Engine Mount
Posted 25 February 2005 - 06:57 AM
I would like to try to intall a new mount by myself, but the wheel wells seem to be in the way... I know that the picture on Bay 13, the mount is very visible but my wheel well basically cover the more than half the mount???
Thanks,
Mike
Posted 25 February 2005 - 12:40 PM
Posted 25 February 2005 - 04:18 PM
Also do you use a jack to hold up the engine or just something between the subframe and engine to get the old mount out and new one in?
Posted 25 February 2005 - 04:23 PM
I just used a jack w/ a piece of wood for better pressure distribution on the oil pan. Worked like a gem.
Posted 25 February 2005 - 04:52 PM
Okay that's what I read on Bay 13 but isn't the oil pan fragile, thats why we purchase the IPD skid pad? I just figured that's alot of weight!
Anyway just wanted to double check to be sure...thank you.
Posted 25 February 2005 - 11:43 PM
Posted 26 February 2005 - 05:44 AM
You always answering my posts man, you rock!!!!!
And thanks to all the others as well!
One more question, I got the mount today and went to my friends house hoping that he would help me out cause he has a jack and I don't but he didn't seem like he was up to it since he stated, "do it in the spring". Anyway I really want to do it, now, tonight!!!!!!! Can't I just use all sorts of wood to hold up the engine and then use something to prompt up the front of the engine on the side of the mount?
Thanks,
Mike
Posted 26 February 2005 - 06:55 AM
Edited by mikie, 26 February 2005 - 06:55 AM.
Posted 26 February 2005 - 02:24 PM
http://buy1.snapon.com/catalog/item.asp?P6...ore&dir=catalog
The rear 17mm is easy, with a regular 17mm wrench or a socket and ratchet, you just don't have a lot of movement, will take lots of short swings of the wrench/ratchet.
Posted 26 February 2005 - 03:03 PM
Posted 26 February 2005 - 05:13 PM
Ended up I bought the engine mount from volvo dealer. Can't go wrong with volvo original part.
Edited by bogelo, 26 February 2005 - 05:13 PM.
YOU ->
<- ME95 850 Turbo - white brick
Mods: Greddy Profec B spec I EBC, Samco turbo hoses kit, Blitz DTT DC-II, Euro-spec headlight, Optima Red Top battery.
Audio: Clarion VRX610 headunit, Clarion DPH7500z DSP, Clarion CDC1255z 12-CD changer, McIntosh MC440, Zapco AG200, Nakamichi SP-S522 component speakers, Infinity reference 2-way speakers, nakamichi SP-W12 subwoofer, Phoenix Gold 4-Ga multi amplifier cable kit.
94 850 wagon - green brick
Mods: 8000K HID
Posted 26 February 2005 - 05:41 PM
I got mine from FCP Groton and it fits. You just have to check to see which one is on your car before you order.
Posted 26 February 2005 - 05:44 PM
Thanks guys for your help!
#14
Posted 26 February 2005 - 06:15 PM
White850T5:
Probably your mount is the older version (subframe < mid 1995) and I believe the older version don't have 2 pins on the bottom that fit to the holes in the subframe. I knew what I ordered from fcpgroton and I even specified my VIN.
Mikie:
Do you have picture? I did mine (bolt that is on the rear end) from the other side. You need to stick the wrench from the other side (oil pan area). Use this kind of wrench (I believe it's 17mm, could differ from urs).
Edited by bogelo, 26 February 2005 - 06:22 PM.
YOU ->
Mods: 8000K HID
#15
Posted 26 February 2005 - 07:20 PM
White850T5:
Mikie:
I have the one with the pins as well. I did try from the other side with my rachet but my rachet is too big I need one of those wrenches that you have in the picture. I just didn't realize that my mount was a little diferent then the one shown in Bay 13 (which seems to be much easier to get at) until my wheel was off and my hands were all dirty. I'm going to go to Canadian Tire and pic one up, should be easy then. Thanks everyone, and thanks for the intructions at Bay 13.
#16
Posted 26 February 2005 - 08:28 PM
YOU ->
Mods: 8000K HID
#17
Posted 27 February 2005 - 01:45 AM
Edited by mikie, 27 February 2005 - 01:45 AM.
