Ignition Timing Question - What's Normal
#1 toms850R
toms850R
  • 230 posts
Posted 27 February 2005 - 09:56 PM
For those of you that do not read the performance section - I have a question about ignition timing...
Read a few posts a while back about ignition timing pull under boost. So I startted monitoring mine and noticed the following:
a- at idle or a stop light it's usually around 6 deg
b- under partial throttle the timing pegs at 16.5 deg
c- under WOT it usually drops from 16.5 to about 11 deg or so, sometimes less depending on load conditions
A couple of questions:
a- should it peg at 16.5 or is my scan tool not providing the correct data?
b- should the timing drop under WOT?
I have a ST chip, high flow cat, stock cat-back. Stage 0 is complete.
Thanks,
Tom
2000 V70 SE - blue, Stock
1997 854R - white, Speedtuning ECU, TurboXS MBC, K&N panel, H&R springs, Koni adjustables, Samco hoses (Sold )
#2 Bay13
Bay13
  • 6,378 posts
Posted 28 February 2005 - 12:58 AM
I can't find a listing for what it should be.
#3 MrWinkey
MrWinkey
    Am I drunk? You tell me!
  • 4,759 posts
Posted 28 February 2005 - 01:05 AM
You ever watch timing on a DI car on a scan tool....it will drive ya' nuts!!! But being that it's not a DI car I still have never watched the timing? Perhaps I should? next time I'm road testing for the forever readiness monitors I will look. But being a technician I must inquire as to why your reading it and not relying on the ECM to do it's work? Are you trying to diagonsis a problem or just researching?
"SMOKE TROUT NOT CRACK"
#4 toms850R
toms850R
  • 230 posts
Posted 28 February 2005 - 09:01 PM
QUOTE(MrWinkey @ Feb 27 2005, 08:05 PM)
The ECM is doing all the work. I read that timing pull can happen under boost if the plugs are not properly gapped. I guess that I am just looking for a problem that may or may not be there. Thanks.
Tom
