Some Tourque Spec Questions
6 replies to this topic
#1 T501
T501
  • 229 posts
Posted 28 February 2005 - 04:00 AM
This is for Bay 13 or anyone else that knows the correct specs.
I'm going to install lowering springs in a couple of days on my 2001 S60 T-5 and I'm wondering what the torque specs are on the:
3 top strut mount bolts
spring retainer bolt (if thats not the proper name I mean the one center bolt on the top of the strut.)
spindle bolts
And if I missing any bolts that need to be torqued properly please let me know.
Thanks!
Edited by T501, 28 February 2005 - 04:01 AM.
Dave
Black '01 S60 T5 GT
Volvo sport suspension
EST intake kit
EBC Greenstuff up front
On order: TME springs, VMS poly bushing
Plans:
3" Downpipe, 2.5" Ferrita Exhaust
BSR PPC
EST SAM grill
Silverstars hi/lo and fogs - LOOK MA, NO HIDZZZ!!!
'95 White 850 N/A ipd springs 17" TSW 5 spoke (totalled, not by me though)
#2 T501
T501
  • 229 posts
Posted 28 February 2005 - 07:31 PM
*bump*
Dave
Black '01 S60 T5 GT
EST intake kit
Plans:
BSR PPC
EST SAM grill
#3 MrWinkey
MrWinkey
    Am I drunk? You tell me!
  • 4,759 posts
Posted 01 March 2005 - 12:55 AM
QUOTE(T501 @ Feb 27 2005, 11:00 PM)
spindle bolts
Thanks!
3 top bolts ...nice and snug
strut to upper mount...there are 2 make the + nut snug and make the top nut tight
spindle bolts...tight
Honestly ...technicians torque very few things considering the amount of hardware a vehicle has, just go by feel as they come apart you'll be fine.
"SMOKE TROUT NOT CRACK"
#4 T501
T501
  • 229 posts
Posted 01 March 2005 - 02:54 AM
I know most techs don't torque to specs, I used to be one for few years, I didn't either. But since it's my car I would like to do everything to spec if possible, you know? smile.gif Oh well i guess I'll do it by feel like I used to do on everyone's car. lol
Dave
Black '01 S60 T5 GT
EST intake kit
Plans:
BSR PPC
EST SAM grill
#5 Kashif
Kashif
  • 1,846 posts
Posted 01 March 2005 - 07:22 PM
Well I don't know the Torque specs for a S60 but I imagine they can't be far off from that of a 850/S70.
3 top strut mount bolts : 18 ft*lbs
spring retainer bolt : 52 ft*lbs
Suspension strut to steering knuckle Stage 1: 51 ft*lbs, Stage 2 : tighten an additional 90 degrees
Cross shaped nut: 52 ft*lbs
Use a torque wrench when you are opening the nuts, the amounts of force to release the nuts should be approx the same as tightening them.
#6 BeachRat
BeachRat
    Team GKT
  • 2,761 posts
Posted 02 March 2005 - 12:02 AM
QUOTE(Kashif @ Mar 1 2005, 12:22 PM)
Not necessarily. Even though it's a newer car, driving and time may have loosened or tightened the nuts well-off torque specs. Also, unless you have a needle-type torque wrench, using a click-type would be a huge PITA! Set it low, click, no. Little higher, click, no. Little higher, click, no. See my point?
#7 Kashif
Kashif
  • 1,846 posts
Posted 02 March 2005 - 12:10 AM
My bad, I have the deflection beam type wrench, not the click type. I was thinking along those lines.
He could of course ask a Volvo tech at a dealership for the specs, or maybe he could pm Rich. I am sure that he would know.
