1997 850 Awd
Crossthreaders
Hey guys. I’m currently about to purchase a 850 Awd in regent red (I think that’s the colour). I’m just wondering what I should look out for if there is anything. I have a 94 T5 so I’m pretty confident, just entirely unsure about the awd system. Also what kind of power figures can I expect to push through this awd system, and what’s the torque split? I’m guessing it’s front bias? Again I have no experience with the awd, only the fwd so any help is appreciated. If anyone could point me in the right direction for aftermarket parts for the awd that would be sweet.
I’m planning on around 400awhp and daily driven. Yes I know this will be a fairly substantial build but I have nothing but time. Thanks for any help👍🏾
Not quite the correct subforum.
This video might explain a few things:
If you look on Youtube, you'll find videos of Hussein's V70XR. IIRC, his last dyno results were over 450AWHP while power was distributed 50/50 front/rear.
Change the fluids, keep your tires within spec (it's very particular about this, must be within 3/32"), and don't do any hard launches. These aren't 911 Turbos, RS3s, or GTRs, but the AWD is relatively tough.
There are no direct aftermarket upgrades for the AWD, only the multi-link rear suspension.
  • 1 month later...
Factory test directions:
"Ensure that the viscous unit remains at room temperature (it was about 45 F outside but best I can do).
A7700344
– Raise the left or right-hand front wheel so that it rotates freely. The other wheels must be in contact with the ground.
– Select neutral.
– Position a torque wrench horizontally as illustrated (basically attach it to the big axle nut and position the wrench so that it's parallel to the ground with the handle pointing in the direction of the front of the car. Read the torque value.
– Turn the torque wrench half a turn (180) clockwise with even torque for 25 seconds.
– The torque must be GREATER than 50 Nm ( 37 lb ft) during the entire turn.
The test method assumes that all the other components included in the system function correctly. If the torque is below 50 Nm (37 lb ft), the viscous coupling is outside the specification and/or damaged."
After confirming your AWD actually functions:
First order of business would be M66 Manual swap, Quaife 14J install, S60R clutch or Spec setup. Higher output fuel pump. Look for a used R/RN motor to build. That power level will need suspension, brakes, etc., upgrade. Over 350AWHP, many other factors come into play.
If you AWD doesn't work, you will likely have a difficult time as that setup is different than mid '98 on, and parts are getting rare, even for the later setup (98-99, '00) and interchangeability is limited. Research that. You can start here for getting to know the parts
  • Similar Content
    • By Oblivious
      Hey Hey,
      First post since I've joined this community, I hope everyone who's reading this is having a good day.
      Here's my issue/cry for help.
      I have a 95 Volvo 850 T5... B5234FT I believe.
      It has a manual transmission and currently around 120K Kms (75K Miles).
      I have the goal of reaching 320/350hp with it, I've been told that yeah it's possible on stock internals... No, it's impossible on stock internals, I don't know...
      What it currently has...
      1 - k&n Air filter was the first mod
      2 - Cat-delete, pretty much a straight tube instead of the catalytic converter (Stock exhaust diameter)
      3 - Revised all the vacuum lines, replaced the radiator since it was leaking, read all the codes (there's still one that's bothering me, since I can't find out what it is)... along with a few other things to make sure it's running properly... Even though there's always something else to fix.
      4 - Got an ebay tune (Don't kill me, it was through a known friend that's been running the same tune for 2 years)
      5 - Suddenly got a good deal on a TD04HL-19T Turbo and I just went for it!
      Installed the damn thing, took me and a friend 12 hours to do it only to realize it doesn't fit the downpipe... No worries, I wanted to upgrade the exhaust anyways.
      6 - This is for the future, I plan on getting a custom exhaust for it, full 3 inch with a sports cat and one muffler, maybe a magnaflow one, still not too sure (open to suggestions)
      7 - After the exhaust I'll be getting it tuned, and for that I got some 480cc injectors to replace the stock orange ones to make sure the thing doesn't run out of fuel or something (Will I need to upgrade the fuel pump as well?)
      8 ---> After installing the turbo, exhaust, injectors and then getting it tuned, I got the goal of getting it up to 320/350hp.. hopefully that's a realistic number...
      I also got these two questions.
      Is it ok to run the 19T on the ebay tune? (tune sets the max boost to 1.2bar(17.4psi) )
      Can I install the injectors and drive around until I get it tuned, or should I just install the injectors once I've gathered enough money for said tune?
      I'm just looking for some guidance on how to do things properly, what I've learned so far is from just reading stuff and such... this car is what I'm using to learn more about the whole car scene, as in, I do everything I can myself, either by watching videos, reading forums, or just grabbing some tools and going for it.
