Andy's 2000 V70 R
@andyb5 I just opened the 2002 B5234T3 and it had 147 mm rods, lightened crankshaft, shorter pistons with 21mm pin and without any teflon coating on the skirts
Previously I purchased a 2001 B5234T3 that had old type heavy crank, longer pistons, 139 mm rods, 23 mm wrist pins.
still both are RN with solid valve pushers and slim valve stems. identical heads.
All this was done for hunting an old 81mm block in order to rebore it to my LPT pistons,but they turned out to be perfect 81mm blocks and Im kinda worried to ruin any of them.
I see two budget options to get something close to 9.5:1 or 10:1 either use lpt pistons + minor head lowering or 81mm pistons with chopping off some 1,5-2 mm of the head
Another ghetto version would be using 93.2mm crank + 147 mm rods + stock 81mm hpt pistons being shaved the dish in lathe, maybe only that perimeter around the dish to prevent any interference with head,reaching needed cr
Now I wish finding a late B5254T2 with new style head cast (long thread spark plug) and 93.2mm crank. I have early one from xc90, and it has dual vvt head with short thread spark plug and 90mm crank with 147mm rods.
Hope @Simply Volvo will return to his engine build topic..
Edited by Andzey
15 hours ago, andyb5 said:
When you consider that this motor now has close to 240,000 miles, still has the original oil pan o-rings, and has had several brushes with low oil level/pressure throughout the nearly 90,000 miles of hard driving in 2 different chassis since I purchased the 99 R it came in almost exactly 7 years ago, it is my hypothesis that the level of wear that the engine was able to tolerate before exhibiting a major symptom of imminent failure has finally been reached.
I would start by replacing that.  Did you also check the VVT hub - those rattle like crazy when oil pressure is low...
 Here’s a short clip of the sound - it starts a few seconds into the video, then fades out at the end. Based on the frequency of when it occurs, it sounds to me like it’s coming from the bottom end.
It gets worse as the engine warms up, and increases proportionally with the RPMs as the gas is applied. The video is only at idle but I can get a video of it being revved if that helps.
21 hours ago, B_Dub said:
That’s a drag Andy, I’m sorry. You’ll be better off in the end, that’s a heap of miles on that engine. Here’s to finding a good, low mileage replacement and good luck!
Thanks Brandon!
16 hours ago, Andzey said:
  (shortened)
Sounds like an interesting project. You should start a thread to keep track of all the progress on your engine build! Matt’s motor was being dropped at the machine shop in Connecticut a couple months ago, my guess is it’ll be a bit longer before he has any updates.
Yeah I should’ve done the pan o-rings already but I didn’t have any indications of trouble until this noise started. I have a feeling it’s too late now. I didn’t check the VVT hub yet, that hadn’t occurred to me. @JoshV70 let me know what you think of the video I just posted.
On 12/3/2018 at 10:02 PM, andyb5 said:
As of now, with limited diagnostics performed, I DO NOT believe it to be related to Steve's tune, and would like to remind anyone who thinks otherwise that I ran a tune from Steve for over 25,000 miles on this engine in my old car without any issues.  When you consider that this motor now has close to 240,000 miles, still has the original oil pan o-rings, and has had several brushes with low oil level/pressure throughout the nearly 90,000 miles of hard driving in 2 different chassis since I purchased the 99 R it came in almost exactly 7 years ago, it is my hypothesis that the level of wear that the engine was able to tolerate before exhibiting a major symptom of imminent failure has finally been reached.
Bummer, Andy! Sorry to see :(
And I agree, I don't think it has anything to do with Steve-O's tune.  With the engine getting up there in age and mileage being pushed harder than normal, things are bound to go quicker. It was sorta like when I had to rebuild the head on mine. At over 400K km, valve stem seals were worn and one of the cylinders already had really low compression (especially compared to the rest), so I knew it was bound to go; I just didn't know when, so I continued to push it hard until it gave out. Now that it's rebuilt, it pulls harder than ever with the mods.
Looking forward to seeing where you go next with it, Andy! It'll be running better than ever once you've got it swapped.
  • Upvote 2
On 10/31/2018 at 3:20 PM, andyb5 said:
It has been buffed and ceramic coated 😊 I’m thrilled with how the fresh paint and ceramic coating all turned out!
I’ll take some better (non-iPhone) pictures but heres a quick preview.
The ceramic coating sheds water like it’s glass, and the way it has improved the depth and gloss is hard to capture in a photo, but it’s very noticeable in person.
Sorry I’ve been MIA. Looks good! Definitely worth the investment!
Wow and now I see the horror... good to see you’re in good spirits. Looking forward to the direction you go from here..
