weight penalty is well worth the increased performance.
Two noteworthy benefits of using Stoptech rotors. One, they have coated hats and vents, which will protect them from rusting and keeps everything looking good. Two, all the exposed surfaces are fully machined after casting so the dimensional tolerances and weights are more consistent than other rotors.
I assembled the brakes onto the fresh spindle/hub assembly
and installed them on the car
My car is filthy so I’m not going to post a full car photo :laugh:
The finished product sitting pretty
After driving for a couple years with 302s, it feels great to have a more capable brake setup again
  • Like 1
  • Upvote 6
You keeping the calipers red Andy? Would look sweet matched to your paint.
Those spindles tho! Very nice, and as always very great attention to detail in your work and your write-up. You remind of Big Will in that way. Speaking of, where is he?
The rotors are awesome. My only nag is that they rust on the untreated surface just where the hat and rotor face meet. It’s just a mil or two and probably nobody notices but me, but I do. All in all they’re fantastic though, and great info about their performance and heat shedding ability.
I’ll be interested in your feedback on the pads. I’ve only run Textar semi-metallic, which iPd sells and provided with their old Porsche BBK. I think they’re fantastic. Relatively low dust, no noise except under 4mm pad depth, and great grabbers.
Great job Andy!
They’ll stay red for the time being. If and/or when I refinish them in the future, I’ll look at color matching them but that’s down the road a bit. Good idea though!!
Great job Andy!
Thanks for compliments, and I really appreciate the comparison to Will! He’s been an awesome source of info to this community over the years, so that’s high praise as far as I’m concerned. I’m not sure what he’s up to lately, I haven’t seen anything for him in a while. Good in the info on the rotors. I’ll keep an eye out and if they need it, wire wheel them when I clean my calipers haha.
This setup is already better in cold rainy weather than the solid rotors and R4S pads ever were - I think that’s more the slotted rotors but not sure.
7 hours ago, Commander Riker said:
Damn it looks good to be a gangster
Thanks 😂
  • Similar Content
    • By zman172
      Box #1
      Steering wheel
      Trunk hatch carpeted trim
      Center console
      Box #2
      A/C compressor
      Windshield wiper motor
      Accelerator pedal
      Fuel door lock solenoid
      Navigation Antenna
      Ignition immobilizer
      Ignition switch starter
      Turn signal stalk
      Sensor alarm
      Seat belt restraints (x2)
      Door sill plates (x2)
      Metal radio pocket
      Volvo plastic radio pocket
      Radio
      A/C control unit
      Side view mirror left
      Servotronic fuse relay
      Trunk latch
      Windshield wiper stalk
      Overhead light driver front
      Rear bumper trim (x2)
      Dashboard trim
      Instrument border
      Rear speaker covers
      Driver motor seat controls
      Passenger motor seat controls
      Gear shifter
      Steering wheel column cover
      Center console trim (x2)
      Front cupholders
      Master cylinder
      Box #3
      Side view mirror right
      Fuel pump regulator
      Overhead dome light rear
      Windshield rain sensor
      Tan headrest with long spikes
      Rear armrest with cupholders
      Power steering pump tank
      Right upper brake light
      Right lower brake light
      Armrest for front seats
      Driver window switch box
      Front passenger window switch
      Airbag sensor
      Rear speakers (x2)
      Box #4
      Side airbags (x2)
      Spare tire
      Rear fuse relay box
      Rear third brake light
      Emergency brake with leather
      Rear trunk speaker trim (x2)
      Right rear trunk carpet trim
      Box #5
      All 4 door panels
      Rear bottom single seat
      Single seat leather upper
      Double seat leather upper
      Right front carpet
      Left front carpet
      Drivers front seat
      Passenger front seat
      Rear trunk hatch trim
      Box 6
      Braking systems (x2)
      Glove box
      Emergency brake trim (x2)
      Center console back plate
      Passenger lower dash cover
      Floor door trim (x2)
      Front door handles
      License plate frame
      Seat railing covers
      Box 7
      Instrument cluster 163000
      Radio trim
      Shifter trim
      Rain sensor cover
      Dash radio storage box
      Fuse panel cover
      Gas tank cover
      Front air bag crash sensor
      Rear air bag crash sensors
      Air bag impact sensor
      Headlight switch
      Hazard light switch
      Dashboard airbag
      Ecu
      Box 8:
      Miscellaneous
      On pallet not in box:
      Door pillar vents (x2)
      Torque rod
      Trunk pillar covers (x2)
