I have owned this amazing vehicle and as I started researching, I found that these cars make great sleeper cars.   No one wants to be taken by a grocery getter.
I am starting the build and want to get educated on my car. Vehicle: Grey 92 Volvo 240 Wagon. Engine 2.3L (That's all I know currently)  I have began tearing into the engine as it died on me and has been sitting for about a year now.  Shop said timing belt was busted and wanted 1,800.  I decided to do it myself.  I am mechanically inclined but far from a master mechanic.  Anyways, I welcome any and all advice.  I am going for sleeper, and will update any mods done.  I want it running first.  As you can see the belt is not busted and since the shop wouldn't return my car for almost 8 months, (Whole other story). I hope more issues have not raised.  At almost 200,000 but prior to dying it was running very well.  While I am tearing into it I want to fit it with a turbo.
Again I can work on stuff, but tricking out, yeah not my thing so first question would be.....Is this motor able to handle a turbo and will I have to get forged guts?  Can I keep the same fuel rail?  Cam suggestions.......So on.  Thanks and I am new to the group.............
  • Similar Content
    • By Xantor
      Hey guys,
      my Name is Mathias and I am new here!
      I own a 2006 V70 II D5 with 185HP and a spaceball shifter manual.
      I recently found out about BSR's Stage 1+ Software Upgrade that would increase the power drastically.
      They however write on their website that an upgraded clutch and flywheel would need to be installed first to support the power.
      Are there any links to such parts? I couldn't find any, neither with "V70 D5 upgrade clutch"  nor "D5244t4 upgraded clutch". Am I missing something?
      Also, are there any people that modified their D5s? I really like the D5 engine.
      Any help would be appreciated.
      Thanks in advance :)
    • By YouGot5Banged
      Hey so recently have had my TDO4HL-13G start leaking oil and having shaft play it is time for a new turbo so I want to upgrade I have a 2002 Volvo xc70 (Engine: B5244T3) I am heading to a local wrecking yard (Pull N Save) I was wondering from what year and model VOLVO TDO4HL-16T is a straight bolt up to my 2002 volvo xc70
    • By zman172
      Box #1
      Steering wheel
      Trunk hatch carpeted trim
      Center console
      Box #2
      A/C compressor
      Windshield wiper motor
      Accelerator pedal
      Fuel door lock solenoid
      Navigation Antenna
      Ignition immobilizer
      Ignition switch starter
      Turn signal stalk
      Sensor alarm
      Seat belt restraints (x2)
      Door sill plates (x2)
      Metal radio pocket
      Volvo plastic radio pocket
      Radio
      A/C control unit
      Side view mirror left
      Servotronic fuse relay
      Trunk latch
      Windshield wiper stalk
      Overhead light driver front
      Rear bumper trim (x2)
      Dashboard trim
      Instrument border
      Rear speaker covers
      Driver motor seat controls
      Passenger motor seat controls
      Gear shifter
      Steering wheel column cover
      Center console trim (x2)
      Front cupholders
      Master cylinder
      Box #3
      Side view mirror right
      Fuel pump regulator
      Overhead dome light rear
      Windshield rain sensor
      Tan headrest with long spikes
      Rear armrest with cupholders
      Power steering pump tank
      Right upper brake light
      Right lower brake light
      Armrest for front seats
      Driver window switch box
      Front passenger window switch
      Airbag sensor
      Rear speakers (x2)
      Box #4
      Side airbags (x2)
      Spare tire
      Rear fuse relay box
      Rear third brake light
      Emergency brake with leather
      Rear trunk speaker trim (x2)
      Right rear trunk carpet trim
      Box #5
      All 4 door panels
      Rear bottom single seat
      Single seat leather upper
      Double seat leather upper
      Right front carpet
      Left front carpet
      Drivers front seat
      Passenger front seat
      Rear trunk hatch trim
      Box 6
      Braking systems (x2)
      Glove box
      Emergency brake trim (x2)
      Center console back plate
      Passenger lower dash cover
      Floor door trim (x2)
      Front door handles
      License plate frame
      Seat railing covers
      Box 7
      Instrument cluster 163000
      Radio trim
      Shifter trim
      Rain sensor cover
      Dash radio storage box
      Fuse panel cover
      Gas tank cover
      Front air bag crash sensor
      Rear air bag crash sensors
      Air bag impact sensor
      Headlight switch
      Hazard light switch
      Dashboard airbag
      Ecu
      Box 8:
      Miscellaneous
      On pallet not in box:
      Door pillar vents (x2)
      Torque rod
      Trunk pillar covers (x2)
      Left side skirt cover
      Right side skirt cover
      Trunk trim no cut out
      Dashboard
    • By mynewvolvoexp
    • By lowbudgetracing
