hav716559
2005 XC70 Alternator Replacement Help
Hello, does anyone have a write up on how to replace the alternator on a 2005 XC70? Otherwise, does anyone who has replaced it have any tips or tricks? Thank you!
Disconnect battery.
Remove drive belt.
Remove cooling fan.
Remove alternator bolt on drive belt side.
Remove two lower alternator bolts (long)
Loosen bottom two A/C compressor bolts.
Remove battery cable and signal wire.
Slide alternator out in front of intake manifold where cooling fan was.
Install in reverse procedure.
