littledove
Elbow rubber fuel line from regulator to manifold
I am having troubles finding information on the name of a part that I need to replace.  It's a part of maintenance to my 1995 Volvo 850 Turbo 2.3L.  I want to order it and replace it since its cracked.  If I don't know the name of it I cant order it.  It's under the fuel rail and plugs (elbow rubber ends)into the manifold then the line extends to the throttle body tree near the vacuum lines.  The color of the line is yellow except for the elbow rubber ends. It's about a foot in length.  Does anyone know what the exact name for this so I can order it online?
I had to put electrical tape on the elbow end of the tree so that's what you see.
Here's your part numbers. #11 and #12 (x2) on the diagram. You can buy the parts on www.fcpeuro.com, or tascaparts.
https://www.volvopartswebstore.com/showAssembly.aspx?ukey_assembly=243138&ukey_make=865&ukey_model=11966&modelYear=1996&ukey_category=7072&ukey_driveLine=457&ukey_trimLevel=24645
But for what you spend on that you can buy a decent amount of silicone hose and refresh all vacuum lines, including the solid hose in question.
https://www.ipdusa.com/products/10271/121613-black-silicone-hose-5mm-id
5mm is tight enough to not require hose clamps. I would just buy 8-10 feet of this, good to have some left over in my opinion. It's what I've been running for close to 10 years.
I did the same on my car, just replace it with silicone hose. And if you haven't changed any other vacuum hoses, it's a good idea to check over all of them and replace everything that you can with that silicone hose.
so using silicone hose lines it still needs the OEM elbow fittings though right?  or is there a way  you guys are making the silicone line do it all without kinking up?
Silicone line retains it's shape while being really soft and flexible, just use enough so there's no tension.
gotcha!  good stuff
  • Similar Content
    • By zman172
      Box #1
      Steering wheel
      Trunk hatch carpeted trim
      Center console
      Box #2
      A/C compressor
      Windshield wiper motor
      Accelerator pedal
      Fuel door lock solenoid
      Navigation Antenna
      Ignition immobilizer
      Ignition switch starter
      Turn signal stalk
      Sensor alarm
      Seat belt restraints (x2)
      Door sill plates (x2)
      Metal radio pocket
      Volvo plastic radio pocket
      Radio
      A/C control unit
      Side view mirror left
      Servotronic fuse relay
      Trunk latch
      Windshield wiper stalk
      Overhead light driver front
      Rear bumper trim (x2)
      Dashboard trim
      Instrument border
      Rear speaker covers
      Driver motor seat controls
      Passenger motor seat controls
      Gear shifter
      Steering wheel column cover
      Center console trim (x2)
      Front cupholders
      Master cylinder
      Box #3
      Side view mirror right
      Fuel pump regulator
      Overhead dome light rear
      Windshield rain sensor
      Tan headrest with long spikes
      Rear armrest with cupholders
      Power steering pump tank
      Right upper brake light
      Right lower brake light
      Armrest for front seats
      Driver window switch box
      Front passenger window switch
      Airbag sensor
      Rear speakers (x2)
      Box #4
      Side airbags (x2)
      Spare tire
      Rear fuse relay box
      Rear third brake light
      Emergency brake with leather
      Rear trunk speaker trim (x2)
      Right rear trunk carpet trim
      Box #5
      All 4 door panels
      Rear bottom single seat
      Single seat leather upper
      Double seat leather upper
      Right front carpet
      Left front carpet
      Drivers front seat
      Passenger front seat
      Rear trunk hatch trim
      Box 6
      Braking systems (x2)
      Glove box
      Emergency brake trim (x2)
      Center console back plate
      Passenger lower dash cover
      Floor door trim (x2)
      Front door handles
      License plate frame
      Seat railing covers
      Box 7
      Instrument cluster 163000
      Radio trim
      Shifter trim
      Rain sensor cover
      Dash radio storage box
      Fuse panel cover
      Gas tank cover
      Front air bag crash sensor
      Rear air bag crash sensors
      Air bag impact sensor
      Headlight switch
      Hazard light switch
      Dashboard airbag
      Ecu
      Box 8:
      Miscellaneous
      On pallet not in box:
      Door pillar vents (x2)
      Torque rod
      Trunk pillar covers (x2)
      Left side skirt cover
      Right side skirt cover
      Trunk trim no cut out
      Dashboard
    • By mynewvolvoexp
    • By lowbudgetracing
    • By carson3
      Hi all! I'm looking for a recommendation on what to do with this classic car!
      This bad boy has 106,250 miles on him and has his fair share of nicks, dings, and minor bruises. The right front sidemarker assembly lens is missing and sometimes starts in 3rd gear on extended drives.
      Is there any Volvo enthusiast that would fix this guy up? I'd love for it to go into good hands instead of trading it in! 😀
    • By mynewvolvoexp
      Hello everyone,
