Check Engine Light
5 replies to this topic
#1 Guest_Guest_Bill_*_*
Posted 25 February 2005 - 09:51 PM
My CEL is on and I am told it is due to an SAS problem. I had the valve, air pump and relay all changed about 18 months ago and I really don't want to replace everything again. I would like to replace the problem part only, so any help would be greatly appreciated.
So far I have done the following: removed and inspected the air pump and it had no water in it. The connections all looked good also. On a cold engine I checked for vacuum on the small line at the SAS valve and vacuum was present. When I reattached the line, the SAS valve made a clicking sound that stopped when the vacuum was removed and started again when the vacuum was reapplied. While I was at the SAS valve I removed the large hose from the air pump and found no air was coming through it.
I would like to know if there is a way to test the air pump, the relay and the controller independently. The Bay 13 write-up is great for replacing everything in the system, but I don't want to just start replacing parts and hope I find the culprit early. Again, I would appreciate any help.
Thanks,
Bill
#2 Mesoam
  • 18,673 posts
Posted 25 February 2005 - 11:41 PM
pull the air pump and put 12v to it, will turn on if its working...i used a batt charger worked great..I am fairly sure my relay is the problem as they are known to be a weak spot on our cars
96 854 R, CLICK ME
The Jeep
#3 MrWinkey
MrWinkey
    Am I drunk? You tell me!
  • 4,759 posts
Posted 26 February 2005 - 01:43 AM
Why not post the year /model and the code if available?
"SMOKE TROUT NOT CRACK"
#4 Guest_Guest_Bill_*_*
Posted 26 February 2005 - 08:13 PM
The car is a 1997 GLT and I don't know the codes it pulled up. The mechanic told me it was SAS related again. (Same mechanic that replaced everything last year.
Bill
#5 Mesoam
  • 18,673 posts
Posted 26 February 2005 - 10:23 PM
i suggest you go to auto zone and get your codes checked for free or buy a code reader for yourself...is this indy reputable?
96 854 R, CLICK ME
The Jeep
#6 MrWinkey
MrWinkey
  • 4,759 posts
Posted 27 February 2005 - 01:25 AM
QUOTE(Mesoam @ Feb 26 2005, 05:23 PM)
I agree.......
Not all indy's have large fangs and drool green saliva some are really nice guys wink.gif
