Have '96 850 that is intermittently sticking in high gear when starting from a stop.
Does not do it all the time. Putting in reverse sometimes corrects.
Symptoms are similar to those described when the low-gear arrow flashes on the dash putting tran in limp home mode, HOWEVER, arrow does not flash. In fact, arrow never comes on, even when trans is in L or 2. CEL is not on, so no codes to check.
Backup lights come on when put in reverse, so would not seem to be PNP switch.
Have tried 20 times P -> L shift to clean PNP switch contacts.
Econ/sport/winter mode switch has no obvious effect in Winter mode. Have ordered new mode select switch, but am puzzled that arrow does not come on in L.
I know this topic has been discussed in context of PNP switch, but wonder if anyone else has seen symptoms like mine.
I guess next step if mode sel switch does not fix problem is to replace PNP.
Any additional thoughts would be much appreciated.
850 Transmission Sticking In High
Started by jtole, Feb 26 2005 12:30 AM
Posted 26 February 2005 - 12:30 AM
Posted 26 February 2005 - 01:28 AM
Hummm...doesn't really make sense other than possibly a real internal issue? You stated now arrow flash? and I assume no console switch flash either?...did you try and have the codes read? on a 96 you need the proper scan tool for that....maybe that will help?
"SMOKE TROUT NOT CRACK"
Posted 26 February 2005 - 01:33 AM
QUOTE(jtole @ Feb 25 2005, 08:30 PM)
Sounds like the bulb might be burnt out for the arrow....
My car (though a 1994) did the exact same thing. The usual suspect would be pnp. Mine turned out to be solenoids. It would not shift into first or second from a start...usually would when cold, but often not when at temp. Transmission flush helped for a while...finally had to replace solenoids. I did however get a code for s2 solenoid....
A transmission flush and codes would definitely help narrow the problem.
One thing I noticed when mine was failing was that the transition to reverse was very rough when the lower gears weren't working...almost like a jerking.
Jens Christensen
