icrashcars
1998 V70R, Resto Mod Thread
3 hours ago, gmsgltr said:
what jetex pipes are you using? are they the ones i linked, the 850 ones at 2.5"? I just wish they were larger than 2.5" but I guess it really doesnt matter with a stock frame turbo and 3" leading up to this system
Just the 2 main pipe from this package. I think it was about $300 shipped.
https://www.jetex.co.uk/performance-exhausts/Volvo/V70-(P80)-Turbo-4WD-(96-00)/
Edited by icrashcars
So many parts to put back in. Hoping to get it done by this weekend so I can drive it for a week before making the trip to Carlisle.
Pulled new Parking Brake Lines. The other came out in pieces.
47740719342_ccb19f51bb.jpgUntitled by britt edward, on Flickr
3D Printed a Radio Trim Bezel
47740719162_8f599f8f9f.jpgUntitled by britt edward, on Flickr
Nice work! I'm partial to silver P80 AWD wagons . All you need to really do next is manual swap. Transforms the wagon :D
Thank you. Your P80 has been an inspiration. Im on the lookout for a clean XC bumper. Looks so good on yours.
Manual conversion is definitely happening. Hopefully sooner rather than later.
Rear 330mm setup is massive compared to the old. Can wait to bed them and then try them out.
47788695122_b65cd68290.jpgUntitled by britt edward, on Flickr
  • Upvote 2
love the color
the bbk and manual swap are the best mods you can do (next to a big ol turbo and motor but thats not as easy or cheap hah)
Still have one of my modded XC bumpers (1st version with medium size opening), and modded 960 lip if you're interested. I had it freshly repainted shortly before the car's demise. Center grille has to be made, I think I have two stock grilles for that.IMG_9129.JPG.58669f01292912004f257696113ebc67.JPG
Very interested, but cant right now.
I understand. I have not made any effort to sell it, so keep it in mind if you are interested. If & when you are ready, just get it touch. No worries either way.
Hit 2 major-ish snafus.
Found out my front "Big Red" caliper are the wrong models.
The part number showed correct in a couple of resources and they bolt up to the adapters perfectly. However, they do not fit over 32mm rotor. These are meant for a 28mm rotor. I couldnt find a Volvo 330x28 rotor, so im going to use a set of 320x28 for now.
Porsche Caliper PN: 996.351.426
33967064048_78b4d1c34d.jpgIMG_2437 by britt edward, on Flickr
Second issue is a separated rear inner CV joint. I was putting it into the new hub/ bearing and I think it popped loose. I wanted to replace them anyway, but was hoping to wait a couple weeks. Replacement Axle should be here Wed/ thurs.
Rear
33967829708_fd331b57b1.jpgUntitled by britt edward, on Flickr
You might be able to find Audi discs in that size and slightly bore the holes because guess what rotors B6 guys use with certain calipers... P2R discs. Just a thought
Thanks.
I bought a pair of volvo 330x28mm rears and Im going to have the parking brake hub portion milled down.
Went for a cruise. Car drives amazing, but needs some adjustments and tweaks.
48003895886_1514dd1019_c.jpgVolvo V70R Front by britt edward, on Flickr
48003824848_c5191ccc06_c.jpgVolvo V70R Side by britt edward, on Flickr
Had some major delays getting it back on the road, mostly due to part availability and delivery times.
Last round of work included:
4 new axles and all seals
New wheel bearings all around
Refurbished rear knuckles
Front control arms, inner/ outer tie rods, sway bar endlinks
4 Piston brembos and 330mm rotors on all 4 corners
4 new ABS sensors
Front/ rear diff fluid flush
Coolant flush
Oil change
New Parking brake cables
New Parking Brake shoes (still fighting with these!)
New Headlights
Modified XC Grill
  • Upvote 2
