phunktified
X70 Corner light /turn signals - crud working its way into inside edge next to headlight...
Anyone know the best way to clean the crud out of your turn signal lenses?   Got a nice pair of jewels having this issue.   The only way I know how to pop the lenses off is to let my gf back the car out of the garage...  😆
That works..   :rolleyes:
I have the same problem actually. Water has been getting into my e code turn signals and it's pissing me off.
By my recollection they're plastic welded although looking closer they could be glued. If glued you need to heat the adhesive in the oven at a temperature warm enough to loosen the adhesive but not so hot as to melt the plastic.
