D4vet5
Green stage 2 question
Hi gang, I have a ARD ecu green stage 2. The ecu number is 0 261 203 936 G4.2 I searched and it's from a GLT. I've tested it by putting it into my S70T5m 98 and the car starts and seems to work fine but I haven't really drove it enough and put back my stock ecu since I was worried it would screw something up.Now my question is will I run into problems if I put it in my T5? Since the glt and T5 have different injectors ect.. and will the power gain be different?
Thank you very much
Edited by D4vet5
If the ECU has an ARD tune on it then the original number on the casing is probably meaningless. The original tune has probably been overwritten by whatever is on there now. For example, years ago when I sent Lucky my stock 608 ECU for retuning, I got back a completely different ECU but with a blue tune for my T5. I wasn't thrilled by that, but ARD was the best new thing at the time.
