Mooseworks
Mooseworks's T5 swapped BMW (473whp)
Hello guys, been a long time since i got a chance to actually build something volvo related.
Been trying to get back to whiteblocks for 5 years and now finally managed to do that.
What started out as a simple naturally aspirated 5 cylinder swap to my "daily-beater", so i could have a little fun with it, has come to a point, where when i get what i want from the engine, i'm going to swap it to a proper chassy for drag use.
So to make long story a little shorter - here's my beemer 5 years ago:
Meanwhile, it has had several engines, starting with 1.8 83kw stock engine, then 3.0 v8 engine, then again 1.8 engine that ran on 2,5bar of boost, then 2.0 6 cylinder with turbo and finally what the thread is about - whiteblock.
So about the "thing" itself - Regular e36 body, minor mods in the front suspension, mostly everything rebuilt few years ago. So far i've used it for dragracing and also drifting as my own entertainment.
https://www.youtube.com/watch?v=A-tc4J13qEI
https://www.youtube.com/watch?v=YnyuSwJJvnc
Sad part is.. my best ET so far is 13,625@162kmh with my 1.8 engine and 0,9bar of boost, so i haven't succeeded much:unsure:
But this year not should, but WILL be different:wub:
So the engine.. i started the swap with B5254S from my old volvo 440, got to drive it just a little around garage when its life got ended due to oiling error.
That sorted out.. new life on the chassy started b5204T engine i picked up. Looked for specifically 2.0 due to 81mm cylinder, so it would handle more power:laugh:
I will not bother you with every little detail i have made, so i'll let the pics to the job:rolleyes:
(dynosheet is in KW)
https://www.youtube.com/watch?v=0HP5sSOPZgM
https://www.youtube.com/watch?v=ibOjNT2byjA
Engine: B5204T
ECU: Megasquirt 3v3.0
Turbo: Holset HX50
Wastegate: from Audi AAN
Injectors: Siemens deka 825cc
Fuel pump: Walbro 450lph
FPR: Turbosmart
Clutch: tdi pressure plate with bmw disc
Gearbox: Getrag 240
For drag season, on the shelf i have forged rods, crank from D5 engine waiting, and also plan for better clutch and double-VVT(for now just exhaust cam).
Been to dyno 2 times.. first time was just to see if things work like they should and get some idea what kind of power it'll make.. second time went to turn up some boost :ninja:
The result is 340hp/378nm at the wheels so about 360hp/400nm from engine at 20psi of boost
Exhaust manifold is stock at the moment and is also next thing to be replaced... doesn't flow at all :a-farmboy:
So new header incoming and then i'll go for 400whp with yet stock internals :biggrin:
Nice Work!
I really like this exhaust/dump pipe detail:
Meanwhile - new header.
With some help of my tuner and moral support of dyno guy(not in pictures):lol:
Also new bigger cooler
Little test run before another dyno:oogle:
https://www.youtube.com/watch?v=6QQQ5rQ1ZpY
Then new dyno..  result? 425whp@21psi
All good.. exept it wanting to detonate every moment possible, ended things there and headed home. On the way did a pull and blew a headgasket... atleast seemed like that at the beginning.
As the next day we had raceday... i took it apart. Head seemed fine.. block also fine.. headgasket obviously gone but then we noticed 1. cylinder piston seemed kinda tilted like it can't possibly be unless something is wrong.
So it came clear.. one of the rods was bent.
Had a theory about how it pulled water from other cylinder to intake just to push it into this cylinder and having hydro lock.. seemed more likely to bend a rod that way it was bent.
Anyway.. took the engine out, piston out and put in another rod and all back together.
With help of some friends i had it back running by midnight and that was it for the day.
Raceday's goal was to make atleast 12 second pass as my previous best was 13,6s.
Jumping ahead.. i ran 13,1 so didn't reach my goal.. and also broke the engine again.
(As before, the sheet is in KW)
https://www.youtube.com/watch?v=jyn5hQhvBYQ
For now, new engine is almost done :) This weekend is new race so also going to dyno in few days.
Closed deck 81mm block; maxpeeding forged rods; B5234t pistons machined down and polished; D5 93,2mm crank
Gives me 2401cc so should be fun.
On 5/27/2019 at 10:22 AM, Mooseworks said:
D5 93,2mm crank
Do you know, how much does it weights?
I don't, but by hand i can't say it weighs more than regular 90mm crank. It's the same thing as in '04+ 2.5t5 engine.
