V70-AAAHHHRRR
850/S70 Antenna switch pinouts
Greetings...
A few 850 and 70-series drivers here may remember posts about the Antenna Down Switch for these cars (Volvo p/n 9204656 -- I believe this is specifically for the black switch, not grey, but I don't believe that matters in terms of wiring).  Here's a classic thread that includes a great photo from Mesoam:
My question...  I recently picked up the SWITCH ONLY (black, for the 850 interior) on eBay and am now struggling to determine the pinouts for makeshift cabling.  In my scratchy diagram (attached), I believe Pin #5 is the one that should pass +power to the antenna when the switch is in the ON position.  If so, it would seem that I could splice this power in from the head unit's antenna +power output at Pin #s 1 or 3...
...but what about the embedded light inside the switch?  Would I need to connect another available ground wire at Pin 1 or 3 (which seem to be hardwired together regardless of switch position)?  Or at 2 or 5?  Or... ?  Can't tell this from that image in the 2005 post.
Or might anyone have a wiring diagram detailed enough to show this?
I realize this may be a "play with the wires and figure it out" scenario, but if anyone already has the answer...  Many thanks.
I take it you don't have a pic-n-pull yard near you?  Would save you a lot of hassle if you had the connector for it too.  I'm looking at a blk antenna switch right now; let me go ohm it out..
I have the black switch (out of S90 or 960; not sure which) along with the connector and pig-tails, so I'll mention the wire colors just as an FYI but don't necessarily assume they'll match the 850.
Pins 1 and 6 are un-populated so can ignore those.
The antenna switch is between pins 3 (red/blk) and 4 (red).  Cut your antenna motor control wire that goes from the radio to the antenna motor and run the two wire ends to these pins.  It's just a switch so polarity doesn't matter.
Pins 2 and 5 are for the illumination bulb in the switch.  Most likely the bulb is missing or burned out so..  But if you do want to hook this up, pin5 is black so hook that to a ground wire, and pin2 is brn/blk so splice that into the plus (+) wire from the rheostat; the one that feeds all the other switches.  Polarity doesn't matter here either (unless you replace the bulb with an LED..) but I went with this polarity based on the wire colors.
GDog, you're my hero.  Thank you.  This makes perfect sense.
Pin 1 is populated in the switch that I have, but seems to simply mirror Pin 3.  Pins 2 and 5 makes sense for the bulb;  I get infinite resistance across those because the bulb is present but, as you surmised, is indeed burnt out.  No worries -- the down switch is the important part, not the bulb.  I can replace that later, or never.
My understanding is this part was a bit of a rarity in the 850 -- and mine is further complicated by having an SC-901 head unit from a 70-series in it.  I did install the 1999 grey version of the switch in my C70 Convertible about ten years ago, but sold that car a few years back and evidently failed to keep adequate notes on this minor modification.
Thank goodness for Volvospeed -- and for your time.  Have a great evening.
  • Similar Content
    • By carson3
      Hi all! I'm looking for a recommendation on what to do with this classic car!
      This bad boy has 106,250 miles on him and has his fair share of nicks, dings, and minor bruises. The right front sidemarker assembly lens is missing and sometimes starts in 3rd gear on extended drives.
      Is there any Volvo enthusiast that would fix this guy up? I'd love for it to go into good hands instead of trading it in! 😀
    • By cryptophilosopher
    • By Crossthreaders
      Hey guys. I’m currently about to purchase a 850 Awd in regent red (I think that’s the colour). I’m just wondering what I should look out for if there is anything. I have a 94 T5 so I’m pretty confident, just entirely unsure about the awd system. Also what kind of power figures can I expect to push through this awd system, and what’s the torque split? I’m guessing it’s front bias? Again I have no experience with the awd, only the fwd so any help is appreciated. If anyone could point me in the right direction for aftermarket parts for the awd that would be sweet.
      I’m planning on around 400awhp and daily driven. Yes I know this will be a fairly substantial build but I have nothing but time. Thanks for any help👍🏾
    • By Crossthreaders
      Hi everyone, just joined the forum and hoping I can get some help😁Just purchased my first car, a 94 850 T5 and looking at some different wheels. I had a quick look on here and people are saying that 17x7 and around a 38-40mm offset is the most you’ll be able to fit on an 850. Currently I’m looking at these V50 wheels, the issue is that they are 17x7.5 and have an offset of 52.50. I really quite like them and for $400 for a set of 5 it seems like a good deal. Does anyone know if I can get these to fit/what modifications I’ll have to do? Also, I hear something about late model wheels not fitting because of their hubcentric sizes or something?
      The tires on them are 225/45/17 if that helps, I read 225 is as much tire as you can get on an 850 aswell. Any help is appreciated!
    • By shea_volvo
      So I have a 2000 V70R parts car that I've been gutting, I want to remove the R manifold with the 19T on it and put it on my 94' 855T. I know I can't just slap it on and drive. So my question is what do I need to do to prevent my stock internals motor from throwing a rod. I know I'll need a tune from a place that knows what they're doing, but what other parts if any would I need, someone one told me I'd need a 960 MAF sensor....
      I'm new to this forum so a little info about my 850: Its a stock 2.3L with a 15T turbo, M56L transmission, M4.3 ECU (I have a M4.4 laying around ready for a real tune), and Bosch greens. I used tuner pro to flash a Manual transmission .BIN and edited the constant for the green injectors but i'm not confidant enough to mess with it further as it's my daily driver.
