Replacing Bearing Hub
Posted 23 February 2005 - 01:23 AM
1. Is it important to have an 'angle torque gauge' for measuring the additional tightening, or is it acceptable to estimate the additional angle after using a torque wrench?
2. Is it necessary to use metal adhesive on the splines?
Thanks for your help.
'98 S70 T5 - 223K miles
'04 XC90 T6 - 70K miles
Posted 23 February 2005 - 01:38 AM
Posted 23 February 2005 - 01:40 AM
Posted 24 February 2005 - 03:05 AM
Posted 24 February 2005 - 03:09 AM
99 V70XC 120K
Posted 24 February 2005 - 03:19 AM
Posted 24 February 2005 - 03:37 AM
Posted 24 February 2005 - 06:54 AM
You'll know right away which one belongs on your car, one doesn't even fit over the shaft. I would GUESS the littler one was for 93 models (Rich?) but the one with three ridges on the outside/top of the nut is yours. Good luck!
Posted 24 February 2005 - 03:07 PM
CSF
FOR SALE: 1998 Volvo V70 AWD R Saffron 130K $4000
Speedtuning ECU, Boost Controller, EST intake, 2.5 inch downpipe to dual exhaust, and Enkei 18's
FOR SALE: 1996 Volvo 854 Turbo Platinum 160K $3000
Speedtuning ECU, V70R injectors, EST intake, 16T, 3 inch downpipe to 3 inch Catback, IPD/OMP/Koni Suspension, and Volan 17's
Posted 24 February 2005 - 06:32 PM
My nut and bolt collection is filling up my tool boxes. Comes in handy though!
Posted 26 February 2005 - 06:50 PM
1. Can the control arm-to-sub frame bolts/nuts be reused? The Haynes manual indicates that they can't be reused.
2. The torque specs for the E-14 Torx bolts that hold the bearing hub into the spindle are different between Haynes and Bay13. Maybe this is because the Bay13 instructions are for 850s and the Haynes manual is for the 70-series??... Bay13 reports 65nm then 60degress while Haynes reports 20nm, then 45 nm, then 60 degrees.
Thanks for the help.
Posted 26 February 2005 - 08:02 PM
2) either method yields the same results, the first (bay13) is right off of the VADIS instructions.
Posted 27 February 2005 - 12:11 AM
