lowbudgetracing
volvo key fobs s60r rims for sale
  • Similar Content
    • By zman172
      Box #1
      Steering wheel
      Trunk hatch carpeted trim
      Center console
      Box #2
      A/C compressor
      Windshield wiper motor
      Accelerator pedal
      Fuel door lock solenoid
      Navigation Antenna
      Ignition immobilizer
      Ignition switch starter
      Turn signal stalk
      Sensor alarm
      Seat belt restraints (x2)
      Door sill plates (x2)
      Metal radio pocket
      Volvo plastic radio pocket
      Radio
      A/C control unit
      Side view mirror left
      Servotronic fuse relay
      Trunk latch
      Windshield wiper stalk
      Overhead light driver front
      Rear bumper trim (x2)
      Dashboard trim
      Instrument border
      Rear speaker covers
      Driver motor seat controls
      Passenger motor seat controls
      Gear shifter
      Steering wheel column cover
      Center console trim (x2)
      Front cupholders
      Master cylinder
      Box #3
      Side view mirror right
      Fuel pump regulator
      Overhead dome light rear
      Windshield rain sensor
      Tan headrest with long spikes
      Rear armrest with cupholders
      Power steering pump tank
      Right upper brake light
      Right lower brake light
      Armrest for front seats
      Driver window switch box
      Front passenger window switch
      Airbag sensor
      Rear speakers (x2)
      Box #4
      Side airbags (x2)
      Spare tire
      Rear fuse relay box
      Rear third brake light
      Emergency brake with leather
      Rear trunk speaker trim (x2)
      Right rear trunk carpet trim
      Box #5
      All 4 door panels
      Rear bottom single seat
      Single seat leather upper
      Double seat leather upper
      Right front carpet
      Left front carpet
      Drivers front seat
      Passenger front seat
      Rear trunk hatch trim
      Box 6
      Braking systems (x2)
      Glove box
      Emergency brake trim (x2)
      Center console back plate
      Passenger lower dash cover
      Floor door trim (x2)
      Front door handles
      License plate frame
      Seat railing covers
      Box 7
      Instrument cluster 163000
      Radio trim
      Shifter trim
      Rain sensor cover
      Dash radio storage box
      Fuse panel cover
      Gas tank cover
      Front air bag crash sensor
      Rear air bag crash sensors
      Air bag impact sensor
      Headlight switch
      Hazard light switch
      Dashboard airbag
      Ecu
      Box 8:
      Miscellaneous
      On pallet not in box:
      Door pillar vents (x2)
      Torque rod
      Trunk pillar covers (x2)
      Left side skirt cover
      Right side skirt cover
      Trunk trim no cut out
      Dashboard
    • By mynewvolvoexp
    • By Oliverscorsim
      Iv been getting some data and doing expiriments to help all of us. Think our i5 are pretty great but this lack of easy way to tune isnt gonna fly. So far as a recap i started with a 2000 volvo s70 se. She was na and blew a hg. Fixed it happened again this time the bores didnt look too good so out she went and in came a b5254t out of a 06xc70. I got the car to run on the denso and slowly kept going with it. I also got it to run on my me7 and me9 via harness adapter. Started to work on a few ways to do this to answer the age old can i turbo swap question. In short yes and its easier than any of you would believe. The stock denso with alittle monkeyery to the car actually runs this thing perfect until 8-9psi then things get a bit lean but not scary until 13psi. I am working on the me7 and me9 aswell still just put them on the backburner for the simple fact that their too smart for their own good and im low on time these days. I have found (and i am in the early stages of testing.) That a power commander 5 that we use on motorcycles will work on the denso. Its cheap and i think i can get a speed density conversion with it. Read the link for details i just got referred here due to very little help on the other fourm.
      I do intend to sell a pnp set up if theres interest and down the road but i will be posting everything one needs to do it themselves so if anyone can chime in with some help in a few parts id be very grateful and the whole community would benifit.
      Anyone know how big na denso injectors are part number 3460? Iv been searching for awhile and im gonna just eat it and build a flow bench if no one knows but i really dont want too lol.
      Check out my water injection kit its ugly but man it works (no intercooler or lag) and its cheap.
      Before anyone asks yes all of this has been done on the cheap quick and dirty side. Im looking for answers not a show car.. Although i do have this other motor here with sleeves, rods, pistons,studs and a trans thats halfway together for awd swap a real awd swap not the haladex.. But first this is my dd and i enjoy the lack of attention it gets from local pd. Its gonna be a year or two before im going that far with it. For now im looking to make the electronics happy and have some fun. see whats the cheapest most attainable way to do this swap safely and make power is. Keeping in mind that it needs to be simple enough that anyone can do it.
      https://volvoforums.com/forum/volvo-s70-33/going-turbo-some-questions-100421/
      Hope the link is okay promise ill make it less all over the place when i get to my next stopping point with the car. Im just messy