      Left side skirt cover
      Right side skirt cover
      Trunk trim no cut out
      Dashboard
    • By lowbudgetracing
    • By cryptophilosopher
    • By apeacock
      1999 V70 R - Needed a VS build thread.
      Wagon is a Canadian, originally tested by a rental car company and thankfully for me was rejected. Purchased in 2012 I'm the third owner. Vehicle thad a full service history that would put other anal Volvo owners to shame.
      Mods list run down
      Suspension/Brakes:
      Ohlins Road holding kit Front - Rebuilt by PSI, Performance Shock Inc in California.
      Ohlins Road holding kit Rear
      TME Awd Springs -
      IPD Front 25mm Sway bar
      IPD Rear Bar
      IPD Strut tower brace
      Solid-ish Top engine mount
      Poly Firewall Mount.
      Ceika 330mm large 6pot Front set  -Street Grey Pads
      Porsche 330mm 4pot rear brakes  - Textar Porsche 996 Pads
      Engine/Exhaust:
      Stev0 Tune running 20-24
      BW EFR 7064 Turbo Smart CBV and Dual port wastegate
      Snabb Reverse intercooler piping kit
      Custom Inlet tube mated to 3.5" maf housing
      VR exhaust manifold - Milled Flat to fit T3 Turbo
      Custom DP from Aaron
      Magnaflow rear mufflers
      Do88 intercooler -
      Do88 Rad
      Wheels:
      Borbet LV5 with Bridgestone Potenzas.
      Many thanks to Bmac,Steve, Hussein, and anyone else for answering the endless questions.
      Day 01:
      Car came with its drive shaft pre-removed but included. 12 total wheels and tires, a brand new set of R mats in the volvo box, and a stack of service receipts totaling 26,000 CAD.
      Purchased at 121,000 miles currently 152k on everything.
      March 2014 - Acquired many nice parts through the winter. Met Bmac and got everything installed and then had Steve tune it the same evening. Long day but everything has held together like new since then.
      Snabb kit was a oh yeah! to install, lower pipe need to sit just right to make it all work.
      18" of space was nice but we almost needed more.
      Clamshell was not surprisingly rusted closed.
      ugly ugly welds but it went in perfectly. Did require cutting the old downpipe to clear the angle gear.
      Bens BIG turbo
      Manifold and turbo and exhaust removed.
      Nice new nuts and reused the washers.
      Huge difference in design.
      Sway bars are such a nice improvement on this car
      Reused a front bar from VS, rear can be had new without buying the set (just ask)
      Practice Safe Turboing
      May '14
      Tint and Clear Bra - No surprise it doesn't show up in pictures. The Tint Shop of Rochester NY did a great job. Happy to protect the newly painted front end. (barely visible below)
      'Winning' Only two volvos that weekend so I can't be too happy.
      Summer 2014
      Fitting some poly bushings to rattle my fillings out.
      Sticker from the EST customer bbq day
      Nice little paint job under the hood
      Nothing Special but it does the job
      March 2015
      Prep the Front shocks for service
      Found a guide form what what i can't believe is 10 years ago. Thankfully the pictures are still up http://v70r.com/forums/topic/1667-ohlins-strutspring-install/
      Had to get a offset box wrench but it was really the only tool for the job.
      Rear set still brand new in box. Really excited to get this all in and be on the road
      Not sure if VS works this way but Saving this space for suspension and brakes when they go on.
    • By WarmCanadianWinters
      SO
      Just made an account, hello all
      Tryna do some work on my '98 V70R, the timing belt is from 2006 I think, rear brakes are sitting at 10% (So sayeth the local mechanic).
      Gonna pick up the Power Stop Z23 Performance D/S Rotor and pad kit. Couldn't find any note in the service records of the rear calipers ever being replace, (and the first guy who had this car put nearly 18 grand into it) does it need to be done?
      Also is this timing belt a problem? From what I've read, if it breaks, its a bad time :(
      Thanks all in advance. Pretty green to mechanic-ing
      Oh shitters, I posted it twice. Off to a bad start
