Cruise Control Vacuum Pump
4 replies to this topic
#1 winsor2
winsor2
  • 1 posts
Posted 26 February 2005 - 06:46 PM
QUOTE(Johnnie855T @ Feb 23 2005, 02:58 PM)
Does anyone have a wiring diagram for the cruise sontrol system?
Does anyone know which two pins you apply 12vdc to inable to find out if it works.
#2 UncleBoost
UncleBoost
  • 114 posts
Posted 27 February 2005 - 11:49 PM
Are you sure its the Vacuum pump?
Just yesterday I decided to replace my fan blower since it has bben squealing and on very cold days it won't work at all. I put a 99 V70 fan motor in and had to make some mods. I should have gotten the Harness plug. Anyways, I remember reading a diagram on the Cruise control circuit with a nice Pictorial somewhere on this site. It showed where all the vacuum hoses go. Since I was already buried up under the dash I decided to check the Cruise switch since the cruise has never worked since I had the car. Turned out the brake pedal switch was knocked out of its mounting bracket and was sort of dangling down! Whooooopeeeeee! I just knew that was the problem....and it was. Cruising now son!
My point is check the little stuff 1st. I was getting ready to start pulling the battery and checking the pump and all that.....I had already gotten a vacuum pump and new hoses anticipating those to be bad when it was only the switch. Check your Switch and hoses for leaks. (Under the battery tray etc.) Find that diagram here on the board somewhere. Good Luck.
-=UncleBoost=-
Edited by UncleBoost, 27 February 2005 - 11:53 PM.
1994 855T
Performance mods: None so far
Suspension mods: Not yet
Visual mods: Rear Wing, Blacked out tint in the Rear
-=Fact not fiction=-
The sky is not the limit....The Ground is.
If our legs bent backwards what would racing seats look like?
#3 WhiteT5
WhiteT5
    Sampson
  • PipPipPipPip
  • 4,828 posts
Posted 27 February 2005 - 11:53 PM
This may help you.
- Sean
#4 UncleBoost
UncleBoost
  • 114 posts
Posted 27 February 2005 - 11:57 PM
QUOTE(White850T5 @ Feb 27 2005, 07:53 PM)
This may help you.
Ha ha haa....Thats AuntBoost. She would kill me if she found out.
Shhhhhhhh!
1994 855T
#5 Karlson
Karlson
    Vodka Lover
  • 7,142 posts
Posted 28 February 2005 - 12:44 AM
nice to see web-site from my homeland
1996 850R... gone, but not forgotten
