DwayneCar
AWD swap
New ro the Volvo thing. I've been looking at a s60 2.4t awd automatic parts car. I have an automatic s60 t5 right now. How compatible are the drivelines?
Same trans control module?
Rearend and drive shape bolt up?
Ect.
Thanks for any help, I'll continue to use the search engine and see what I can find
Oh sorry,
Mine is a 06 s60 t5 auto fwd
Donor is an 05 s40 2.4 turbo auto awd
Not a chance that's going to work. The S60 is part of the P2 generation and the S40 is the P1 generation, very few interchangeable parts.
  • Similar Content
    • By jsf1992
      Hi all,
      Only recently has my 2010 S60 DAB radio stopped working.
      When I click on Radio on the central console and go on DAB 1 or DAB 2, nothing comes up on the main screen at all. It just put me back into FM mode after a few seconds.
      Does anyone have any idea how this could be fixed, any help would be much appreciated?
      Many thanks in advance
    • By zman172
      Box #1
      Steering wheel
      Trunk hatch carpeted trim
      Center console
      Box #2
      A/C compressor
      Windshield wiper motor
      Accelerator pedal
      Fuel door lock solenoid
      Navigation Antenna
      Ignition immobilizer
      Ignition switch starter
      Turn signal stalk
      Sensor alarm
      Seat belt restraints (x2)
      Door sill plates (x2)
      Metal radio pocket
      Volvo plastic radio pocket
      Radio
      A/C control unit
      Side view mirror left
      Servotronic fuse relay
      Trunk latch
      Windshield wiper stalk
      Overhead light driver front
      Rear bumper trim (x2)
      Dashboard trim
      Instrument border
      Rear speaker covers
      Driver motor seat controls
      Passenger motor seat controls
      Gear shifter
      Steering wheel column cover
      Center console trim (x2)
      Front cupholders
      Master cylinder
      Box #3
      Side view mirror right
      Fuel pump regulator
      Overhead dome light rear
      Windshield rain sensor
      Tan headrest with long spikes
      Rear armrest with cupholders
      Power steering pump tank
      Right upper brake light
      Right lower brake light
      Armrest for front seats
      Driver window switch box
      Front passenger window switch
      Airbag sensor
      Rear speakers (x2)
      Box #4
      Side airbags (x2)
      Spare tire
      Rear fuse relay box
      Rear third brake light
      Emergency brake with leather
      Rear trunk speaker trim (x2)
      Right rear trunk carpet trim
      Box #5
      All 4 door panels
      Rear bottom single seat
      Single seat leather upper
      Double seat leather upper
      Right front carpet
      Left front carpet
      Drivers front seat
      Passenger front seat
      Rear trunk hatch trim
      Box 6
      Braking systems (x2)
      Glove box
      Emergency brake trim (x2)
      Center console back plate
      Passenger lower dash cover
      Floor door trim (x2)
      Front door handles
      License plate frame
      Seat railing covers
      Box 7
      Instrument cluster 163000
      Radio trim
      Shifter trim
      Rain sensor cover
      Dash radio storage box
      Fuse panel cover
      Gas tank cover
      Front air bag crash sensor
      Rear air bag crash sensors
      Air bag impact sensor
      Headlight switch
      Hazard light switch
      Dashboard airbag
      Ecu
      Box 8:
      Miscellaneous
      On pallet not in box:
      Door pillar vents (x2)
      Torque rod
      Trunk pillar covers (x2)
      Left side skirt cover
      Right side skirt cover
      Trunk trim no cut out
      Dashboard
    • By GrimVenom
      Looking to upgrade my car a little bit, I’m planning on starting with a cold air intake, blow off valve, and possibly a stage 1 tune, any suggestions/products I should be looking for?
    • By silent-circuit
      Existing mods by previous owner:
      Black mesh front grill, LED light bar
      Rear badges blacked out
      Sony touchscreen head unit
      1" drop, Eibach springs, coil-overs
      Elevate front mount intercooler
      Elevate TCV
      EST 3" downpipe
      Magnaflow exhaust with resonator delete
      Pod style high performance air filter
      Hilton Tuning stage 2.5+ tune
      IPD boost gauge
      Just got this a couple days ago, love it already. There are some cosmetic issues to take care of, but it's been well maintained and will make a great platform.
    • By DrCrap
      100k miles
      timing belt already done
      its immaculate, i cannot believe i got so lucky.
      Besides changing all the fluids, what should I pre-emptively take care of?
      I'm already balls deep watching shifting lanes on youtube and moosetech who work on c30's of the same chassis model.
      Some more pix
      i am going to start a youtube series about making this beauty better. thanks to (if you're here by any chance) "Mynameideasweretaken" as well
