Hey all,
I haven't posted in awhile. I just dropped my oil after 3300 miles of dino oil in the auto-rx rinse phase.
I switched to valvoline syn-power full syntheti 5w30...put in 6 quarts and a mann filter.
I drove about 75 miles on it after the switch, almost all of which was 15-45 minute drives. I drove about 12 miles this morning, let the car sit for awhile and pretty much cool down, and then I checked the dipstick and it had all sorts of white foam on it.
6 to 7 inches the dipstick there was a good 1" or 2" of foam and some smaller amounts down by the bottom. When I stuck the stick back in it had just as much on it. I like this synthetic...it seems to start easier and rev a little smoother.
Is this cold weather related? We're solidly in the 20's right now. Water in the system? I thought I would've burned it off.
Is it because I put 6 quarts in and overfilled it a little?
Any help appreciated. Thanks guys!
Foam On Dipstick
Started by jo346820, Feb 28 2005 05:11 AM
Posted 28 February 2005 - 05:11 AM
Sold my 95 850 in June of 05 at 140+k....now looking back to volvo as a potential future car.
Currently driving an 06 Civic SI
Posted 28 February 2005 - 06:02 AM
sounds like condensation from cold weather.
Posted 01 March 2005 - 08:57 AM
Had / have the same. Had foam UP to the top of the dipstick. Have been told it is "normal" and could be due to condensation.
- Just watch the levels a bit.
- Oil in the cooling water?
CheerS
Patrick
CheerS
Patrick
There are those who think a car is just a machine - pray for them
'98 Volvo V70
- HKS SSQV BOV
- UPsolute'd
'74 Wife, stock
'00 Boy, stock
'02 Boy, stock
'98 Volvo V70
- HKS SSQV BOV
- UPsolute'd
'74 Wife, stock
'00 Boy, stock
'02 Boy, stock
#4 Guest_Guest_keefus_*_*
Posted 01 March 2005 - 08:01 PM
Sounds like classic short-haul driving condensation. Take it on a long drive, and get it really warmed up good, then re-check. The heat should drive off most, if not all of the condensation.
Otherwise, I would say that you might have coolant in the oil, in which case I would suspect a blown head gasket, or oil cooler leaking into cooling system, or vice versa.
keefus
keefus