But as i'm going to take the engine apart again anyway, i'll try to put it on a scale.
That would be extremely useful for European users. the d5 engines are a lot cheaper and more common compared to late whiteblock petrol.
Also it would be so cool use D5 block and custom rods 🙂
In my opinion, there's no need to use D5 block or custom rods. As much as i remember, diesel block isn't much different from petrol block.. those gaps between cylinders are just a bit smaller and more deck height, but that doesn't change anything.
With good tuning and only slight mods those engines can handle about the same power as any other engine - 100hp per cylinder. I mean my completely stock 2 litre had 470hp from engine and broke only because i was too careless about few ecu things.
Things that break engines - too small turbos with too much boost and stock ecu's.
But yeah, i will weigh the crank.. would also be nice if anyone could find part number from T5 93,2mm crank, because i'm pretty sure it's the same thing in d5 🙂
And yeah i know about the engine prices.. I live next to Your country 😄
more dech height of D5 would allow longer rods = less piston velocity and acceleration, longer time at top dead center. This is both good and bad. If you want play with dynamic compression ratio by turning crazy cam angles, shorter rod/ stroke ratio will be more beneficial.
the d5 crank differs alot from the petrol crank...
the layout on the counterweights is different.. theres uneven pairs on the d5, petrol crank has even pairs..
the d5 crank weighs about 1kg more as far as i remember..
and regarding the d5 block - i see alot of advantages using it.. only lot of modification and compromise needs to e counted in..
i will see what it can handle when its finally tuned..
greetz!
So a week has gone by since the first race this year I actually got to attend at and I probably should write something about it.
To get you in the mood - short review of the whole last week:
Monday - BMW ready for dyno.. so full of optimism we got there.. melted the engine of bmw.
Tuesday - In the evening got the bmw back to garage, where, while i was elsewhere trying to get another car running, Rannet and Martin started to take the engine apart.
Wednesday - Me still building the other car, Martin started to put together new engine and as the day went, i joined and together we got the engine running again by the evening.. which meant new chance of dyno. As it still wanted to knock awfully, we kept it safe with low boost and ridiculously little ignition advance. So the car was running but with low power (200+kw).
Thursday - As i got nothing else to do.. tried to replace turbocharger for smaller one.. hoping it would work better with the badly breathing intake manifold and resulting in less detonation... well few runs on road showed that it didn't change ****.
Friday - Last chance to try something... i pumped out the gasoline and poured in ethanol. Result? - No knock whatsoever, got 1,5bar of boost with almost 20 degrees of ign. advance and no sign of knocking.. everything running damn good and lots of power, got the car loaded on the trailer, and trip to "home"(read: dragstrip) could finally begin.
Trip went smoothly and both racedays quite easy also.
Had some loss of power due to very hot weather at the airfield and the fact, that it had rough tune with rather cold and moist weather, so it didn't run quite as good as friday, but still managed to run personal best times.
And if some of you are still with me, you finally get to know what times we ran... Well yes you can be disappointed because i didn't run 9 seconds or not even 10 seconds... and not even 11 seconds:lol: But 12,6 seconds with 194kph topspeed.
So i finally got into 12 seconds.. but with new working gearbox and better rear diff i should be in 11s quite easily.
Overall was a very good race, lots of awesome cars and as always - very nice people together. Super happy that everything worked almost as planned, and trying my best to be faster at next race, which takes place in already two weeks.
Also some eye candy for you... if you are as retarded as i am :D
20 degrees advanced, not retarded 😉
On 7/28/2019 at 2:49 PM, Mooseworks said:
melted the engine
any comments on this one? got lean, fuel starvation?
Yea i don't think i wrote retarded ignition anywhere 😛
Engine melted with heavy detonation which we don't have reason for yet... Not lean, no starvation or anything, only probable cause is volvo's not so good flowing intake manifold. That flows in the mid rev range but my huge turbo comes to life in high rpm, where stock manifold doesn't breathe at all. Everything else we have tried and tested already, as it has been suffering under heavy knock since the beginning. I mean different pistons, heads, comp. ratios, fuel pressure, fuel pump, injectors and so on. But with ethanol no knock whatsoever.. so i don't know. I'm going to make a new intake anyway and try again with gasoline, so then we'll see what happens.
Where do you buy methanol in Estonia? How much does it cost? In Latvia we have extended network of LPG filling stations, im thinking towards building liquid LPG injection for same reason - lowering intake temp and reduce knock risk.
