Yellow/brownish Mud In The Coolant
12 replies to this topic
#1 gronberg
gronberg
  • 380 posts
Posted 22 February 2005 - 02:42 AM
So I took the car in to the dealer to fix the leaking tank recall and starts with that the break the hoodlatch and then when I checked the coolant it had some kinda of yellow/brownish mud in it. It is like a oil on water and it doesn't desolve with anything. Real slippery substance.
Could this be a reaction between different cooler fluids as I mostly just use 80% water and 20% coolant fluid, can't think of the name right now, yellow bottle with black lable?
Going to flush the system and just put water in the and see.
-94/95 850 Turbo Mix "Fluffy"
#2 Bay13
Bay13
  • 6,378 posts
Posted 22 February 2005 - 02:52 AM
The chocolate milk shake is usually caused by a bad radiator, it's leaking the oil cooling part of it.
#3 gronberg
gronberg
  • 380 posts
Posted 22 February 2005 - 03:17 AM
awesome, so oil is leaking into the coolant, great.
is it going to cause any damage if left like that or is coolant going to start mixing with the oil also?
#4 Bay13
Bay13
  • 6,378 posts
Posted 22 February 2005 - 04:05 AM
Problem is the oil in the coolant, it's getting all over the coolant galleys in the block and reducing the cooling ability of the coolant. The pressure from the oil will more that likely keep the coolant out of the oil but......... why test fate.
#5 Mesoam
  • 18,673 posts
Posted 22 February 2005 - 04:40 AM
did this just all the sudden happen? when was the last time you checked and or changed/flushed your coolant? Mine was a brownish tint before i flushed/filled the first time from the orig owner...
96 854 R, CLICK ME
The Jeep
#6 gronberg
gronberg
  • 380 posts
Posted 22 February 2005 - 02:13 PM
couldn't been more then 1 month seens I checked it and then when I came back from the dealership it looked like they put some different coolant in there and it reacted with the stuff I had in there to make the mud, but the oil in the coolant like right.
Going to flush it and just put water in there and see, but one new/used radioter is probably in the next week or so.
#7 KLS
KLS
  • 727 posts
Posted 22 February 2005 - 09:06 PM
Dishwasher machine detergent cleans oil from engine cooling passages. It is low sudsing. Be sure to flush, flush, and flush again after the cleaning. If you can still smell the scent of the detergent, flush and flush again.
Ken
#8 Mesoam
  • 18,673 posts
Posted 22 February 2005 - 11:05 PM
that is an interesting method... any one else experimented with washing detergent?
96 854 R, CLICK ME
The Jeep
#9 PullMyFinger
PullMyFinger
  • 1,311 posts
Posted 23 February 2005 - 12:32 AM
Just curious - What do you do with the old coolant? I'm pulling my radiator and flushing while I'm at it but I don't know what to do with the old stuff. Its toxic as hell so I'll collect it into a big jug like I do oil. Then what?
Same with the flushing...do you just flush out onto the ground after you've drained as much coolant as possible? That could end up being quite a bit of fluid.
#10 KLS
KLS
  • 727 posts
Posted 24 February 2005 - 08:58 PM
QUOTE
I first saw it done by a Caterpillar mechanic working on an engine with a leaking coolant-cooled oil cooler. It cleaned the cooling passages with no fuss.
Ken
#11 gronberg
gronberg
  • 380 posts
Posted 24 February 2005 - 11:31 PM
KLS, thx
#12 98BRICK
98BRICK
    The Sarge
  • 1,238 posts
Posted 24 February 2005 - 11:58 PM
QUOTE(gronberg @ Feb 21 2005, 08:42 PM)
u using Prestone??? I use something called "Sierra? its a special collant for aluminum engines.....
i too, noticed a brownish liquid in my overflow tank just after flushing the cooling system w/ distilled water and white vinegar...it was fine b4....
i guess its time fer another flush?
98 S70GLT (Silver)
98 V70XC (White)
98 V70R (Saffron)
#13 dancetheman
dancetheman
  • PipPipPipPip
  • 3,355 posts
Posted 25 February 2005 - 09:17 AM
this mud thing happened to me
i had to replace my rad....the dealer said best to do it before it leaks back and mess something else up
daniel (@) volvospeed.com
Present:
2007 Candy White GTI
Previous:
1995 Yellow 854 T5-R
