1) Climate sensor for a/c has come out of the dash and the plastic part of the dash it connects into is cracked. can i just replace this piece of trim or must i replace the whole dash
1.5) sound like the dash is movin around - can it be padded more???
2) passenger side seatbelt does not rewind itself so well, has a lot of slack - is there a tensioner to replace?? how much?? how hard???
3) door trim is bubbling (AHHHH!) - how to fix? replace? who sells used panels??!!
4) hear a strange clanking noise coming from under car over bumps - however suspension appears to be tight and tip-top - problem has been getting worse over time. just replaced inner and outer tie rods, stabilizer links, struts, upper strut mounts, shocks, rear shock mounts....what else could it be??!??!
what are some things taht you volvo owners do out there to insulate and "solidify" our cars and make them feel more vaultlike?
