This is weird. My key fob worked normally for like a month and a half, but a few days ago, the lock function stopped working. Unlock still works fine. What the heck? Any idea on how to fix it (if fixing it is possible)?
Key Fob Problem
Started by 855T, Feb 24 2005 02:05 AM
6 replies to this topic
Posted 24 February 2005 - 02:05 AM
2010 WRX (2.5k) - stock, until the warranty's gone
1995 855T (160k) - deer dents, various mechanical failures, voluminous trunk
Posted 24 February 2005 - 06:15 PM
bump
Posted 24 February 2005 - 06:26 PM
Have you tried replacing the battery?
I know my remote start fob eats batteries like a mofo. Just a thought.
Posted 24 February 2005 - 09:23 PM
QUOTE(855T @ Feb 23 2005, 10:05 PM)
pop the sucker open and give it a good cleaning with some alcohol or windex.... probably just dirty contacts. could be the battery though.
2001 C70 Coupe HPT
#5 Guest_Mr. Norm_*
Posted 24 February 2005 - 09:53 PM
Short the switch and see if the function works. If one side works, it isn't the battery. Likely the switch is dirty or bad.
#6 Guest_Guest_mad finn_*_*
Posted 26 February 2005 - 06:00 AM
QUOTE(855T @ Feb 24 2005, 02:05 AM)
Take the fob apart so you can see the printed circuit board with the buttons on it. Try depressing the locking button the printed circuit board, and if it works that means when you are pressing the lock button (when the unit is assembled) the button isn't making good contact with the button on the circuit board. You may have to put a thin spacer between the buttons so when you press the button, the circuit boards button is being depressed also.
Posted 26 February 2005 - 03:09 PM
my lock doesn't work all the time...very annoying, my fob looks like a sealed unit
i notice on the 95's that the fob has a sort of click to it but on the 96's they are more of a soft touch no click..not sure about +96 and -95's though