Edited by p4eAaLcLe
Well, recent events may lead to an unexpected change of direction for this project.
The engine has developed a ticking sound from the engine.  I first noticed the sound occasionally appearing late last week, and it has begun to become more constant.  I'll do some more investigation/documentation to confirm, but right now I'm 99% sure one of the rod bearings is toast :sad:
I'm now on the hunt for a replacement engine.  As much as I'd like to build a fresh bottom end, budget and time constraints mean that won't happen at this time.  My ideal replacement for this 99 B5234T8 would be a B5234T9 from an 03/04 C70, which is nearly the same engine, with a number of small incremental improvements that should help make it a bit more reliable and develop a bit more power when compared to the older engine.   I did consider a number of other options, but ultimately would like to stick with an 81mm bore block for the increased integrity of the block that offers when compared to an 83mm bore.  The 147mm rods used on the later motors theoretically offer a small improvement in higher-RPM breathing than the 139.5mm rods in the 99 B5234T8 that I have now.
I have a B5234T short block from C70 of that vintage :D Bought from Maciek back then. Don't recall mileage precisely , my recollection is that it was 75K range.
coated bores with grease 3 years ago when I stashed it after parting out the XR - I was going to use it.
On 12/5/2018 at 9:02 AM, Commander Riker said:
Bummer.  But alas, it can be fixed.  How many miles are on the chassis?
Just rolled over 209,000 on the chassis and close to 10,000 miles since the engine install/M66 swap in January.
My thoughts exactly. Thanks for the encouragement Mike, it sucks right now but I know it’ll be better than ever once it’s sorted out.
Thanks Dan, I appreciate the advice you gave me about the ceramic coating. I love seeing the paint all cleaned up, it makes me so happy!
Thanks for the offer Hussein. Right now I’m looking at picking up a complete engine from Re-Volv but if anything changes I’ll let you know!
Drove out to Re-Volv and picked up the replacement engine from Nick yesterday.
It’s a B5234T9 with 127k from an 04 C70 - this is exactly the engine I was looking for!
When it came time to unload the engine from the truck I rented, the shop’s lift couldn’t quite go high enough to allow me to drive the truck out so I had to enlist a couple friends to help :laugh:
Nice score, that was fast! Are you going to pull the head off or anything or just drop it in?
On 12/16/2018 at 5:40 PM, apeacock said:
Nice! Also the shop looks very clean.
Thanks! Yeah it’s pretty clean, the students in charge have done a good job with it this year.
On 12/16/2018 at 8:56 PM, Ol' Dirty Noodle said:
Save for a few stray ball bearings 🙄
Those are long gone at this point :laugh:
I’m going to do a bunch of preventative maintenance but as of now, I wasn’t planning to take the head off it. If the head comes off, the probability of scope creep greatly increases and since this is an unplanned project, I’m trying to keep my time and money spent somewhat reasonable. I can always freshen up the head at a later date.
  • Similar Content
    • By zman172
      Box #1
      Steering wheel
      Trunk hatch carpeted trim
      Center console
      Box #2
      A/C compressor
      Windshield wiper motor
      Accelerator pedal
      Fuel door lock solenoid
      Navigation Antenna
      Ignition immobilizer
      Ignition switch starter
      Turn signal stalk
      Sensor alarm
      Seat belt restraints (x2)
      Door sill plates (x2)
      Metal radio pocket
      Volvo plastic radio pocket
      Radio
      A/C control unit
      Side view mirror left
      Servotronic fuse relay
      Trunk latch
      Windshield wiper stalk
      Overhead light driver front
      Rear bumper trim (x2)
      Dashboard trim
      Instrument border
      Rear speaker covers
      Driver motor seat controls
      Passenger motor seat controls
      Gear shifter
      Steering wheel column cover
      Center console trim (x2)
      Front cupholders
      Master cylinder
      Box #3
      Side view mirror right
      Fuel pump regulator
      Overhead dome light rear
      Windshield rain sensor
      Tan headrest with long spikes
      Rear armrest with cupholders
      Power steering pump tank
      Right upper brake light
      Right lower brake light
      Armrest for front seats
      Driver window switch box
      Front passenger window switch
      Airbag sensor
      Rear speakers (x2)
      Box #4
      Side airbags (x2)
      Spare tire
      Rear fuse relay box
      Rear third brake light
      Emergency brake with leather
      Rear trunk speaker trim (x2)
      Right rear trunk carpet trim
      Box #5
      All 4 door panels
      Rear bottom single seat
      Single seat leather upper
      Double seat leather upper
      Right front carpet
      Left front carpet
      Drivers front seat
      Passenger front seat
      Rear trunk hatch trim
      Box 6
      Braking systems (x2)
      Glove box
      Emergency brake trim (x2)
      Center console back plate
      Passenger lower dash cover
      Floor door trim (x2)
      Front door handles
      License plate frame
      Seat railing covers
      Box 7
      Instrument cluster 163000
      Radio trim
      Shifter trim
      Rain sensor cover
      Dash radio storage box
      Fuse panel cover
      Gas tank cover
      Front air bag crash sensor
      Rear air bag crash sensors
      Air bag impact sensor
      Headlight switch
      Hazard light switch
      Dashboard airbag
      Ecu
      Box 8:
      Miscellaneous
      On pallet not in box:
      Door pillar vents (x2)
      Torque rod
      Trunk pillar covers (x2)
