n8t50
1998 V70 N/A Misfire/Stalling
Hi folks, looking for some help with a misfire/sputter on a 1998 V70 N/A (537xxxkm). Car was throwing some codes for the rear O2 sensor, but wasn't doing anything funny. Coming back from a camping trip, it started to misfire/sputter while cruising at 100km/h in 5th gear. It then started stalling out while at idle. I replaced the rear sensor, and shortly after, it started to throw codes for the front O2 sensor (slow response, and lean mixture), and do the same thing.
It is fine on startup, but sometimes will have little fits of stalling at idle, and sputtering/missing when accelerating/cruising. When it would stall, I used to be able to get it too restart on the first try, but now it usually takes 2-4 cycles of the ignition to get it to catch. Once I give it some gas and take off, it improves a little, and just seems to lack a little power. When at idle, you can also smell the exhaust, which normally is very clean.
Today I replaced the front O2 sensor. The car ran well for 30min, then threw the same codes, and started acting up again. I've tested the PCV and the compression, and both are fine. The spark plugs are new, but the rest of the ignition system (Coils, leads, rotor) are older. I'm thinking this sounds like either an ignition system problem, or a fuel system. I'm not sure how to run the normal relay test, because it it is really intermittent with its sputtering/stalling. (Currently there seems to be about a 50/50 chance of it being fine, or acting up when I take it out) I'm probably going to redo the ignition system, because the car needs it anyways, but am wondering what else this could be.
Thanks guys!
Could be a lot of things, but I'd check fuel pressure first.  You may need to drive around with a fuel pressure gauge hooked up to the fuel rail until you hit this failure mode again, so you can check the pressure when it's happening.  The stock fuel pump is typically good for 140-200K miles so this car is likely on its 2nd one.  Maybe the last one was installed poorly or it's lousy quality?  If you are losing fuel pressure, it could also be the fuel pump relay under the hood (another common failure point).  Again, this is all speculation until you find that the fuel pressure does indeed drop when this happens.
What are your actual codes?
Unplug the MAF (NOT while the car is running) and see if anything changes. That could definitely cause issues like this. It would also make sense after changing the O2 sensor that it was fine for about 30 minutes, then it adapted and starting running poorly again. Check the codes again and post them.
  • Similar Content
    • By lowbudgetracing
    • By JPittVolvo
      So i have been dealing with the oil cooler lines on my 1998 V70 Awd Turbo for a while. Vehicle has 169,000 miles or so on it now and since i have gotten the car i have put two sets of oil cooler lines on it. I have used the OEM lines each time with new seals etc. Well the second set is now leaking again from the connection at the rubber hose to metal clamping as the usually seem to start leaking at. I dont want to have to do a third set of lines or have these ones rebuilt. I was able to get a hold of the NA motor oil cooler block off plate that it uses instead of having oil coolers. Does anyone know if that would cause a big problem if i decided to put that on instead of new lines? The car is daily driven to work and back about 2 miles on local roads. Never take it on the highway etc, we use the wifes newer mini van for that. I am just worried that iuf i do the block off that the oil might be too high a temperature and burn out the turbo etc. Any thoughts would be greatly appreciated?
    • By cryptophilosopher
    • By RobT5M
      Hey guys, Rob here.
      I figured it was time to go ahead and make a thread since this car has been around the community and finally down here in FL for the last 8 years.
      At one point this used to be my daily, now ive moved on to a 2018 S60 and it has become more of a project/fun/love/hate car.
      It's had a lot of work and a lot done to it so I guess a little back tracking is warranted.
      Originally a 1998 s70 2.3 T5 Automatic.
      Around 2010 I added a OBX Exhaust system, 18t, WideBand, ARD blue custom Tune, various other little things.
      Around 2013? it went from a 18t to a K24, Manual swap, and RN swap.  The RN recieved a rebuilt top/bottom using new parts and seals before install as well as the tranny. (Lol Tranny)
      Eariler this year (Feb 2018), I managed to kill the engine coming home from a large volvo meet in Orlando (over 120 volvos so I guess thats large)
      (enter the new daily thanks to winter park volvo (chris is my new bestie))
      Ordered up an 02 2.4LPT engine since there were no 2.3's in stock anywhere, and it sat in my garage with the s70 for close to 8 months...  (Hey at least the detail I got before the meet in Feb lasted 8 months riiiiiggghhhttt?)
      After finally getting tired and life back on track from a number of bad events, I sent the car and engine off to Maitland Importers (enter Alan <3 )
      A week and $2k later, I got 1 s70 back with almost nothing for me to worry about, new control arms, endlinks, engine professionally installed, etc. etc.
      And this catches us up to now.  October 2018 :D
      Current plans / set up for the car.
      (bold installed) (not bold not installed)
      2002 2.4 LPT
      K24 Turbo
      OBX 3" downpipe / cat back exhaust
      2.5" Intercooler piping with front mount
      M56
      Snapp intake pipe
      3" MAF (Currently looking, likely hit a JY for this part)
      COP conversion
      VastTuning Tune
      800cc Injectors (waiting on the mailman)
      W200 Fuel Pump (waiting to see what Aaron wants to do for base map)
      Water Meth System (Would love some input on what to go with)
      Suspension
      IPD springs
      Koni Yellow Struts
      Blisten HD rear shocks
      Upper UMP Strut Brace
      Trunk Brace
      IPD brace that goes under the car (yeah I totally forgot its name)
      Extras
      320mm front brakes (have brand new brakes, pads, lines, brackets, just need rotors and wheels)
      New wheels because those wont fit with what I have </3 sad no more comets or porps
      New Headliner (wonder what pattern ill go with this time around)
      New sunroof assembly (have it just need to swap old one)
      New boost gauge (cant see my prosport during the day... weird af)
      Pictures <3
      [/img]
      Finished the COP install last night.  Pretty quick install.
      I'll keep posting as things happen.
    • By ovlov780t
      Here she is. Putting her up for sale. All offers will be considered.
      https://losangeles.craigslist.org/sfv/cto/d/1998-volvo-s70-t5-manual/6705737681.html
