Failed clutch master cylinder or clutch slave cylinder?
Today on my way home something went wrong with my clutch system. Shifted down from 4th to 3rd and the peddle suddenly went soft, and the clutch wouldn't disengage. Ended up limping it to my parents place which was a task on its own.
I popped the hood when I got there, but cant see any visible fluid around the slave where it meets the trans (internal slave). I've had my dad watch the fluid reservoir as I pumped the peddle and the fluid level doesn't move at all. I cant see any puddles on the ground where it might be leaking.
So my question is: Is it the the master cylinder that's  gone bad, or the slave cylinder? The slave was bought brand new, has about 3,000 miles on it right now. The master was used, unknown mileage.
car is a 1998 V70R with an M58 swap.
Refill the system and try popping the bleeder while someone holds the pedal down or use a power bleeder to ensure you are still getting fluid to bleed out the line. Do this a few times to ensure you have fully bled the line. If all that checks out I would be inclined to believe you have a problem with your master since you do not know the history of that.
I think that's your best bet. It sounds more likely that your master cylinder is the issue since it's used, but the best way to find out will be to try and get fluid at the bleed valve. If you're still getting a good amount of fluid there, it may be the slave.
  • 3 weeks later...
Turns it it was neither. Did a reverse bleed on the system, everything pressurized for a minute while I drove it around the lot, then the clutch started feeling soft again. Popped the hood, and saw some mist spraying out under the battery tray. Pulled it all apart and found this line had been worn down by the shift linkage.
Fortunately an easy enough fix. Thanks for all the help!
61491434_688473148255634_2108393041810161664_n.thumb.jpg.e3ae1cdde05fce663371d426d8171365.jpg
  • Similar Content
    • By Crossthreaders
      Hey guys. I’m currently about to purchase a 850 Awd in regent red (I think that’s the colour). I’m just wondering what I should look out for if there is anything. I have a 94 T5 so I’m pretty confident, just entirely unsure about the awd system. Also what kind of power figures can I expect to push through this awd system, and what’s the torque split? I’m guessing it’s front bias? Again I have no experience with the awd, only the fwd so any help is appreciated. If anyone could point me in the right direction for aftermarket parts for the awd that would be sweet.
      I’m planning on around 400awhp and daily driven. Yes I know this will be a fairly substantial build but I have nothing but time. Thanks for any help👍🏾
    • By ovlov780t
      Here she is. Putting her up for sale. All offers will be considered.
      https://losangeles.craigslist.org/sfv/cto/d/1998-volvo-s70-t5-manual/6705737681.html
    • By Domo
      I'm having trouble with the rear ride height on my 2000v70xc I have changed the nivomats about two years ago it had always been low on the left in the rear so I changed them with the ride height not changing, I've looked and searched lots even swapped the shocks from right to left to see if the ride height changed to the other side but no still low on the left, checked the springs no broken coils. Is it possible that I have a broken or damaged rear spring seat that is completely silent that could cause right height issues? I don't have any clunk sounds from the back. its always lower even when its empty, when we are going camping for example its embarrassing.
    • By Chrisonfire
      For sale is a pair of brand new front and rear IPD lowering springs for P80 Volvos. I originally bought them for my 99 S70, but never installed them and eventually sold the car. Also included is a brand new pair of upper spring seats.
      Looking to get $200 locally - or willing to negotiate a price+shipping if you are not in Western Washington. I understand these are on-sale at IPD right now, so I am negotiable.
      Thanks for looking
    • By FrankenMoose
      First parts off my Frankenmoose part out are the ABM Headlights.  I picked them up from IPD a few years ago, and immediately installed XPEL Film on them. The  access doors for the low beams are missing (removed to let the cooling fins for the LED Bulbs (long gone) breath, and promptly lost). There's a hole in the High beam access door for the Driver's side, for HID Ballasts to feed though (also gone); the Pass side door is lost.  The access doors are easily replaced with factory ones.
      There are standard Sylvania bulbs in both high and low beam locations now. There are amber parking lights installed in the area below the high beam,; they match the turning/running bulbs. All mounting tabs are intact and mounting screws are included.
      Looking to get $200 +shipping for the set.