      Left side skirt cover
      Right side skirt cover
      Trunk trim no cut out
      Dashboard
    • By lowbudgetracing
    • By cryptophilosopher
    • By apeacock
      1999 V70 R - Needed a VS build thread.
      Wagon is a Canadian, originally tested by a rental car company and thankfully for me was rejected. Purchased in 2012 I'm the third owner. Vehicle thad a full service history that would put other anal Volvo owners to shame.
      Mods list run down
      Suspension/Brakes:
      Ohlins Road holding kit Front - Rebuilt by PSI, Performance Shock Inc in California.
      Ohlins Road holding kit Rear
      TME Awd Springs -
      IPD Front 25mm Sway bar
      IPD Rear Bar
      IPD Strut tower brace
      Solid-ish Top engine mount
      Poly Firewall Mount.
      Ceika 330mm large 6pot Front set  -Street Grey Pads
      Porsche 330mm 4pot rear brakes  - Textar Porsche 996 Pads
      Engine/Exhaust:
      Stev0 Tune running 20-24
      BW EFR 7064 Turbo Smart CBV and Dual port wastegate
      Snabb Reverse intercooler piping kit
      Custom Inlet tube mated to 3.5" maf housing
      VR exhaust manifold - Milled Flat to fit T3 Turbo
      Custom DP from Aaron
      Magnaflow rear mufflers
      Do88 intercooler -
      Do88 Rad
      Wheels:
      Borbet LV5 with Bridgestone Potenzas.
      Many thanks to Bmac,Steve, Hussein, and anyone else for answering the endless questions.
      Day 01:
      Car came with its drive shaft pre-removed but included. 12 total wheels and tires, a brand new set of R mats in the volvo box, and a stack of service receipts totaling 26,000 CAD.
      Purchased at 121,000 miles currently 152k on everything.
      March 2014 - Acquired many nice parts through the winter. Met Bmac and got everything installed and then had Steve tune it the same evening. Long day but everything has held together like new since then.
      Snabb kit was a oh yeah! to install, lower pipe need to sit just right to make it all work.
      18" of space was nice but we almost needed more.
      Clamshell was not surprisingly rusted closed.
      ugly ugly welds but it went in perfectly. Did require cutting the old downpipe to clear the angle gear.
      Bens BIG turbo
      Manifold and turbo and exhaust removed.
      Nice new nuts and reused the washers.
      Huge difference in design.
      Sway bars are such a nice improvement on this car
      Reused a front bar from VS, rear can be had new without buying the set (just ask)
      Practice Safe Turboing
      May '14
      Tint and Clear Bra - No surprise it doesn't show up in pictures. The Tint Shop of Rochester NY did a great job. Happy to protect the newly painted front end. (barely visible below)
      'Winning' Only two volvos that weekend so I can't be too happy.
      Summer 2014
      Fitting some poly bushings to rattle my fillings out.
      Sticker from the EST customer bbq day
      Nice little paint job under the hood
      Nothing Special but it does the job
      March 2015
      Prep the Front shocks for service
      Found a guide form what what i can't believe is 10 years ago. Thankfully the pictures are still up http://v70r.com/forums/topic/1667-ohlins-strutspring-install/
      Had to get a offset box wrench but it was really the only tool for the job.
      Rear set still brand new in box. Really excited to get this all in and be on the road
      Not sure if VS works this way but Saving this space for suspension and brakes when they go on.
    • By WarmCanadianWinters
      SO
      Just made an account, hello all
      Tryna do some work on my '98 V70R, the timing belt is from 2006 I think, rear brakes are sitting at 10% (So sayeth the local mechanic).
      Gonna pick up the Power Stop Z23 Performance D/S Rotor and pad kit. Couldn't find any note in the service records of the rear calipers ever being replace, (and the first guy who had this car put nearly 18 grand into it) does it need to be done?
      Also is this timing belt a problem? From what I've read, if it breaks, its a bad time :(
      Thanks all in advance. Pretty green to mechanic-ing
      Oh shitters, I posted it twice. Off to a bad start
