greenellie
1998 T5 ECU needed!
Hey all! I'm planning on swapping in 'white' 350cc injectors, a 16T, and a '98 T5 ECU in my 1998 V70 GLT.
Only issue is, I'm having serious trouble finding a T5 ECU! I need an automatic one...
I've scoured Ebay and various other sites and they all seem to be non-turbo ECUs. I've found R and T5 upgrades online and they're all relatively expensive (150-200 bucks).
Any help or advice would be greatly appreciated.
Thanks,
-Ellie
Thanks,
-Ellie
You're planning on plug-and-play?!  You know the T5 ecu is mapped for 8.5:1 compression ratio, but your GLT engine is 9.0:1, yes?  You realize while that will give you more boost, knock (and therefore knock induced ignition retard) will come along with it?  :huh:
If that's what you want, how close is your nearest pic-n-pull?  Found this one:
https://www.picknpull.com/vehicle_details.aspx?VIN=YV1LS5347W1425876
The ecu out of that should be what you want; they usually get around $60 unless you go on discount day..  :rolleyes:
Thanks a lot for pointing that out, I had no clue the engines use different compression ratios.
I’ve read posts of people swapping the ecu, turbo, and injectors and running it successfully so I guess I thought it wouldn’t be too bad of an idea.
Maybe I should suck it up and order a tune.
Lots of people use the T5 ECU in their GLTs along with the T5 injectors (white or blue) and a 15g/16t. It seems to be perfectly fine, but of course the best thing to do would be to get a tune. Vast is a great tuner for M4.4.
You should be able to flash your 98 ECU with a T5 bin.
  • Similar Content
    • By 98s70t5mvt
      Bought an 04 c70 b5234t9 to swap
      Have
      Fuel rail with blues $30
      ETM with intake manifold $80
      Auto flex plate $30
      P80
      Sas pump $50
      850 x70 air box $50
      Exhaust manifold $20
      New obx straight flange downpipe $200
      Straight flange housing $55 (no cracks)
      Stock straight flange downpipe with cat $100
      Used td04hl-16t p80 feed ports, little to no shaft play $100
      Low mileage (60k) td04hl-16t p2 style feed , no shaft play $200
      Snail turbo cnc billet wastegate actuator fits straight and angle flange with 1 bar spring brand new valued $140 will sell $80..
      Snail turbo - Td04hl-22t billet 6+6 (td05-18g) wheel extended tip 50mmx71mm with 9 blade turbine. Silicone hd cbv with medium spring 14-18psi
      Has 4 open coolant port with plugs
      Paid $960 was dropped by a friend and seems have some rubbing when spun by hand. Never installed so essentially new Will sell for $400 fp offers rebuild for $275. My loss is your gain. Good for around 320-360whp depending on boost and fuel.. Possible it's fine but had 2 so went with the other...
    • By JPittVolvo
      So i have been dealing with the oil cooler lines on my 1998 V70 Awd Turbo for a while. Vehicle has 169,000 miles or so on it now and since i have gotten the car i have put two sets of oil cooler lines on it. I have used the OEM lines each time with new seals etc. Well the second set is now leaking again from the connection at the rubber hose to metal clamping as the usually seem to start leaking at. I dont want to have to do a third set of lines or have these ones rebuilt. I was able to get a hold of the NA motor oil cooler block off plate that it uses instead of having oil coolers. Does anyone know if that would cause a big problem if i decided to put that on instead of new lines? The car is daily driven to work and back about 2 miles on local roads. Never take it on the highway etc, we use the wifes newer mini van for that. I am just worried that iuf i do the block off that the oil might be too high a temperature and burn out the turbo etc. Any thoughts would be greatly appreciated?
    • By mynewvolvoexp
      Hello everyone,
    • By Bosozoku_Volvo
      I wasnt sure where to post this exactly, but i figure some of you might appreciate this. if you where at ipd last weekend, you might have seen me there!
      I havent started a build thread for it, but i am making a whiteblock swap thread over on TB right now including this project.
      98 t5 block, custom clutch disc for a foxbody t5 trans, motronic 4.4 with COP and wideband lambda, stock trimmed harness, cut 960 pan, custom mounts, toyota alternator. i dont have a solid video of it yet, but i figure this weekend after i get the exhaust on it and the wideband hooked up, ill see about making something.
    • By justanotherhumanoid
      Looking for a TD04HL-16T or TD04HL-18T turbocharger such as the 16T found on 2001-2004 (maybe up to 2005?) Volvo S60 T5 vehicles (for the 16T) or 1999 V70R vehicles (for the 18T).
      Will replace a TD04L-14T which I believe has both coolant ports on the back.
      San Diego area would be ideal, will pay for a rebuilt one shipped if good rep.