      If I'm doing anything wrong, or if I could be doings things a little bit better, I'd appreciate it if someone managed to point them out, I'm always up for learning new things.. In fact, that's why I joined this...
      But anyways, thanks for the help!
      Have a nice day!
    • By getscandi
      What’s up guys!
      I’m looking to buy a used 240mm 850r/early x70 pressure plate, p/n 272 218
      i have a local shop that is willing to rebuild it for me with beefier diaphragm for more 00mph !
      Cant find locally here im Montreal Canada, so seller must be willing to ship to Montreal! 🙏🏼
      Thank you
      brick on 🧱🌪🇸🇪🦌
    • By lotsofmagnets
      Hey folks,
      Turns out long time lurker 1st time poster. Figured this would be the place to go with a pretty specialised problem as the m4.4 people are here.
      Backstory:
      This is the car I've owned for 12 years now:
      it's not super sexy but it's mine. i have a 164TE, 1800E, 2 C202s and another almost identical 850 except a wagon (very early production 93 model also)
      It started life as a 2.0 20V auto which is not bad if you're prepared for the tacho to visit 3PM frequently but through circumstance I got a B5254S and an M56 from a 2.0 (4.45 final drive) and that made the car actually faster than I anticipated. I drove it like that for 6 years but the engine was tired and blowing more smoke than I was comfortable with. About 3 years ago a valve chipped so I threw another head on and drove it for another year but then the week before I was scheduled to fly out to Australia for 2 months it chipped another valve and so I decided the time had come. I already had a B5244T3 sitting aside and I had already rebuilt a 16T turbo for it so last summer I finally put the car on blocks in the backyard and ripped the engine out. Over the winter I did a stage zero on the B5244T3 and rebuilt the steering rack while I had the subframe out to fix a leak and also got access to a full 98 xc70 so took everything relevant to the M4.4 setup from it and worked it onto the B5244T3. Finally, this May just gone I had everything ready and started putting the car back together and after working slowly on it the past 2 months On Thursday I was finally ready to turn the key for the 1st time. My 1st actual attempt to start it failed and so I did checks and the 1st thing I found was that the injectors only pulse for about a second  before turning off but then when I release the key an injector or 2 fire once. This happens every time I crank. I tried several very short cranks and the car actually fired up! I ran it for about 20 mins and after about 5 mins the lambda light came on but there's no surprise there as there are no o2 sensors yet as there is still no exhaust and the ecu is an auto one so that might also have thrown the code but the car did run for about 20 mins but then i turned it off and so far haven't been able to get it running again.
      This is how the engine bay looks right now:
      So, I think if you've read this far you can probably figure what my question is but I'll ask anyway: Would anyone have an idea what's going on? To recap, when the car is cranking, the injectors fire for maybe a second then stop but then when I stop cranking an injector or 2 may fire again. I've checked power to the ecu and on cranking I get 10.4V which I guess should be enough and I cleaned all of the contacts between the battery and ecu quite well so I don;t think it's an issue of power. Things I'm about to do are check spark to see if I lose spark too or just injectors and then maybe throw a cam sensor and crank sensor in desperation but I'm hoping someone has either encountered this before or has enough of an idea of how the M4.4 system works to help me figure this out. BTW I do have a video of it happening but not sure how to post it here. But yeah, If you have any questions about converting a 2.0 NA auto car to a turbocharged manual then feel free to ask
    • By ksb
      Our much beloved V70R (~110K miles) overheated on a family trip from Oakland to LA this week.  It now sits at a dealer/service station waiting either for us to pour more money into it than we can afford right now, or for you to come and pick it up.  Asking $1500, OBO.  Then you can either fix the thermostat (and possibly head gasket) yourself, or part it out.
      We are the original owners, with complete service records.  Right before this trip, it had a regular service and new front brakes done (but, ugh, not the thermostat).
      Needs to happen by Weds July 8, in Los Angeles. Paypal, Venmo works.
      (1st side facing pic is from this week, dash board & down facing pic from last year.)
    • By silent-circuit
      Existing mods by previous owner:
      Black mesh front grill, LED light bar
      Rear badges blacked out
      Sony touchscreen head unit
      1" drop, Eibach springs, coil-overs
      Elevate front mount intercooler
      Elevate TCV
      EST 3" downpipe
      Magnaflow exhaust with resonator delete
      Pod style high performance air filter
      Hilton Tuning stage 2.5+ tune
      IPD boost gauge
      Just got this a couple days ago, love it already. There are some cosmetic issues to take care of, but it's been well maintained and will make a great platform.
