No Power To Fuel Injectors
20 replies to this topic
#1 Jeph430
  • 2,714 posts
Posted 06 March 2005 - 07:21 PM
Any idea where to begin? Not a fuse, no bad ecu. Please help, we need to get this car running ASAP!
'01 C70 Coupe - Black on Black '04 XC70 - Silver on Black
'04 C70 Convertible - Black on Volcano Red '98 S70 GLT T5 - Black on Black
'95 850 T-5R - Black on Black '06 Harley Davidson Super Glide Custom - Sunburst Yellow and dripping with chrome!
#2 Jeph430
  • 2,714 posts
Posted 07 March 2005 - 05:09 PM
Bump to help me please....come on guys...
#3 jda2000
  • 1,027 posts
Posted 07 March 2005 - 05:22 PM
Have you been working in the engine prior to your problem?
did you leave something unplugged? Check the fuel pump relay
John, Sarasota, FL
'01 V70 T5, '07 S60 2.5T
#4 billr99
  • 271 posts
Posted 07 March 2005 - 08:38 PM
Pull one of the plugs, if its wet from unburned fuel more than likely you have an ignition problem. If its dry, then its fuel system problem. If its the former, make sure you are getting spark to the plugs. If not, there are any number of reasons but the easiest are to check your cap and rotor for arching, etc. Also make sure all your wires to the coil are OK. In regard to the latter, see if you can hear the fuel pump running. Could be a bad pump, bad wiring to the pump, or a bad fuel pump relay. These items would be the basics. If all of these are OK, things start getting a bit complicated and probably best to cal lin a pro if you are not real familiar with this type of thing.
Good luck,
Western Head, NS, CDN
'02 V70XC - @180K kms
And a whole bunch of past Volvos (7), VWs (7), SAABs (5), Land Rovers (3), etc.
#5 Jeph430
  • 2,714 posts
Posted 09 March 2005 - 03:08 PM
Fuel pump is working, there is no power to the fuel injectors It is at a shop, a Volvo only shop. Other dealers have been called and my uncle who is a VP at ASE is on the issue too with Volvo Cars NA and noone knows what is wrong. Was just hoping someone would have some more guess' on here. Thanks though.
Edited by Jeph430, 09 March 2005 - 03:10 PM.
#6 billr99
  • 271 posts
Posted 09 March 2005 - 05:32 PM
QUOTE(Jeph430 @ Mar 9 2005, 11:08 AM)
Just on an off chance. I had the same trouble with a Porsche that I had one time. Turned out to be a cold joint in the wiring loom going to the injectors. Porsche dealer couldn't figure it out immediately so the fix ended up being a $2 wiring splice and $1000 of labour while everybody stood around scratching their heads.
Moral of this story, see if you are getting power to the injectors. Surely Volvo has a procedure that will allow this to be checked.
Good luck,
#7 MrWinkey
    Am I drunk? You tell me!
  • 4,759 posts
Posted 10 March 2005 - 01:32 AM
I'm assuming it's a 93 850 ...have they replaced the fuel injection main relay? I call it the injector relay. Under the rad. shroud...seem's like I repeat myself ...If that's it you owe me a beer smile.gif
"SMOKE TROUT NOT CRACK"
#8 Jeph430
  • 2,714 posts
Posted 10 March 2005 - 01:32 PM
They replaced it, wasn't it... They're just throing parts at it I think, I told em to check electrical from the beginning.
#9 MrWinkey
  • 4,759 posts
Posted 11 March 2005 - 12:01 AM
QUOTE(Jeph430 @ Mar 10 2005, 08:32 AM)
From what you say sounds like it can't be fixed over cyberspace? Wonder what the towing bill would be to PA biggrin.gif ...sorry
#10 Jeph430
  • 2,714 posts
Posted 16 March 2005 - 09:00 PM
He soldered a connection he said was bad. Drove it home, died that night, started again the next day. Driving it back to the shop, it kept sputtering and wanting to die. Every time it would do that, the CEL came on. He's replacing the cam position sensor again, as he said it threw 2 codes for it...
#11 Figawi
  • 3,116 posts
Posted 16 March 2005 - 09:04 PM
hey im having a similar problem. my car won't start and im getting fuel to the rail and spark. do you know what connection needed to be soldered?
Andrew
2004 Volvo V70 2.5T Titanium Edition
#12 Figawi
  • 3,116 posts
Posted 16 March 2005 - 09:06 PM
also, how did u come to the conclusion the fuel injectors didn't have power?
Andrew
#13 MrWinkey
  • 4,759 posts
Posted 16 March 2005 - 11:27 PM
QUOTE(Driver850 @ Mar 16 2005, 04:06 PM)
Well his problem wasn't but yours might be the fuel injection relay
#14 Figawi
  • 3,116 posts
Posted 17 March 2005 - 12:33 AM
yeah i was thinking that. is there a way for me to test the injection relay?
Andrew
#15 whilst
  • 99 posts
Posted 17 March 2005 - 01:20 AM
QUOTE(Driver850 @ Mar 16 2005, 06:33 PM)
Could this be an ignition switch problem?
Just a thought.
Easy and cheap.
'95 854T 197K+, '98 S70 base 5spd. 163K, '99 Audi A6 quattro 109K, '69 Yamaha DS6C,1973 Honda CL 350 , 1950 Roadmaster balloon tyre cruiser.
#16 Figawi
  • 3,116 posts
Posted 17 March 2005 - 01:37 AM
QUOTE(whilst @ Mar 16 2005, 09:20 PM)
Just a thought.
Easy and cheap.
again is ther a way to test that because i dont want to buy a bunch of parts unless i know they are bad. it would save me money if i could test them somehow
Andrew
#17 MrWinkey
  • 4,759 posts
Posted 18 March 2005 - 12:25 AM
QUOTE(Driver850 @ Mar 16 2005, 07:33 PM)
Just replace it...
#18 Figawi
  • 3,116 posts
Posted 18 March 2005 - 12:31 AM
well thats a waste of money if thats not the problem
Andrew
#19 MrWinkey
  • 4,759 posts
Posted 18 March 2005 - 12:36 AM
Your right??? Perhaps someone here can help you on testing the relay I cannot? I have only been fixin' these things for 17 years I probably don't have enough experience under my belt yet? Good Luck wink.gif
#20 Figawi
  • 3,116 posts
Posted 18 March 2005 - 04:15 AM
sorry if i came across as being rude before.
Edited by Driver850, 19 March 2005 - 01:12 AM.
Andrew
IPD
